| Thread Tools |
| This thread is privately moderated by BRENDAN LUGO, who may elect to delete unwanted replies. |
Joined Aug 2002
as per Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated} Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
Romania, Dolj, Craiova
Joined Sep 2007
You have 4 voltages available in the sensor station.
So you can tap in the balancer plug of up to 4s pack. |
Latest blog entry: JRSky - birth of a dream radio
Joined Sep 2007
There are no external "sensors", the sensor station just has 4 voltage inputs where you plug connectors with wires of the voltages you want to measure. |
United States, WI, Kenosha
Joined Aug 2004
I would like to see the Flap Control system to be improved to allow for the delay of both the flaps and any associated elevator compensation.
In my JR 9303 this is a simple activity of adding delay value in the Flap System. Here is a link to a setup document for the JR 9303 which documents that process. You can see it on the bottom of page 4. http://www.jrradios.com/ProdInfo/Files/p51setup.pdf This is beneficial to most any warbird to smooth the input of flaps without pitch up/pitch down in the application of the flaps. |
Joined Sep 2006
Hi, I'm a guy new to RC Groups,... I usually read and think a lot before writing, but when I write... I write
(this does mean:" sorry for the LONG post)First of all I want to thanks Mike a lot for solving issues I had with my A9 (from request to solution it took about 4 hours, isn't that a very very low latency? )- In the meanwhile I'd like to see what Hitec has 'approved', so we achieve peace of mind and stop asking (and start waiting )A sort of official lists group that could be on the top of the thread: - Features already implemented in actual firmware release (I mean: "stop asking and RTFM and/or this list" )- Features already implemented in the next to come firmware - Features approved but still to be implemented - pending approval (any user can vote the feature to give Hitec an idea of our priority) - rejected (cannot be implemented due to explained technical limitation... ex: The A9 cannot connect to the web and dowload the new firmware of your hely ESC and upgrade it while flying because... it could be dangerous )My suggestions follow... starting with the most important: Model fine tuning: - command dead band and acceleration setting, at least on throttle and rudder (gyro) The dead band is a zone around the center (and endpoints) that you must go beyond for the servo to become moving. The acceleration is the contrary (learned from, more than ten years ago, and massively used on my Futaba 3VC, now I really need it for the GP750 GYRO from Align), as soon as you move the stick, the control jumps immediately to the end of the dead band of the gyro/servo/ESC, assuming the deadband does exist, cannot be eliminated from the model, and you do not want it. This way we eliminate both electronic unwanted dead bands and some mechanical unwanted slops. Both could be achieved using a input output curve mix on the same command (or using a slave command to pass through), but the curve must give the possibility to set the points position (x axis), other than the values (y axis) Example: acceleration curve: 5 points (positions: -100, -0,1, 0, 0,1, 100), with values: -100, -5, 0, 3, 100. This way we get rid of 5% left and 3% right slop/dead band. Alarm: - Voltage alarm per model is a must. dual / triple would be nice. (ex: 9.6 one beep, 9.3 two beeps, and 9.0 five beeps) I think at the moment it has to be defined through the HPP cause it's a module feature, why not to make it a TX feature? Model Safety: - minimum recorded SPC voltage displayed (it appens whe you accelerate hard, and usually when you accelerate hard you are not watching the tx display). Gyro: - Gyro gain that could be reversed, in just one of the dual rates for HH+Rate gyros. - Control command that controls separately the gain for each one of the dual rates for HH+Rate gyros. Alarm: - different alarms type/volume per event: the timer could be low, not to be annoyng, while the battery MUST be different and louder (at least the last battery alarm) Audio interface: - Different event audio: each event could have a different (simple) effect (Bip, Biiiiip, Bop, Click, tic, toc, trrrrok) with different volume (NO, Low, Mid, Hi, Max). I mean the trimmers could 'click' or 'tic', while the software +/- buttons could 'toc' etc. - Trimmers could sound at a different frequency for the position (Walkera radio trimmers act this way) Models programming: - can copy (merge) only some setting from an existing model (ex throttle curve from one or more flight mode) Model fine tuning: - sinus compensation to have all linear travels Safety - my walkera radio has the possibility to assing an ID number to a model, this way the receiver 'arm' only when the number is recognized (it's a model match feature, dunno if it's allowed by spektrum license when made this way). (the actual model display and confirmation is OK, but this way could be better) - some time my radio beeps and I do not know what does she want to say (add a frame that pops up for a second that show alarm information, customizable if small, big or 'full screen, and that lasts for a secon, for three, or until tapped (disabling screen lock until tapped))- rename all flight modes, including normal and hold - screen touchlock 2 min, 3 min and 5 min. - I use speed transitions for my flight modes, it would be nice to hear trr.trr.trr.trr.trr.bip, to know while it's transitioning and when it's ended Well, I think it could be enough for my first post thanks to all of you for being here ![]() ps.: sorry for my english, it's not my primary language |
What would be really cool is if "aileron to rudder mix" and aileron and elevator dual rates could be proportionally increased in relation to the throttle stick position in a flight mode. As you lower the flaps, aileron to rudder mix is increased proportionally instead of on/off. Example: you don't need as much aileron to rudder mix at half flap as you do at full, the same is true as airspeed is lowered with the use of flaps concerning elevator and aileron response, proportionally increasiing throw would be better here. If these rates could be increased proportionally it would make a truly smooth transition into a Landing flight mode. This might be a software programming nightmare to implement so, bottom line, a flight mode on/off switch on the throttle stick would be great. John |
| Thread Tools | |
| Question what's on your Christmas wish list ? | brn-grose | Alabama's Rocket City Renegades | 26 | Dec 11, 2009 10:58 PM |
| Discussion 2009 3DHS Wish List | FlyCush | 3D Flying | 31 | Oct 18, 2009 12:25 AM |
| Discussion Training Helicopter- wish list | fpainter3 | Electric Heli Talk | 20 | Oct 12, 2009 08:28 PM |
| Rave Phase 3 fan thread and future plane wish list :) | SmoothCruizer | Foamy EDFs | 0 | Feb 20, 2008 03:22 PM |
| Discussion Mamba Max ESC software wish list..... | Marv829 | Castle Creations | 9 | Jan 04, 2008 01:42 AM |
