This thread is privately moderated by BRENDAN LUGO, who may elect to delete unwanted replies.
Old Nov 26, 2011, 02:06 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Chris Benndorf View Post
Hi,just got my Blue Sensor Stations and i'm measuring the main battery voltage now on all my helis. I would be really happy with my A9 but one thing is absolutely annoying: when i disconnect the helis battery it starts beeping and i cannot stop it - except by switching it off. Hitec: Please do something... ASAP! THX Chris
Already covered, please refer to "Battery Low Voltage Alarm"
AFHSS - Aurora & Spectra 2.4Ghz module - Warning Beeps
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers & Telemetry - FAQ & Undocumented Features
Alan T.
A.T. is offline Find More Posts by A.T.
Old Nov 27, 2011, 05:10 AM
Chris Benndorf is offline
Find More Posts by Chris Benndorf
Deutschland, RP, Altleiningen
Joined Jul 2011
Thanks, Alan, but i don't find a solution to my problem in there...
My Rex 600E has two batteries - one for RX (SPC, 2 cells) and one for flight (BlueSS, 6 cells). The alarm for the flight battery is set to 20.4 volts. The A9 should (and does) beep when reaching that limit. But when i disconnect the flight battery the A9 starts beeping too (every time!) and i am not able to stop that - except by reconnecting the battery or switching off the A9. The same thing happens with all my 6 cell helis but not with the 3 cell Rex 450.
What i'm asking for is a way to acknowledge the warning so the A9 stops beeping without switching it off. I would like to check the telemetry data after flight without risking to start the heli by accident.
Danke & Gre
Chris
Chris Benndorf is offline Find More Posts by Chris Benndorf
Old Nov 27, 2011, 10:45 AM
CSpaced is offline
Find More Posts by CSpaced
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
Danke & Gre
Chris
Another option is to ditch the seperate battery for your SPC port, and run a line from the ESC plug that plugs into the flight battery straight to your SPC port. You will then get your flight pack telemetry, and can set your alarm. I run this setup in my electric helis and it works great.
CSpaced is offline Find More Posts by CSpaced
Old Nov 27, 2011, 02:12 PM
Joined Jul 2011
Does not help! It would still be beeping after disconnecting the flight pack, like it does on my Atom 500 (6 cell directly to SPC, no extra RX battery). Same setup with 3 cells (T-Rex 450 Pro) does not beep after disconnecting.
Old Nov 30, 2011, 06:17 AM
DelTorres is offline
Find More Posts by DelTorres
Joined Nov 2011
I'd liked to see programmable warnings at turning on the transmitter.
Switch A = this position
Switch B = that position
-> Warning
DelTorres is offline Find More Posts by DelTorres
Old Dec 08, 2011, 03:32 AM
schnipa is offline
Find More Posts by schnipa
Joined May 2011
Alan T.
in your link it says:
"Voltage alarm may sound on Aurora when RX/Power battery is disconnected. This is because the telemetry cycles about 3 times/second, sometimes when you are unplugging the battery it will sense the voltage drop and the warning will kick in, but sometimes it won't because once you unplug the battery there is no signal going back to the TX. This is a hit and miss thing due to the way the system works."
this explains WHY it beeps, though it does not solve the problem.
or am I missing something?
why isn't it possible to turn off that beep e.g by touching the area of the screen where the voltage is displayed for, let's say, 3 seconds. as like resetting the counter!?
schnipa is offline Find More Posts by schnipa
Old Dec 15, 2011, 04:46 AM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
I thought there was a fix coming for the alarm when unplugging the main lipo. Eg. alarm silent button.
I'm still waiting Hitec.....
nac is offline Find More Posts by nac
Old Dec 21, 2011, 05:28 AM
skyrock is offline
Find More Posts by skyrock
The truth will prevail
skyrock's Avatar
Westbury, NY
Joined Nov 2009
Ok, my soiftware wish includes hardware as well.
I would like to have a channel update for the A9 expanding it to 14 channels. But same time Hitec would have to develop a 14 ch RX.....
Juergen
skyrock is offline Find More Posts by skyrock
Old Dec 22, 2011, 03:02 AM
lud95 is offline
Find More Posts by lud95
lud95's Avatar
Paris france
Joined Oct 2008
o yes, +14 !!!
lud95 is offline Find More Posts by lud95
Old Dec 29, 2011, 03:01 PM
Mike Gravelle is offline
Find More Posts by Mike Gravelle
Joined Oct 2007
Wish List
Hi
I finally found something that would be usefull with our transmitters : A , "note pad " We can keep out notes on battery type and capacity , in the radio . Even keep a cycleing history . I think this would be nice .
Michel
Mike Gravelle is offline Find More Posts by Mike Gravelle
Old Jan 01, 2012, 04:51 AM
Woita is offline
Find More Posts by Woita
Woita's Avatar
Joined Jan 2012
Rssi
RSSI - Received Signal Strength Indication (or at least lost packets, or both). It would be useful for long distance flying as well as for finding lost model...
(It would be a big competitive advantage!)
Woita is offline Find More Posts by Woita
Old Jan 06, 2012, 05:42 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
How about adding a simple Flaps -> Aile Reflex -> Elev Mix to the Acro choices. Essentially, this would be like BFly / CROW for Glid, except that Flap activation off a switch would drive it. This would be a GREAT mix for landing warbirds or any plane with high wing loading.
After a lot of work, I somehow got this to work via the Cambmix for one model, but was not able to duplicate for another. It would be nice to have a canned mix available.
TTRotary is offline Find More Posts by TTRotary
Old Jan 07, 2012, 09:29 AM
vlr is offline
vlr
Find More Posts by vlr
vlr
Joined Oct 2009
Electric Fuel Gauge
Im flying 4-5 electric powered A/Cs. Telemetry is very usefull especially during tuning powerpant etc. One Sensor station is enough in this case. What would be great (and is available with other 2,4GHz systems already) is "fuel gauge" computing consumed Ah with adjustable sound warning. This would push me to install sensors into all of my aircrafts. Has HITEC intention to introduce such feature into some nearest SW version?
vlr is offline Find More Posts by vlr
Old Jan 09, 2012, 11:15 PM
SLOPERDUDE is offline
Find More Posts by SLOPERDUDE
Joined Aug 2011
I don't want to start a separate thread for this- how about a rpm sensor for brushless motors? The kind that are already in use in other systems, that just compare the voltage zero-crossing on two motor phase wires. With all the electric systems now it seems odd there are speed/rpm sensors geared for helis and fuel planes...
If this has already been discussed I apologize, but a search revealed nothing on this.
SLOPERDUDE is offline Find More Posts by SLOPERDUDE
Old Jan 10, 2012, 04:28 AM
mijou is offline
Find More Posts by mijou
Česk republika
Joined Dec 2010
Hi.
I don't know if it is already here but some people from "rcmania.cz" describes problems with "stopwatch" in Aurora9.
1second in Aurora9 is not realy 1second. :-)
v 1.07
10min cyclus ---- aurora9 dislays 9:47
v 1.8
10min cyclus ---- Aurora9 (without transmitting) displays 8:42
10min cyclus ---- Aurora9 (with transmitting) displays 9:30
Can anybody check and fix this.
mijou
mijou is offline Find More Posts by mijou
Question what's on your Christmas wish list ? brn-grose Alabama's Rocket City Renegades 26 Dec 11, 2009 10:58 PM
Discussion 2009 3DHS Wish List FlyCush 3D Flying 31 Oct 18, 2009 12:25 AM
Discussion Training Helicopter- wish list fpainter3 Electric Heli Talk 20 Oct 12, 2009 08:28 PM
Rave Phase 3 fan thread and future plane wish list :) SmoothCruizer Foamy EDFs 0 Feb 20, 2008 03:22 PM
Discussion Mamba Max ESC software wish list..... Marv829 Castle Creations 9 Jan 04, 2008 01:42 AM
