This thread is privately moderated by BRENDAN LUGO, who may elect to delete unwanted replies.
Old Jun 19, 2010, 08:11 AM
warhawk.cz is offline
Find More Posts by warhawk.cz
Česká republika, Hlavní město Praha, Praha
Joined Jan 2007
Hello,
I must admit that it's an interesting thought ;-)
warhawk.cz is offline Find More Posts by warhawk.cz
Old Jun 19, 2010, 10:05 PM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
Heli Swash functions- 120 degree swash. Both helis I have set up so far have a reversed swash layout where the elevator servo is in the front. So... how about the ability to reverse the layout in the menu.
JoeR is offline Find More Posts by JoeR
Old Jun 19, 2010, 11:24 PM
planesinsane is offline
Find More Posts by planesinsane
United States, AZ, Gilbert
Joined Aug 2003
Originally Posted by paderflying View Post
Feature request for wish list: Make the timer triggering dependent on the flight mode.
bEst,
Holger
No need to wish that, the A9 does it. I never liked the throttle activated timer so I did something a bit different. I have a flight mode called START/LND which has priority over all my other flight modes. When I switch to this mode the timer turns OFF. So in all other modes the timer is ON. When I setup for landing I set the START/LND switch the timer turns off, my rudder increases, my elevator increases, my downline mixes turnoff, my throttle drops down and presto, perfect landing
planesinsane is offline Find More Posts by planesinsane
Old Jun 21, 2010, 10:13 PM
exciter900rr is offline
Find More Posts by exciter900rr
Kenny- Really!
exciter900rr's Avatar
USA, CA, Cathedral City
Joined Jul 2007
out of calibration due to climate change. Get ready to search for the step by step directions on how to re-calibrate it yourself in this thread approx 50+ pages back, or send it back in so they can re-calibrate it. The same hapened to mine, and I did it myself with good results. I would tell you how to do it, but I have since forgotten.
Originally Posted by warhawk.cz View Post
Hello Mike,
We have two Auroras at our home - me and my father. I could have a lot of comments, but I am still learning "how to" and waiting for new firmware release.
But anyway, My father has a earlier version of Aurora with side sliders without central notch. I know, there were a lot of comments forcing you guys "make notch for us".
My aurora is a newer one and has a central notch but not in the center !!
It is weird, because it seems to be in the center mechanically (at least optically), but not electrically (offset in A/D conversion ?). Beep to indicate the center is not in the mechanical center (where notch is) and this issue can be perfectly seen for example in programmable mixes. (Imagine situation when you using slider like this with CAMBMIX)
Can you explain this ? If you're interested, I can take pictures tomorrow.
Is there any way how to get both sliders without central notch please ?
Thank you
Jiri Panacek
Czech Republic
Europe
exciter900rr is offline Find More Posts by exciter900rr
Old Jun 21, 2010, 10:22 PM
Joined Aug 2003
It must be a different thread because this one is only 18 pages long and is supposed to be dedicated to the 'Wish List'.
Old Jun 22, 2010, 12:09 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Try this thread.
http://www.rcgroups.com/forums/showthread.php?t=996037
Originally Posted by exciter900rr View Post
out of calibration due to climate change.........
Dang it, didn't Al Gore warn us about this?? Sorry, couldn't resist.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jun 22, 2010, 02:18 AM
Kenny- Really!
Joined Jul 2007
Originally Posted by diggs View Post
try this thread.
dang it, didn't al gore warn us about this?? :d Sorry, couldn't resist.
Diggs
lol!
Old Jun 23, 2010, 12:08 PM
amiro is offline
Find More Posts by amiro
Joined Jul 2009
Update release time?
Originally Posted by Diggs View Post
Per Mike, it will be implemented in firmware V1.07 which is due out very soon.
Diggs
Any idea when the 1.07 will be out?
Also would like to know when the telemetry gear will be available and the Spectra Pro module?
Mario
amiro is offline Find More Posts by amiro
Old Jun 23, 2010, 11:59 PM
Kenny- Really!
Joined Jul 2007
SOFTWARE/HARDWARE TELEMETRY suggestion-
Pitot tube for actual airspeed, rather than gps speed- groundspeed doesn't do much for aircraft. combine with software for stall threshold adjustment, and warning/alarm on the tx and you'll have a winner! OR
strike a deal with "how fast how high" to PNP with their tested and proven hdwr.
Old Jun 24, 2010, 02:11 AM
Jambock is offline
Find More Posts by Jambock
Legen -- wait for it -- Dary!
Jambock's Avatar
São Paulo, SP, Brasil
Joined Sep 2003
My suggestion:
  • Simple improvement in Exit button: When click and hold on exit button on few seconds, leave to main menu. Today, if we are on a deep sub-menu, we have to click in the exit button several times.
Regards
Roberto Besser
Jambock is offline Find More Posts by Jambock
Old Jun 28, 2010, 11:58 AM
Jambock is offline
Jambock's Avatar
Joined Sep 2003
Another suggestion:
  • Add rudder adjustment on LAUNCH MIX (glider): Today is possible active the rudder using P.MIX together LAUNCH MIX but the auto-release not works with P.MIX.
Old Jun 29, 2010, 05:34 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Amend Throttle Lock to include any Aux Channels P-Mixed 100% with Throttle.
Throttle Lock Icon locks "throttle" only, does not presently include any other engines/motors linked via PMix to enable separate trims. (Or add menu to allow association with selected other channels).
Twin EP Motor set up with independant trims
A.T.
A.T. is offline Find More Posts by A.T.
Old Jun 29, 2010, 05:45 AM
jackosmeister is online now
Find More Posts by jackosmeister
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Yup A.T , would need to be selectably associated with stuff. I set up p-mix's that mix flaperons down on lower throttle settings on some pylon racers, having to unplug the esc to set the rates up and test that its working correctly would be PITA.
jackosmeister is online now Find More Posts by jackosmeister
Old Jul 03, 2010, 12:16 PM
Jevgeniy is offline
Find More Posts by Jevgeniy
Jevgeniy's Avatar
Joined Apr 2009
I would like to see:
Virtual channels wtih assignable swithces, sliders.
Ability to make separate EPA and Subtrims in conditions.
Jevgeniy is offline Find More Posts by Jevgeniy
Old Jul 08, 2010, 03:58 AM
Jevgeniy is offline
Jevgeniy's Avatar
Joined Apr 2009
EPA should limit P.mixes, as it is real problem in some aplications with many radios.
Question what's on your Christmas wish list ? brn-grose Alabama's Rocket City Renegades 26 Dec 11, 2009 11:58 PM
Discussion 2009 3DHS Wish List FlyCush 3D Flying 31 Oct 18, 2009 01:25 AM
Discussion Training Helicopter- wish list fpainter3 Electric Heli Talk 20 Oct 12, 2009 09:28 PM
Rave Phase 3 fan thread and future plane wish list :) SmoothCruizer Foamy EDFs 0 Feb 20, 2008 04:22 PM
Discussion Mamba Max ESC software wish list..... Marv829 Castle Creations 9 Jan 04, 2008 02:42 AM
