Old Jan 15, 2010, 12:31 AM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
are you using a balun on your inverted vee?
sonicj is offline Find More Posts by sonicj
Old Jan 15, 2010, 10:12 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I don't use a balun. Since the impedance of the TX and inverted Vee antenna is so close I don't need one. Just run it direct.
IBCrazy is online now Find More Posts by IBCrazy
Old Jan 15, 2010, 02:59 PM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
in case somebody want to see, this is the DPCAV 900mghz 3dbi
inside look. What is this kind of antenna IBCrazy ?
brass tube is connected to shield (ground) and the spring is connected
to the center pin:
i only save 3g with this mod go from 14 to 11g...
ggtronic is offline Find More Posts by ggtronic
Old Jan 15, 2010, 07:27 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It looks like a base fed helical full wave dipole. It might be 3/2 wave too, which would make more sense. How tall is the brass tube? What frequency is it used on?
Basically this combines the helical antenna with a dipole antenna. The helical antenna has a gain of about 1.5 dbi at 1/4 wave, so it is almost isotropic. However, with added length the gain increases. The brass tube would act as a monopole reflector. It will actually direct the signal some.
This looks like a decent antenna design for moderately high altitudes. The radiation pattern would be similar to the 1/2 wave inverted Vee.
-Alex
Old Jan 15, 2010, 07:37 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Ok, I just checked DPCAV's website. They are calling it a compact dipole with 2 dbi gain.
The real term for this is a helical dipole. It is 1/2 wave not full wave. Impedance is 71 ohms assuming it is perfectly tuned, so you would have a best case SWR of 1.3 which is fairly good. Gain is actually more like 1.5 to 1.6 dbi not 2 dbi. This is very close to isotropic (spherical radiation pattern). A definite good closer range antenna which would work extremely well if you like to fly over your own head. It would also be good for stunt flying and moderately high altitude.
-Alex
Old Jan 15, 2010, 08:55 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
I use this antenna. Love it. I fly with it striaght up I flew it over head and got a lot of static. Once out along side the static when away. I've flown really high at what I think is a good distance and had an awsome picture. But 100 ft directly over head... static.
This what I think is going on. If anyone has anyother ideas please PM me with a fix.
man2000me is offline Find More Posts by man2000me
Old Jan 15, 2010, 08:58 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Flip it upside down. That should help the overhead problem. The brass tube acts as a reflector so the propagation pattern looks kind of like a mushroom.
Old Jan 15, 2010, 09:07 PM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Well damn. Its mounted on top or the plane. I was going to test that and fly upside down over my head to see if there was a difference.
Old Jan 16, 2010, 12:34 PM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
thanks IBCrazy ..
yes i forgot to say its for 900mghz...
brass tube is 67mm and spring=20mm
Old Jan 18, 2010, 07:02 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
gg, that should work well. If you can get that GPS a little farther away from the antenna, that will also help. The orientation of the GPS receiver does not matter. It is receiving signals from many directions, so there is no proper orientation. I usually lay mine in the side and tuck it in the wing or something.
Old Jan 18, 2010, 07:57 PM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
How do you think it transmits through foam? Say if I were to drill a hole striaght down throught the foam fuselage, slide the antenna through it...
Old Jan 18, 2010, 09:15 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It will travel through foam like air. Foam is mostly air. What isn't air is plastic... which is exactly what the antenna case is made from. It will travel through thin wood just the same. It is conductive materials that are the problem.
Old Jan 18, 2010, 09:19 PM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Well if that is right then I will lay the Vtx across the top of the fuselage and run the antenna straight down. Less drag and more Vtx cooling... Anyone have any information to prove otherwise???
Old Jan 19, 2010, 07:16 AM
Patrick R is offline
Find More Posts by Patrick R
Dos Hermanas (Sevilla)
Joined Dec 2007
Hi IBCrazy,
Great information about antennas.
Is it posible to make a "lighter" 1.2ghz antenna for a 500mw LW Tx than the stock one?:
http://www.nghobbies.com/cart/index....roducts_id=357
I am mounting a trex 250 for fpv, the 1.2ghz stock antenna is quiet heavy at the base, so i would like to get or make a lighter one.
Regards.
Patrick
Patrick R is offline Find More Posts by Patrick R
Old Jan 19, 2010, 07:30 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
8 grams. If interested I can post build log, I took pictures.
http://www.rcgroups.com/forums/showp...&postcount=143
renatoa is offline Find More Posts by renatoa
Discussion trex 600e build your own fuse. catbalu Large Electric Helis 10 Oct 27, 2009 12:10 AM
Sold Build your own brushless motor sale pending Douglas Cheatwo Aircraft - Electric - Power Systems (FS/W) 1 Oct 07, 2009 11:26 AM
New Product Build your own two channel servo tester for less than $15! W9GFO Product Announcements 0 Sep 29, 2009 07:19 PM
Question Build Your Own Parkzone Mustang Question Blue Jacket Electric Warbirds 8 Sep 13, 2009 08:49 PM
