This thread is privately moderated by BRENDAN LUGO, who may elect to delete unwanted replies.
Old Oct 16, 2011, 12:14 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Originally Posted by Nathan Schmoekel View Post
THAT'S EASY.....open up the radio and snip a wire to the beeper!!!
I suppose if you think you might want the beep back sometime, you could add a switch on the back of the case to turn it on-off with
True ... but then you would not hear the beep for the timer.
Like Kimi, I would like to have a silent TX. Other than the timer, all that beeping is annoying and unnecessary.
Lou is offline Find More Posts by Lou
Old Oct 21, 2011, 03:50 AM
schnipa is offline
Find More Posts by schnipa
Joined May 2011
so, what about the mah-counter? I am also extremely interested in such thing.
in fact it is not that hard to implement it in the software, cause all you need is the already available amp-sensor. by simply integrating those amp-values over time one gets the used mAh.
so, when will it be implemented in the software!?
schnipa is offline Find More Posts by schnipa
Old Oct 24, 2011, 08:23 AM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
That would so useful as many have pointed out. I just used the 200 amp pack for the first time yesterday. To be honest I did not have the ability to look down at the readings and only the voltage alert is useful and we already had that with 8s and below setups with the SPC port. You really can not practically get a temperature reading on a outrunner so only the ESC temp is useful out of the whole pack unless I bring a PC along or that voice system comes out.
I suppose you can setup a alert for over amping with setup. I run a ICE 100 in the setup I was testing so a alert above 100 might be useful
Enterprise7 is offline Find More Posts by Enterprise7
Old Nov 14, 2011, 05:55 AM
LiPoSly is offline
Find More Posts by LiPoSly
Joined Aug 2007
Regarding sounds: I would like to have all sounds configurable on/off. All people have different opinions to which sounds are annoyning / useful in different situation. Me for example hate the middle of the slider beep, the pronounced ratched feel is enough for me.
My girlfriend agrees...
LiPoSly is offline Find More Posts by LiPoSly
Old Nov 15, 2011, 02:51 PM
marcfern is offline
Find More Posts by marcfern
I'm a Hitec Fanboy
marcfern's Avatar
Ottawa, ON
Joined Jan 2005
As I don't see a spot for the hitec Spectra 2.4 Module Firmware wishlist, I will add it here (hope that's OK).
I would love if if you allowed user control (via firmware settings) of the RF Power from this Module.
My rational being, if I'm flying a micro model I don't need the wopping 100 mW of AFSS power, I am sure that only 10 mW would do it and save battery if not my cells! ha ha ha....Please let me know if this will be and likely future option (I'm looking to Spring of 2012) otherwise I will look at purchasing the XPS Module for the A9 which has RF signal strenght settings from 1mW to 100 mW.
marcfern is offline Find More Posts by marcfern
Old Nov 15, 2011, 04:52 PM
notruthless is offline
Find More Posts by notruthless
liv nvrtd
United States, NC, Salisbury
Joined Jun 2007
How about the ability to backup / load models using HPP-22 without being connected to the internet. Hitec's recent upgrade server outage prevented this as well as the normal upgrades.
notruthless is offline Find More Posts by notruthless
Old Nov 15, 2011, 04:57 PM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
++++++100000000000
HP-22 operational dependance on an internet connection SUCKS!!!!!
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Nov 15, 2011, 06:53 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
++++++100000000000
? As covered under the HPP-22 instructions and the FAQ, provison has always been available for off line data transfer. Refer attached jpg
Alan T.
A.T. is offline Find More Posts by A.T.
Old Nov 15, 2011, 08:03 PM
liv nvrtd
Joined Jun 2007
A.T.,
I appreciate your paying attention to this, but during the period that the server was down, this option was not functioning. It was not until the server was restored that I was able to upload a new model to the transmitter.
Alan T.
Old Nov 15, 2011, 08:32 PM
A.T. is offline
Joined Aug 2002
Aurora A9 - Data Transfer to and from PC or Laptop
A.T.,
Demonstrated many times past two+ years using laptop and no internet.
Please try again whilst refering to attached sequence.
Aurora A9 - Data Transfer to and from PC or Laptop - Pictorial (7 screenshots taken without internet connection.)
Alan T.
Old Nov 15, 2011, 10:54 PM
aa78 is offline
Find More Posts by aa78
Fast and low...
aa78's Avatar
Joined Apr 2009
I would like the convenience of backing up all models in A9 memory in one go instead of the current tedious process of selecting each model and saving it individually.
aa78 is offline Find More Posts by aa78
Old Nov 24, 2011, 08:50 PM
bingo17 is offline
Find More Posts by bingo17
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
Hitec,
Any update on when a software update with some new features will be released?
bingo17 is offline Find More Posts by bingo17
Old Nov 25, 2011, 12:51 AM
Dan.Cummins is offline
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
A9 Sailplane Wishlist
For sailplane specific wishlist for the A9 software, I have started a separate thread....
http://www.rcgroups.com/forums/showt...2#post19968186
Dan.Cummins is offline Find More Posts by Dan.Cummins
Old Nov 25, 2011, 12:10 PM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Moved to:
fcbflyer is offline Find More Posts by fcbflyer
Old Nov 26, 2011, 04:42 AM
Chris Benndorf is offline
Find More Posts by Chris Benndorf
Deutschland, RP, Altleiningen
Joined Jul 2011
Hi,
just got my Blue Sensor Stations and i'm measuring the main battery voltage now on all my helis. I would be really happy with my A9 but one thing is absolutely annoying: when i disconnect the helis battery it starts beeping and i cannot stop it - except by switching it off.
Hitec: Please do something... ASAP!
THX
Chris
Chris Benndorf is offline Find More Posts by Chris Benndorf
Question what's on your Christmas wish list ? brn-grose Alabama's Rocket City Renegades 26 Dec 11, 2009 10:58 PM
Discussion 2009 3DHS Wish List FlyCush 3D Flying 31 Oct 18, 2009 12:25 AM
Discussion Training Helicopter- wish list fpainter3 Electric Heli Talk 20 Oct 12, 2009 08:28 PM
Rave Phase 3 fan thread and future plane wish list :) SmoothCruizer Foamy EDFs 0 Feb 20, 2008 03:22 PM
Discussion Mamba Max ESC software wish list..... Marv829 Castle Creations 9 Jan 04, 2008 01:42 AM
