Old Dec 18, 2009, 02:37 AM
Blue Sky is offline
Find More Posts by Blue Sky
It just keeps getting better!
Blue Sky's Avatar
Eureka, CA
Joined Oct 2002
Nice work!
Lots of useful info and to the point.
Blue Sky is offline Find More Posts by Blue Sky
Old Dec 18, 2009, 02:48 AM
jarconman is offline
Find More Posts by jarconman
jarconman's Avatar
Lijnden, the Netherlands
Joined Oct 2007
Great article IBCrazy,
I am a bit confused maybe you can help me a little. In the article you tell about the old formula to calculate wave length in meters being 2.98 * freq in Mhz. Usingn your 910 Mhz example resulting in a wave length of 2711,8 meters. This seems a little long wavelength since you calculated a little bit further that the quarter wave would be 7.87 centimeters or 0,0787 meters.
even when I take the 0.95 % in the equation I can't understand the big difference because 4 * 0,0787 is not equal to 2711,8.
Where do I go wrong.
jarconman is offline Find More Posts by jarconman
Old Dec 18, 2009, 05:34 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Excellent, all you need to make it perfect is to add some more bits about polarization
renatoa is online now Find More Posts by renatoa
Old Dec 18, 2009, 07:14 AM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
subscribe! thanks
is it possible that different type of antenna have a direct link
with video TX power comsuption ?.
i have a problem: my video TX (900mghz 500mW) become really
really hot (untouchable), and pull between 600mA and 1 amp
instead of 300mA as advertise...with the original antenna
(i`w waiting my 2dbi dipole).
I will built one of your model (dipole probably ?) to get more performance
and save weight... !
ggtronic is offline Find More Posts by ggtronic
Old Dec 18, 2009, 07:59 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Awesome post! I've been wanting to make my own tx antenna.
bracky72 is offline Find More Posts by bracky72
Old Dec 18, 2009, 09:10 AM
SoliSab is offline
Find More Posts by SoliSab
Iranair
SoliSab's Avatar
Joined Aug 2007
Originally Posted by IBCrazy View Post
Building your own antennas for FPV use
This is a basic guide on how to build and calibrate your own antennas for use in FPV. I will not be going into extreme detail as there are hundreds of papers on the designs of these antennas. However I will explain their construction, and most importantly, how to connect them and how to test them without specialized equipment. I will be covering 3 basic antenna types:
The basic half wave dipole
Half wave whip
Inverted Vee
I will discuss the limitations, design considerations, and best applications for each of these antennas. For those who wish to build a patch antenna, Mr. RC Cam has an excellent how to on his website titled The GP Patch antenna. I will refrain from reposting it here.
-Alex
Hi IBCrazy
It seems that you are the one to ask this from. I Have a sheety Fpv system that i bout long time ago. It is and was very cheap, but it doesnt work really. I am not very good at this, but there should be someone or a site or somethig that i could turn this to a nice hobby working time.
What i want to know is. If i make a better antenna for it. would it improve the range? or what can i do with it?
I have thought of many things. Like jumping up and down on it and then see if it improves anything?
I havent done it yet but if you say so i promess i will........
here is a picture of it.
SoliSab is offline Find More Posts by SoliSab
Old Dec 18, 2009, 09:51 AM
Joined Sep 2007
The problem with your system it's the overall low quality, that can't be improved much only by changing antenna.
First the receiver... I see in the picture the damned tuning knob, that is a sure sign of low sensitivity receivers that are very difficult to keep in tune, because they drft badly with both power voltage and temperature.
Also, I suspect the transmitter too, if it is hidden in the camera case, picture is too small to see clear. If I guessed, then that transmitter has 10mW in the most optimistic case, but I expect to have even 2-3mW, so a range of under 100feet.
Old Dec 18, 2009, 11:09 AM
Crash9 is offline
Find More Posts by Crash9
FPV Pilot
Crash9's Avatar
United States, MT, Missoula
Joined Mar 2006
Very nice work IBcrazy. Good info your sharing .
Crash9 is offline Find More Posts by Crash9
Old Dec 18, 2009, 11:27 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Right on. You'll need to test with the RSSI pin extensively after this thing warms up some. Tune the knob to the highest RSSI (You'll have to back off about 20 feet before taking the reading). Once set, glue it in place. Use a voltage regulator to make sure the voltage is constant on the RX.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 18, 2009, 11:42 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That is the length of your antenna active component. It is 1/4 of your wavelength. At 910 MHz with a 95% propagation factor, your wavelength is 31.43 cm. 2,970,000 * .95 *100 / 910 MHz = 31.43 cm
Old Dec 18, 2009, 02:34 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Matching the antenna will have a direct impact on the heat generated by the transmitter, but not the power consumed. Poorly matched antennas direct the would be transmit energy back at the transmitter causing it to heat up.
Do yourself a favor and take apart the junk whip antenna on your TX by unscrewing the plastic holder. Solder on a piece of solid copper wire 6-3/16" long to the end of it and replace the cap to help support it. I'll bet you TX runs much cooler and your range doubles.
-Alex
Old Dec 18, 2009, 04:51 PM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Poorly matched antennas direct the would be transmit energy back at the transmitter causing it to heat up.-Alex
humm thats good news!
but the transmitter claim 300mA, and it sometime pull 1000mA !
it start to have an impact on flight duration !
anybody else have ever mesure theire 900mghz 500mW transmitter
power comsuption (i'v seen amp go near zero on most FPV video,
wich mean video TX need near nothing... )
thanks Alex
Old Dec 19, 2009, 01:17 AM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
thanks Alex
my 900mhz 500mw tx, camera, and a small fan pulls around 0.5a. i think im using a 1a fuse on my fpv gear.
like alex said, a tuned antenna is first and foremost. i don't know how it affects power consumption, but it certainly affects power output! when i was tuning my stock junk antenna power output varied from 400mw to 700mw.
sonicj is offline Find More Posts by sonicj
Old Dec 19, 2009, 03:58 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Thanks IBcrazy
you have made so many points so much clearer. I'm off to get some bits for that dipole aerial
rcmonster99 is offline Find More Posts by rcmonster99
Old Dec 19, 2009, 06:12 AM
flyinthesky is offline
Find More Posts by flyinthesky
Joined Sep 2009
IBCrazy, there is an interesting dipole antenna design on rc-cam.com you might like to include in your list. The benefit of it is that the transmitter is not forced to be at the centre of the antenna, and also that some length of feedline is possible (but note the comments about results varying with feedline). I haven't tried it yet myself unfortunately.
Thanks for your article!
flyinthesky is offline Find More Posts by flyinthesky
Discussion trex 600e build your own fuse. catbalu Large Electric Helis 10 Oct 27, 2009 01:10 AM
Sold Build your own brushless motor sale pending Douglas Cheatwo Aircraft - Electric - Power Systems (FS/W) 1 Oct 07, 2009 12:26 PM
New Product Build your own two channel servo tester for less than $15! W9GFO Product Announcements 0 Sep 29, 2009 08:19 PM
Question Build Your Own Parkzone Mustang Question Blue Jacket Electric Warbirds 8 Sep 13, 2009 09:49 PM
