Old Aug 26, 2010, 01:58 PM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
My First (practical) Arduino Device
sonicj is offline Find More Posts by sonicj
Old Aug 27, 2010, 01:26 PM
sim_io is offline
Find More Posts by sim_io
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
Originally Posted by theothercliff View Post
Transmitter battery voltage is a factor. You will get some added range if you get a 3 cell (11.1V-12.6V) Lipo for your transmitter. You can expect maybe 2 extra volts from a Lipo pack. Lipo packs speced out for RC transmitter use (shape, size, connector) are becoming common. Their power on time between charges is at least 4 times as long as a brand new nicad pack, although you ought to take the battery pack access cover off and charge it through the balance connector when you charge it once a month.
Cliff
Now if I get my Futaba 9c and replace its nicad pack with a lipo should the voltage increase do any damage to the radio?
sim_io is offline Find More Posts by sim_io
Old Aug 27, 2010, 02:00 PM
sverlander is offline
Find More Posts by sverlander
Sam in Virginia
sverlander's Avatar
Hampton Virginia
Joined Jul 2005
I have been using a 3 cell lipo in my 9C for 3 years now with no problems. It's a Lightning Power 2650mah 3cell rated at 4C and with a full charge I can run the transmitter for 7 to 8 hours, I charge it when it gets down to 11 volts but I could run it lower. I'll never go back to ni-cads.
sverlander is offline Find More Posts by sverlander
Old Aug 27, 2010, 07:22 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Do you still charge it with the stock charger or a lipo charger? And where did you get it? My 9C nicad is getting iffy, low run times.
Derek_S is offline Find More Posts by Derek_S
Old Aug 27, 2010, 07:37 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Never charge a LiPo with anything but a LiPo charger. I've been running LiPo's in my Tx for years with no problems. I do not charge the LiPo through the Tx charge port. I always disconnect the LiPo from the Tx and charge directly from my LiPo charger. There may be no need to do it this way, but it just doesn't sit right with me to charge a LiPo though the radio's circuitry.
Vantasstic is offline Find More Posts by Vantasstic
Old Aug 27, 2010, 08:22 PM
Sam in Virginia
sverlander's Avatar
Hampton Virginia
Joined Jul 2005
I got mine at Helihobby. They still have them on their site, PART#LP-B0106 $49.99 and are plug and play, They already have the correct connector for the radio.
http://helihobby.com/html/batteries.html
You can use any 3 cell lipo as long as it fits in the battery compartment and NEVER charge a lipo with anything but a lipo charger. I leave the lipo in the radio but take the back cover off and charge it with the balancing tap but I sometimes use my Thunder power 1010c charger so I replaced the Spektrum plug on the battery with a deans and charge though it and the charger monitors the cells though the balance plug.
Old Sep 02, 2010, 09:32 AM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
My 2nd V antenna, each one i make looks better than the last...
badlands is offline Find More Posts by badlands
Old Sep 02, 2010, 09:53 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That's a good looking antenna. Very professional looking... better than mine
IBCrazy is online now Find More Posts by IBCrazy
Old Sep 02, 2010, 10:08 AM
badlands is offline
badlands's Avatar
Joined Mar 2010
Thx Alex, just having trouble finding a good location for it on my Stryker...
Martin
Old Sep 02, 2010, 06:47 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Martin
I'd like to see some pics of your set up on the Stryker when you get it all sorted....if it's not too much trouble.
2500GENE is offline Find More Posts by 2500GENE
Old Sep 04, 2010, 12:57 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I built this and stuck it in Depron to hold it... does it look ok?
jasmine2501 is offline Find More Posts by jasmine2501
Old Sep 04, 2010, 01:09 AM
AdamChicago is online now
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Newbie FPV base station question...how do I connect the power for everything?
The 2 receivers and diversity station each need power as well as the Fat Shark goggles...so that's 4 things requiring 12volt power. I have one 3s 2200 battery, so how do I make the connection between everything?? ...is it as simple as connecting all of the positives and then all of the negatives and then just plugging it into the battery? ...that would be way too simple, so do I need some kind of circuit board or voltage regulator...please help!!!
Thank youl
AdamChicago is online now Find More Posts by AdamChicago
Old Sep 04, 2010, 03:43 AM
ldriess is offline
Find More Posts by ldriess
Australia, VIC, Wonga Park
Joined Jul 2010
Inverted Vee Tx with Moxon Rx
I have the HK 200mW 900MHz system and I built the antennas from IBCrazy's threads http://www.rcgroups.com/forums/showthread.php?t=1266148 and they have been working well. I haven't tested the full range yet but they definitely work better than the stock HK antennas (less interference and static).
I'm using a 7" cheapy LCD with a cardboard box over it, but it's still pretty hard to see.
I've posted some photo's of my setup for your amusement.
ldriess is offline Find More Posts by ldriess
Old Sep 04, 2010, 11:39 AM
Rocket Programmer
Joined Jul 2007
Hey that looks nicer than what I'm doing with the goggles and all... I guess, if you make the antenna like mine up there, it's not "inverted" but just a V? What is the meaning of inverted, and does it matter?
Old Sep 04, 2010, 11:49 AM
sonicj is offline
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
see here. it does make a difference which way the V faces.
-sj
Discussion trex 600e build your own fuse. catbalu Large Electric Helis 10 Oct 27, 2009 12:10 AM
Sold Build your own brushless motor sale pending Douglas Cheatwo Aircraft - Electric - Power Systems (FS/W) 1 Oct 07, 2009 11:26 AM
New Product Build your own two channel servo tester for less than $15! W9GFO Product Announcements 0 Sep 29, 2009 07:19 PM
Question Build Your Own Parkzone Mustang Question Blue Jacket Electric Warbirds 8 Sep 13, 2009 08:49 PM
