This thread is privately moderated by BRENDAN LUGO, who may elect to delete unwanted replies.
Old Jun 28, 2011, 10:42 PM
razerunner is offline
Find More Posts by razerunner
bladereaper
razerunner's Avatar
Joined Jul 2007
i wish you guys put a menu so you can see your range test working and showing the % of of signal
razerunner is offline Find More Posts by razerunner
Old Jun 29, 2011, 04:23 PM
ZeekWorld is offline
Find More Posts by ZeekWorld
ZeekWorld's Avatar
United States, CO, Avon
Originally Posted by sharkcom View Post
I would prefer an option to disable beep-minute timer.
I would very much like the Vario module
+1 to be able to Disable beep-minute Timer. It's confusing, I am always thinking something is running out of juice!
ZeekWorld is offline Find More Posts by ZeekWorld
Old Jul 01, 2011, 12:39 PM
vettebob is offline
Find More Posts by vettebob
Yes, it will go verticle
Kansas City Mo
Joined Apr 2004
+ 1 for a low voltage beeper reset after activation on main screen I hate it beeping and beeping after I have disconnected the battery.
+ 1 for signal strenth meter for range tests
+ 1 for being able to turn of the minute beep while leaving the end of time beep active. Thanks Bob
vettebob is offline Find More Posts by vettebob
Old Jul 01, 2011, 12:46 PM
aa78 is offline
Find More Posts by aa78
Fast and low...
aa78's Avatar
Joined Apr 2009
1 - RSSI/Signal strength
2 - Selective trainer mode channel passthrough for all channels. Currently it is only implemented for the 4 basic channels. This is inadequate for a radio of this level and rather limiting for trainer and other uses.
3 - Option to disable beeping for a certain amount of time for voltage alarm after it starts beeping.
4 - Option to disable RF transmission/module by pressing and confirming with the AFHSS icon.
5 - Options to enter scan mode and binding mode from the System menu.
aa78 is offline Find More Posts by aa78
Old Jul 02, 2011, 11:56 AM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
How about breaking up this thread into , heli, motor and Sailplane? It is very confusing looking for info in this thread at this point.
Is there a time frame for a new software update?
fcbflyer is offline Find More Posts by fcbflyer
Old Jul 02, 2011, 11:18 PM
jackosmeister is online now
Find More Posts by jackosmeister
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
How about be able to assign different voltage alarms to a switch.
Be handy if one wanted to run a variety of cell count packs, ie switching between 3 and 4S in the same model. You could also assign the switch to turn off the voltage alarm if ya wanted.
jackosmeister is online now Find More Posts by jackosmeister
Old Jul 04, 2011, 02:40 PM
donato.jun is offline
Find More Posts by donato.jun
Joined Mar 2011
How about composite PPM? Some Flybarless system, like Skookum 720, BeastX e Mikado V-BAR support PPM receiver.
Maybe a opcional firmware upgrade for Optima 7 to provide de PPM Who needs S.BUS?
donato.jun is offline Find More Posts by donato.jun
Old Jul 04, 2011, 04:42 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Would it be possible to add Butterfly to the ACRO model type? I tried to help a bud with his powered glider at the field yesterday and after 2 hours of trying to get it setup, we failed. I just wanted to enable it to RS and we just couldn't do it. Under Acro, the throttle is default on J3 ch 3, on glider it isn't and also in glider mode the butterfly option appears to be tied to the throttle stick and I can't find an option to move it.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jul 07, 2011, 10:41 AM
miche is offline
Find More Posts by miche
miche's Avatar
Joined Oct 2008
+1. The setup for my hotliner is in ACRO model, and the crow is controled by a switch on-off(only one deflection).
miche is offline Find More Posts by miche
Old Jul 08, 2011, 07:19 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
Diggs
Use the CAMB MIX assigned to RS.
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Jul 10, 2011, 08:48 AM
serkans is offline
Find More Posts by serkans
Joined Jul 2011
New to Aurora9
Hello Everyone,
I am a Scale Heli lover with a raptor 90 with MD500 fuse and a 90 engine Hirobo TOW Cobra. I am a new user for Aurora9,switched from Futaba 8fg.At the moment,i am trying to get familiar with my new TX.
One question if anyone please to answer:
I want to assign the throttle servo (ONLY THROTTLE SERVO,NOT PITCH) to one of the switches like LT,CT or RT to increase or decrease the throttle(and the head rev.),independent from pitch. It was done from FUNCTION menu of futaba and i was assigning one of the knobs to throttle servo...
I hope i explained well what i am trying to do with my mid-level english...
Waiting for your kind replies,
Serkan S.
serkans is offline Find More Posts by serkans
Old Jul 10, 2011, 10:13 AM
Widelec is online now
Find More Posts by Widelec
Simple is the best
Widelec's Avatar
Joined May 2011
Yes.
I need too ppm sum for multirotor (hexa, Y6) heli
Widelec is online now Find More Posts by Widelec
Latest blog entry: Asterix Brushless Gimbal v2r
Old Jul 10, 2011, 10:21 AM
Chris Benndorf is offline
Find More Posts by Chris Benndorf
Deutschland, RP, Altleiningen
Joined Jul 2011
After a few days with my new A9 my two most wanted additions or changes are:
- numerical values in the servo monitor
- placement of the SPC voltage on the left or right side of the display - not in the middle where the neck strap hides it.
Greetings from Germany
Chris
Chris Benndorf is offline Find More Posts by Chris Benndorf
Old Jul 10, 2011, 11:05 AM
LowWatts is offline
Find More Posts by LowWatts
Seattle, WA
Joined Mar 2006
Originally Posted by serkans View Post
Hello Everyone,
Serkan S.
Your question may be more likely to get an answer in this thread: http://www.rcgroups.com/forums/showt...3#post18721374
This is a wish list thread for things you think they should incorporate via firmware update into the A9.
LowWatts is offline Find More Posts by LowWatts
Old Jul 10, 2011, 11:24 AM
LowWatts is offline
Seattle, WA
Joined Mar 2006
Hello Everyone,
Serkan S.
I think what your looking for is this.
Select T.Curve, then select a switch.
At the bottom of that screen you will see an Adjust Function.
Select Adjust Function and then select Set.
In the next screen, it should show two pages, (1/2) and below to the left Switch : NULL. In this screen again select (SEL.) and you will be able to pick your trimmer. Keep in mind that there is a second page.
More helpful A9 owners on the discussion thread I previously listed.
Question what's on your Christmas wish list ? brn-grose Alabama's Rocket City Renegades 26 Dec 11, 2009 11:58 PM
Discussion 2009 3DHS Wish List FlyCush 3D Flying 31 Oct 18, 2009 01:25 AM
Discussion Training Helicopter- wish list fpainter3 Electric Heli Talk 20 Oct 12, 2009 09:28 PM
Rave Phase 3 fan thread and future plane wish list :) SmoothCruizer Foamy EDFs 0 Feb 20, 2008 04:22 PM
Discussion Mamba Max ESC software wish list..... Marv829 Castle Creations 9 Jan 04, 2008 02:42 AM
