Old Aug 18, 2011, 11:53 AM
LowWatts is offline
Find More Posts by LowWatts
Seattle, WA
Joined Mar 2006
Originally Posted by Machineman View Post
Hi,
Can you please make the Throtle switch available in the 1) Changing Flight Conditions and 2)Programable mixers, switch menu. It is currently in the Timer switch menu so the function currently exists.
For Gliders (Landing) and Electrics (Motor) it is the ONE BIG FEATURE that is currently missing and would be a huge benefit to all that fly them.
Other than this feature the A9 is sensational for glider/electric competition and I love the radio.
Thanks Hitec.
Marcus
Previously mentioned as stick switches and I TOTALLY AGREE.
LowWatts is offline Find More Posts by LowWatts
Old Aug 18, 2011, 02:18 PM
LowWatts is offline
Seattle, WA
Joined Mar 2006
Ignore. Unsubscribing.
Old Aug 20, 2011, 12:07 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
HPP 22 Software requests
Ok, I don't think I am at the most recent revs on everything, but I am pretty close. However, if this stuff is there, just let me know, don't shoot me for asking
1. When you enter the firmware update mode for the TX, it should ask you if you want to make a backup of all settings on the TX first. It should be an option and ask yes or no. If yes is selected, then ALL data on the A9 is then backed up to the PC. Also an option for the save location should be opened so you can chose the proper folder.
2. When you bring up the HPP22 application, an option to view all models would be nice. Once you are in the view all models option, you should be able to make modifications to those models.
a. Change the location of the model. This would allow you to move models from say location 2 to location 16 in order to group like models or however you want them listed.
b. Delete model
c. Rename model
D. Copy model
3. Restore all settings from PC. This over writes all data currently on the A9 and loads the data you have backed up and/or modified from option #2 with what you currently have saved. Yes I know the ramifications of offering this option, but it should be there.
4. Backup All Settings to PC. Just the opposite of #3 above. Stores everything stored on the A9 and makes a backup to the PC in one step.
This one is for the A9. As has been suggested many times from other users, please setup some way to have the low voltage warning tone stop without shutting off the TX. I have to reset my thresholds if I am testing out say a bad servo/servo extension in the shop and want to use a 3S test lipo when the model uses something like a 5S normally. When I land and disconnect the lipo after flight, it is not that big of a deal, but it really sucks to have to reset the values when just testing in the shop.
Diggs
Diggs is offline Find More Posts by Diggs
Old Aug 20, 2011, 02:18 PM
jetigm is offline
Find More Posts by jetigm
Joined Aug 2009
Sometimes when I turn on the TX, I see backlighted green display without any text and all, the A9 donít starts. I had this case three times already and I canít simulate this problem. One time this happened when I quickly turn off and on the TX, and other time A9 has been turned off approx. 30 min. then I turn it on and the same problem happened, so this problem in not caused by quick turning off and on.
The THRO Lock function doesn't work when I turn on the TX and apply transmitting. My example: I put the THRO Lock function to E switch. When I turn on the TX and switch E in position when the THRO Lock should be activated, after applying the transmitting the throttle is unlocked. Then I put E switch in preprogrammed throttle unlock position (thr. works), then put him back to lock the throttle and now it works. It is in the Glider with motor program.
Flight phases not available for Landing mix.
Would be nice to fix it.
jetigm is offline Find More Posts by jetigm
Old Aug 20, 2011, 06:33 PM
guyst is online now
Find More Posts by guyst
guyst's Avatar
Joined Feb 2010
Is Corona 2.4 module can fit the Aurora 9?
guyst is online now Find More Posts by guyst
Old Aug 21, 2011, 05:34 AM
notruthless is online now
Find More Posts by notruthless
liv nvrtd
United States, NC, Salisbury
Joined Jun 2007
Sounds like this is one that should be posted to a Corona wish list.
notruthless is online now Find More Posts by notruthless
Old Aug 28, 2011, 03:00 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by jetigm View Post
Sometimes when I turn on the TX, I see backlighted green display without any text and all, the A9 don’t starts. I had this case three times already and I can’t simulate this problem. One time this happened when I quickly turn off and on the TX, and other time A9 has been turned off approx. 30 min. then I turn it on and the same problem happened, so this problem in not caused by quick turning off and on.
The THRO Lock function doesn't work when I turn on the TX and apply transmitting. My example: I put the THRO Lock function to E switch. When I turn on the TX and switch E in position when the THRO Lock should be activated, after applying the transmitting the throttle is unlocked. Then I put E switch in preprogrammed throttle unlock position (thr. works), then put him back to lock the throttle and now it works. It is in the Glider with motor program. Flight phases not available for Landing mix.
1. What version firmware? does not appear to have been reported after V1.07.
Was occasionally seen when TX turned off/on to quickly (was also possible if turned off after a significant program change without
returning to main menu first. Remove battery, cycle switch, re-insert battery).
2.Aurora 9 - Throttle Lock (Hold) & Transmit Yes-No Features & Use. - How to use Icon and/or Switch method
(operates when in transmit mode only)
- request for active when TX powered on is listed.
3. ""Flight phases" not available for Landing mix"? Flight Phase in Evo Glider Tutorial is "Flight Conditions" under Aurora?
Aurora 9 - Flap (Landing) Mix
Aurora 9 - Sailplane_Glider Flap Mixing - assign flap channel to a 3 position switch First (refer posts 208,209 & 210).
Alan T.
A.T. is offline Find More Posts by A.T.
Old Aug 29, 2011, 03:51 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
I've had it where I get a blank green screen upon power up and I've only ever used v1.08. It does a single beep and thats it. A power cycle off, wait a sec and on again has always recovered it - I've never had to resort to removing the battery.
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Aug 29, 2011, 08:36 AM
Hugh P is offline
Find More Posts by Hugh P
Quincy IL
Joined Jul 2006
I have had two instances of the blank screen boot up. First with 1.07 so I updated to 1.08 and have had one more instance.
In both cases a power down, wait 10 sec and power up fixed the problem.
Otherwise system is in a Radian Pro that gets flown quite a bit and have no airborne problems.
Hugh P is offline Find More Posts by Hugh P
Old Sep 02, 2011, 12:03 PM
rgil is offline
Find More Posts by rgil
Brasil, MT, Sorriso
Joined Aug 2011
Hitec receptors could develop more channels and upgrade the A9 to work with more channels. 12 channels would be already a good size, i would say goodbye to match boxes.
rgil is offline Find More Posts by rgil
Old Sep 04, 2011, 11:18 AM
d68 is offline
d68
Find More Posts by d68
d68
Netherlands, NB, Breda
Joined Jun 2011
I don't know if Hitec also reads this thread but i have a suggestion:
Hitec, why don't you opensource the Aurora 9? Its sounds silly but i think this is 2011+ meaning:
- More developers creating better quality software (5 persons versus 250?), see the linux kernel. Hitec can still be the moderator controlling updates.
- You will attact more people, more attention and thats better for business because Hitec's main goal is surviving by selling & quality
-Afraid of bricked A9's? Modern uC (and sure the A9 contains one) can always be updated some way.
-You will see solution never thought about it: better HPP-22, wireless telemetry on Android/Ipad, fight recording, ...
Think about is, its radical but its what Cisco is already doing for years. Get ahead of your competitors.
See this thread how model guys love to experiment: http://www.rcgroups.com/forums/showthread.php?t=1474513
Regards,
Diederich
d68 is offline Find More Posts by d68
Old Sep 06, 2011, 09:39 AM
Machineman is offline
Find More Posts by Machineman
Aussie F3K Team
Melbourne, Australia
Joined Jun 2008
Aileron differential with Flight Condition change
Hi,
I use 6 Flight Conditions and if I change the differential in one Flight Condition it changes it in all the Flight Conditions at the same time. It does this even when the C is changed to S (it is like the S does not work).
I want to be able to use the 'Rate' change feature to change the Aileron differential independently in each Flight Condition.
Marcus
Machineman is offline Find More Posts by Machineman
Old Sep 16, 2011, 09:34 AM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Hi,
Marcus
HELLZ YES That would make my life easier too!!!! What was the logic behind the rate function trumping the "S" any way??? Or was that just an over-site??
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Sep 16, 2011, 09:41 AM
Joined Apr 2007
There is also some weirdness going on with V-tail mixing.... when mixing something to elevator, for instance, one sometimes has to also create a mix to the rudder channel to get both tail surfaces to move with the mix.
The Radio should "KNOW" that when a V-tail is in use that elevator or rudder functions are shared between two channels.....
If I want to mix something to the elevator channel and the model is defined as a V-tail the radio should automatically recognize that two servo channels are in play.
Old Sep 16, 2011, 05:08 PM
Markus05 is offline
Find More Posts by Markus05
Joined Nov 2005
Receiver Battery is not on display anymore since 1.08.1
Why does the Display dont show me the voltage of the receiver anymore?
Software A9: 1.08.1
And optima 7: 2.xx
Receiver Battery Low Voltage Warning Function: You can select the Low Battery Warning Alarm activation level.
Is it not working ?
Markus
Markus05 is offline Find More Posts by Markus05
Question what's on your Christmas wish list ? brn-grose Alabama's Rocket City Renegades 26 Dec 11, 2009 10:58 PM
Discussion 2009 3DHS Wish List FlyCush 3D Flying 31 Oct 18, 2009 12:25 AM
Discussion Training Helicopter- wish list fpainter3 Electric Heli Talk 20 Oct 12, 2009 08:28 PM
Rave Phase 3 fan thread and future plane wish list :) SmoothCruizer Foamy EDFs 0 Feb 20, 2008 03:22 PM
Discussion Mamba Max ESC software wish list..... Marv829 Castle Creations 9 Jan 04, 2008 01:42 AM
