Old Nov 04, 2012, 09:19 AM
bolo1234 is offline
Find More Posts by bolo1234
United States, TX, Laredo
Joined Oct 2012
Originally Posted by IBCrazy View Post
2-1/8" for 1280MHz
Ok, is that measuring both legs? Right?
bolo1234 is offline Find More Posts by bolo1234
Old Nov 06, 2012, 02:36 AM
novian89 is offline
Find More Posts by novian89
novian89
Indonesia, Jakarta
Joined Sep 2012
before i bought one becouse they are attracted by low price in my countries
cctv Spy Camera mini wireless INFRARED 1.2Ghz
Uploaded with ImageShack.us
the camera has build in antenna
what can be modified so that its antena can be greater distance
novian89 is offline Find More Posts by novian89
Old Nov 06, 2012, 02:44 AM
novian89 is offline
novian89
Indonesia, Jakarta
Joined Sep 2012
sorry double post
Old Nov 06, 2012, 09:13 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You are going to need to hack into that thing a little and access the output transistor. Where then antenna is soldered on, solder in a section of RG316 coaxial cable. Connect the shield to the neares ground. Now simply build the antenna on the other end.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 06, 2012, 09:14 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Correct.
Old Nov 26, 2012, 11:37 AM
Jeff Watt is offline
Find More Posts by Jeff Watt
Joined Dec 2004
Anybody have any idea where I can get 4-conductor shielded cable (I need a small diameter outer casing - preferably less than 4mm)?
Nevermind - Using a USB cable
Jeff Watt is offline Find More Posts by Jeff Watt
Old Nov 28, 2012, 06:03 AM
angry is offline
Find More Posts by angry
Work less, fly more!
Australia, WA, Broome
Joined Aug 2012
Hello Alex, I have just spent a few hours reading all the information in your blog, thank you so much for spending the time and effort to put it down in words. I have just ordered the goods to have a go at an inverted vee.
Thanks again. Angry
angry is offline Find More Posts by angry
Old Nov 28, 2012, 06:16 AM
ExperimentalAir is offline
Find More Posts by ExperimentalAir
Ed @ Experimental Airlines
ExperimentalAir's Avatar
United States, AZ, Phoenix
Joined Sep 2011
Completely aside from fresnel zone considerations, is there a critical proximity of "parts" (Vtx, camera, battery, other wires, etc.) to the video transmitter antenna that will actually detune or otherwise suppress transmitted power?
I'm getting what I consider to be pretty dismal performance from a Lawmate 2.4GHz 500mW, seemingly with less influence than I would expect between stock omni, Vee, cloverleaf antennas, and corresponding antennas (plus tried a patch) on receiver. I have a pretty tight setup with a 6cm feedline (except stock antennas) direct to Vtx, with PSU and camera immediately adjacent to the Vtx, and main battery 15cm from that.
I'm on the verge of abandoning this concept, just looking for some information and affirmation. Or if it's something else, I'll keep searching. Thanks!
ExperimentalAir is offline Find More Posts by ExperimentalAir
Old Nov 28, 2012, 07:44 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes. Even moisture causes detuning of the antenna. The wider the antenna bandwidth, the less it affects performance. The Vee is a narrow band antenna and thus the effect of environment is relatively high compared to a closed loop design such as a folded dipole (hence why folded dipoles are used as feeders for Yagi antennas).
However, this is likely not the cause for poor performance. Poor performance lies in the ground station at least 90% of the time. Poor performance on the TX side is more or less limited to fresnel zone issues.
Let me explain what I mean. This flight is the raw footage from a .000125W system. That's 125 uW or 1/8th of 1mW! My transmit power is really cut down as I was using this as a test bed for my new "Pepperbox" antenna that is comng out very soon.
125uW test flight - 2250 feet (3 min 18 sec)
-Alex
Old Nov 28, 2012, 06:22 PM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
Alex, i need your help again master
I have a meeting this weekend and have no time to crimp and make a top quality antenna, i just want to do a fast inverted V,
I have welding wires left from the CP antenna project + old 2.4ghz antenna,
What i did is open the old antenna and unsolder the cylinder around the dipole, then cut it to keep the connector and solder 2 pieces of welding wires (that i will trim to 2.4)
Lookig at pictures, you think that method is okay ?
Thanks Alex !
bakchos is offline Find More Posts by bakchos
Old Nov 28, 2012, 07:31 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Looks good to me. Open your angle up to 120-135 degrees for best results.
-Alex
Old Nov 29, 2012, 04:12 AM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
-Alex
Thank you Alex, the angle was not set yet.
Thanks for always helping out !
Old Dec 16, 2012, 10:18 PM
angry is offline
Joined Aug 2012
Hello Alex and all, i know it has probably been posted before but i am reasonably new to this thread, but is there a calculator or formulas to calculate the length of the antenna elements for an inverted vee.
thanks angry
Old Dec 17, 2012, 08:45 AM
angry is offline
Joined Aug 2012
Hello again please disregard previous post found info on page
161. Thanks
Old Jan 02, 2013, 06:26 PM
angry is offline
Joined Aug 2012
Hello Alex, first test flight of the home made inverted vee this morning, 2.6 klm faultless video all the way, (900mhz 500mw tx) could not be happier, had a little interference on the way back, (vee pointing to nose).
Thanks for your tutorials. Is there any real advantage to building a 2/3 vee? space is not a problem.
Thanks again, angry
Discussion trex 600e build your own fuse. catbalu Large Electric Helis 10 Oct 27, 2009 12:10 AM
Sold Build your own brushless motor sale pending Douglas Cheatwo Aircraft - Electric - Power Systems (FS/W) 1 Oct 07, 2009 11:26 AM
New Product Build your own two channel servo tester for less than $15! W9GFO Product Announcements 0 Sep 29, 2009 07:19 PM
Question Build Your Own Parkzone Mustang Question Blue Jacket Electric Warbirds 8 Sep 13, 2009 08:49 PM
