Old Jun 19, 2001, 04:46 PM
spy0o7 is offline
Find More Posts by spy0o7
CharlieR
bay area, california
Joined Nov 2000
Silly Question: Control Throws?
Is this what angle you elvator or elevons are at in neutral position?
thanks
spy0o7 is offline Find More Posts by spy0o7
Old Jun 19, 2001, 05:48 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Control throw refers to the amount the surface moves from the neutral position...
This is a variable dependent on the use the plane will have.
Sparky Paul http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jun 19, 2001, 10:29 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
The throw is normally measured in mm at the bit of the control surface that is furthest from the hinge. So for an elevator, you may see a recommendation like 4mm up and 3mm down.
Throws are not nrmally measured in degrees because of the difficulty of measuring them.
DaveSawers is offline Find More Posts by DaveSawers
Old Jun 19, 2001, 11:14 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
The only silly question is the one you don't ask!
After all, none of the model aircraft terms are coded into the genes!
Dave
DaveW is offline Find More Posts by DaveW
Question E.P.A. Adjustment (Control Throws) Question. Ramen Radios 7 Jul 12, 2007 12:25 PM
A question about control throws. citabria Parkflyers 3 Nov 14, 2002 07:27 PM
Adjusting control throws ? John E Beginner Training Area (Aircraft-Electric) 8 Jun 22, 2001 07:52 AM
Adrenalin 400 control throws. Erik Johansson High Performance 1 Jun 20, 2001 09:17 AM
Speedy control throws? Bill72pa High Performance 3 Jun 12, 2001 04:38 PM
