This thread is privately moderated by BRENDAN LUGO, who may elect to delete unwanted replies.
Old Jun 25, 2012, 09:35 PM
copperbricks's Avatar
Joined Aug 2011
I think it'd be neat if we could set up a preflight checklist, like with the dx18t. With the touchscreen it should be a piece of cake
copperbricks is offline Find More Posts by copperbricks
Old Jun 25, 2012, 10:10 PM
Seattle, WA
LowWatts's Avatar
Joined Mar 2006
Try a post it note, it'll save us all $$$$$$$$$$$$$$$$$$$$$$$$
LowWatts is offline Find More Posts by LowWatts
Old Jun 26, 2012, 12:31 AM
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
At this point I would be happy with a full travel b-fly mode that also could be set as a flight condition..........
B-fly travel programmable for -150% to 150% on flaps and
If you move the throttle stick to activate b-fly ( b-fly goes from 0 to 1 depending on where you set the triggerpoint. I love this off set function!) it also triggers the b-fly flight condition and all my travel, differential and mixes for a precision landing magically switch on because it is a flight condition.
Yes only two things
fcbflyer is offline Find More Posts by fcbflyer
Old Jul 09, 2012, 06:28 AM
Česká republika, Hlavní město Praha, Praha
Joined Jan 2007
Does someone from hitec still read this ?
warhawk.cz is offline Find More Posts by warhawk.cz
Old Jul 09, 2012, 07:51 AM
a.k.a. GlideZilla
Dean.roberts's Avatar
Australia, VIC, Box Hill North
Joined Sep 2003
Only AT.
Dean.roberts is offline Find More Posts by Dean.roberts
Old Jul 09, 2012, 10:50 AM
You are a "go" for reentry
High Orbit.....
Joined Jun 2009
Course Hitec reads this.... they're just out making the next radio to fit into the new 18 channel radios.
Re reminder to shut down the TX, wishlist... add a accelerometer in the TX so that if it remains motionless for more than 5 min and is on a voice note starts saying, Transmitter is still on. I could even live with the same safty feature on a jet ski etc where you have a key around your wrist that you have to unplug as your TX on/off switch so that its not as easy to forget that you've left it on.
Timers. Wishlist.... Three timers.
Always have the option to silence any individual audible timer by touching the timer on the touch screen.
Continue to have any number of audible sound bits, owners choice (say limit to 10), from the SD.
1) Count up timer stick/slider/switch activated to start and stop above a certain stick/slider/switch setting.
2) Count down timer, allowing Flight mode to engage at a assignable time, stick/slider/switch activated. Count down timer to read out time each minute eg "three minutes left".... till in the last minute, 40 seconds left, 30 seconds left, 20 second left, 10 seconds, 5, 4, 3, 2, 1 followed by countup 30 second interval audible note, "30 seconds over", followed by minute intervals over.
3) TX on connected to particular RX timer to monitor how long your TX has been talking to a particular RX. This portion could also add a check list.
The combinations above should cover TX monitoring, Pack time monitoring, did you leave it on monitoring, its time to land monitoring and even timing of a flight routine when to enter into a certain portion of a flight plan.
None of the above being expensive seeing that we have disposable toys with similar electronics for near nothing all over.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jul 09, 2012, 11:23 AM
Low altitude flyboy
MajorMal's Avatar
Minneapolis
Joined May 2010
Good timer ideas, but I think the best idea for the timer is that it actually keeps time instead of just guessing. 10 seconds off for every minute is pretty bad. A very sore spot for me. I'm patiently waiting to see if they can fix that serious issue.
MajorMal is offline Find More Posts by MajorMal
Old Jul 09, 2012, 11:30 AM
North West UK
Joined Nov 2010
I agree. My sand filled egg timer is more accurate.
Roblister is online now Find More Posts by Roblister
Old Jul 09, 2012, 11:32 AM
High Orbit.....
Joined Jun 2009
True and it should be fixable but if the offset is accurately known then you can recalibrate your timing with an extra 10 sec/min.
But ya I'd add that to a wish list... accurately calibrated time.
Old Jul 09, 2012, 12:17 PM
Don't ask me anything...
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Originally Posted by Dean.roberts View Post
Only AT.
AT not "read". AT register; search memory collate banks; AT post. AT down stand .
Woodstock 1 is online now Find More Posts by Woodstock 1
Old Jul 09, 2012, 12:19 PM
Joined Dec 2005
If that is introduced and not deletable, then my radio will become a frisbee ...
Old Jul 09, 2012, 02:06 PM
Low altitude flyboy
MajorMal's Avatar
Minneapolis
Joined May 2010
I haven't checked if its exactly the same every time. Good Idea though. I read somewhere here that the error is different if you're not transmitting.
Old Jul 09, 2012, 03:00 PM
Joined Jan 2007
Yes, this is right. You can find pictures in one of my topic. There is comparison with my cellphone, when radio are transmitting or not.
By the way, I went through last few pages and people in this thread seems to be unhappy with FW updates, poor B-fly mix (using camber for FLAPS offset ?!?!) , but when I mentioned it in my thread, I was named really badly and got information that everything is excellent.
I am afraid, that we are going to have new Hitec's radio sooner than new FW with bugfixes.
Old Jul 09, 2012, 04:06 PM
Low altitude flyboy
MajorMal's Avatar
Minneapolis
Joined May 2010
I've been biting my tongue.
Old Jul 19, 2012, 07:03 AM
Joined Sep 2011
Is there a possibility that a variometer output could be provided based on height readings from the GPS module (this would require a simple software revision although it isn't certain how valuable the result would be). As in a full size glider the output could be used to provide an audio output (while trying to ensure this cannot be confused with other sounds).
Robert Grey is offline Find More Posts by Robert Grey
     DRIVE / FLY / SUPPORT
Question what's on your Christmas wish list ? brn-grose Alabama's Rocket City Renegades 26 Dec 11, 2009 10:58 PM
Discussion 2009 3DHS Wish List FlyCush 3D Flying 31 Oct 18, 2009 12:25 AM
Discussion Training Helicopter- wish list fpainter3 Electric Heli Talk 20 Oct 12, 2009 08:28 PM
Rave Phase 3 fan thread and future plane wish list :) SmoothCruizer Foamy EDFs 0 Feb 20, 2008 03:22 PM
Discussion Mamba Max ESC software wish list..... Marv829 Castle Creations 9 Jan 04, 2008 01:42 AM
