Old Jan 01, 2011, 10:47 PM
replayreb is offline
Find More Posts by replayreb
replayreb's Avatar
Oxford, MS
Joined Dec 2005
Originally Posted by IBCrazy View Post
Sort of...
The truth is that the shield of the cable will acts partially as a counterpoise unless you alter the geometry a little. If you look at how I build mine, I keep the active element right in line with the cable and have the counterpoise at an angle. This mitigates the RFi and keeps the signal almost perfectly level.
It's amazing how much detail and analysis can go into something so simple
-Alex
I consider myself a relatively smart person but I think this antenna stuff is more art than science...or maybe voodoo.
replayreb is offline Find More Posts by replayreb
Old Jan 01, 2011, 10:50 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Not really voodoo. Black magic actually
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 01, 2011, 11:03 PM
replayreb's Avatar
Oxford, MS
Joined Dec 2005
lol. No wonder so many people when they see a long range FPV video demand that the pilot tell them EXACTLY what equipment they used! The air stuff was easy for me...I just threw a 1-watt transmitter up into the air with the stock rubber duck and it worked flawlessly for me up over a mile away but this ground-based FPV range problem really has me confounded.
Old Jan 02, 2011, 07:39 AM
blupp is offline
Find More Posts by blupp
FPV is my cup of tea
blupp's Avatar
Sweden
Joined Mar 2010
Sort of...
-Alex
http://www.antennex.com/shack/Dec06/cps.html
For clarity and better understanding, this antenna have no counterpoise.
It have two radiators, and the two radiators as a unity should be referred to as a radiating element.
Am I correct?
blupp is offline Find More Posts by blupp
Old Jan 02, 2011, 09:10 AM
bah7566 is offline
Find More Posts by bah7566
FPV maniac
bah7566's Avatar
Colorado
Joined Sep 2007
coax question
If I wanted to make an extension from my video RX on my ground station to put the antenna on a pole. What coax would be best for about 25' ? Is this a possibility or a pipe dream? I want to have my yagi on a pole but the RX on or close to the ground.
Thanks in advance for any advice you may have.
Bruce
bah7566 is offline Find More Posts by bah7566
Old Jan 02, 2011, 09:19 AM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
Bruce
LMR-400 would work fine at 25'.
Po73 is offline Find More Posts by Po73
Old Jan 02, 2011, 09:20 AM
bah7566 is offline
FPV maniac
bah7566's Avatar
Colorado
Joined Sep 2007
Thanks!
Old Jan 02, 2011, 09:25 AM
Po73 is offline
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
Thanks!
No problem. Keep in mind it's not very flexible so you want some slack near a point that will move IE; near the last clamp on the mast if you are rotating the mast.
Old Jan 03, 2011, 05:03 AM
blupp is offline
blupp's Avatar
Sweden
Joined Mar 2010
Sorry if I sound arrogant and rude, I don't mean to. I just have to stick out my tongue sometimes.
Many here possess more knowledge and experience than I probably ever will.
Thank you for sharing and helping! Thank you Alex!
Old Jan 03, 2011, 08:42 AM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
For my issue with the video breaking up on the return trip, watch here. At about 5:40, I turn around. Sorry for the boring video. My view isn't great - I need a different camera mount.
I'll shoot some pics of the plane and antenna/mount.
DragonOSD FPV (13 min 23 sec)
Bigster is offline Find More Posts by Bigster
Old Jan 03, 2011, 08:52 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Seems to me something on the airplane was blocking the signal. Do you have a picture of the antenna mounted on the plane?
-Alex
Old Jan 03, 2011, 11:51 AM
Bigster is offline
Bigster's Avatar
Joined Sep 2004
Here are a couple of pics. The wing does have a carbon spar, fwiw.
Old Jan 03, 2011, 01:44 PM
blupp is offline
blupp's Avatar
Sweden
Joined Mar 2010
All electronics, wires, magnets and the carbon spar will interfere.
Maybe not much, but still.
I would move the antenna away from the aforementioned and as low as I could.
Possibly onto the tail fin. And tilt it slightly forward counter clockwise.
That would put the front lobe slightly angled downwards, below the motor, electronics, etc.
Last edited by blupp; Jan 03, 2011 at 04:17 PM. Reason: I changed my mind about the CP case, sorry :)
Old Jan 03, 2011, 07:10 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Flip that antenna upside down. The way you have the coaxial cable coming into the center causes the shield to angle the signal skyward. Flip it over and it will send it downward where you want it
-Alex
Old Jan 03, 2011, 08:05 PM
Bigster is offline
Bigster's Avatar
Joined Sep 2004
Awesome! Thanks Alex - I'll try it!
Discussion trex 600e build your own fuse. catbalu Large Electric Helis 10 Oct 27, 2009 12:10 AM
Sold Build your own brushless motor sale pending Douglas Cheatwo Aircraft - Electric - Power Systems (FS/W) 1 Oct 07, 2009 11:26 AM
New Product Build your own two channel servo tester for less than $15! W9GFO Product Announcements 0 Sep 29, 2009 07:19 PM
Question Build Your Own Parkzone Mustang Question Blue Jacket Electric Warbirds 8 Sep 13, 2009 08:49 PM
