Old Dec 17, 2009, 05:36 AM
sid69 is offline
Find More Posts by sid69
INdia
Joined Mar 2009
Any powerful motor then Axi 2820/10 class
Hi ,
I have AXI 2820/10 setup on my Custom UAV , spinning 10X5 APC-E prop.. Generates 1.7 Kg of static thrust..consumes about 33A at full power..AUW is 2.5 Kg. I am using hand launch and belly landing.. I am finding static thrust of the setup on the Edge being hand launched....If I use 10X6 or 10X7 is consumes 3 to 5 amps more but thrust increases only about 100 Gms..Being a pusher I have a limitation of using 10 Dia prop..
Is there any better power plant setup ? Has anyone tried ..? Above is teh Optimum thrust against power consumption I could manage.
Inputs are highly appreciated..
SID
sid69 is offline Find More Posts by sid69
Old Dec 17, 2009, 04:50 PM
jglenn is offline
Find More Posts by jglenn
Ohio
Joined Nov 2003
I love my AxiGold, but if you have even more money, check these, supposed to
be utterly amazing motors:
http://www.neumotors.com/Site/Welcome.html
jglenn is offline Find More Posts by jglenn
Old Dec 17, 2009, 05:41 PM
Air Head is offline
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
Try the Power Systems Thread
Hello Sid
The Power Systems Thread gets a lot of activity from some very knowledgeable people. I second the Neu suggestion. I would also look at some of the Scorpion and Plettenberg...and of course Aveox.
Try your question in the Power Systems Thread and I am sure there will be a lot of help sent your way.
Do you have any pictures of your UAV ??? Just kidding....Mounting the rudder today and should be ready to snap some for you in the next few days. Almost there...
Good luck
Rick
Air Head is offline Find More Posts by Air Head
Old Dec 17, 2009, 09:11 PM
sid69 is offline
INdia
Joined Mar 2009
THanks Jglenn,
WIll have a look.. Thanks for the link..
@ Rick.. I am referring my wooden prototype.. You already have those pictures. Finalizing AVionics , firmware and planning to do Range tests as soon as possible. Thanks for your help anyway..I am glad things are getting there..I hope we will have test flight by Christmas perhaps.
Sid
Old Dec 18, 2009, 11:49 AM
Air Head is offline
Joined Jan 2005
Hello Sid..I received some information from Maxon
"Maxon has some very high efficiency / power per unit volume brushless motors.
Please call me so we can further discuss your particular requirements for this application."
I need to give them a call, they say they have something sutiable.
I am not sure how to specifiy the motor yet though. I think I need to get some test flights done first.
Ill keep you posted
Rick
Old Dec 28, 2009, 07:16 PM
Air Head is offline
Joined Jan 2005
Finally Finished
Here it is put together
Old Dec 30, 2009, 04:04 PM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
Hi Air Head,
Have you documented your build anywere. I am looking to scratch build a fpv or uav air frame and like your design. Just wondering on wingspan. overall length, contruction methods. Thanks
vertcnc is offline Find More Posts by vertcnc
Old Jan 03, 2010, 08:24 AM
Air Head is offline
Joined Jan 2005
vertcnc
No building details, Its nothing special though except it all snaps together without any tools. This is a prototype and the final version will have some changes.
72" Wing Span
48" Long
3000 Grams
Off to do a test flight today, hope it flys!
Ill post a flight report.
Rick
Question Any AXI 2820-10 equivalent motor? rkhoo Power Systems 2 Jul 08, 2012 03:10 AM
Question motor input axi AXI 2820/8 or 2826/8 pval3 Power Systems 3 Dec 19, 2009 06:21 PM
Help! Need some help with an axi 2820/10 neonbutterfly Power Systems 4 Nov 16, 2009 09:39 PM
For Sale Axi 2820/10 w/ Jeti Advance 40 w/bec new cycle1racing Aircraft - Electric - Power Systems (FS/W) 2 Nov 12, 2009 04:23 PM
Sold AXI Gold 2820/10 $45 Wave Glider Aircraft - Electric - Power Systems (FS/W) 2 Sep 30, 2009 06:07 PM
