Old Dec 16, 2009, 12:55 AM
liam2317 is offline
Find More Posts by liam2317
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
HobbyKing EDF 64 Identification
So I need a little help with my first EDF. After reading a bit about HobbyKing's EDF64 with ADH300 Motor it looked like a pretty decent buy so I picked one up. My problem though, is that the one they sent me looks nothing like the one pictured on the site! It also comes with a outrunner motor instead of an inrunner!!! Has anyone else ordered this EDF and gotten something else?
I tried going on the Live Support but they weren't very helpful, they basically just told me to email them the question so they could take a month getting back to me...
Anyway, I have attached some pictures of the one they sent me, any help identifying it and it's motor would be greatly appreciated. I'd really like some specs on this setup but I don't have a watt meter and I don't want to take it out of its packaging in case it's total crap and hobbyking wont take it back once I have.
Thanks!
-Liam O.
liam2317 is offline Find More Posts by liam2317
Old Dec 17, 2009, 01:06 PM
liam2317 is offline
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
No one has any ideas?? C'moooon!
Old Dec 17, 2009, 01:46 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well I beleive that they likely haven;t updated the picture more recently. The newer versions of that EDF are using a longer nose outrunner that fits in place of a smaller in diameter inrunner. I like having the motor more exposed to air than being inside the EDF shroud with less of a airflow on it.
HC doesn't appear to be selling the ADH300 motor separately, so there is no way to compare it to a short shaft version of that motor.
But I think you are OK.
i would go ahead and use it. I think the shipping costs are probably as much as the EDF unit costs, unless Canada is a lot cheaper than here in the USA.
I have noticed a lot more outrunners with the long shaft, so that they can be inserted into EDF units that were designed for the smaller in diameter inrunner motors.
earlwb is offline Find More Posts by earlwb
Old Dec 17, 2009, 01:51 PM
FidlerEd is offline
Find More Posts by FidlerEd
Joined Aug 2005
http://www.aeorc.com/english/?gallery-37.html
FidlerEd is offline Find More Posts by FidlerEd
Old Dec 18, 2009, 01:53 AM
liam2317 is offline
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
Alright, excellent! From the link you posted Ed it looks like the specs of this fan are pretty similar to the specs on HobbyKing's site. Thanks for the help guys!
So I took your advice and went ahead and opened it up, soldered on the connectors and fired it up. Loooots of rubbing on the inside of the shroud!!! That being said even though I never took it above 1/2 throttle it still had a surprising amount of thrust.
Will balancing the fan eliminate the rubbing? I didn't feel a whole lot of vibration but I suppose at these RPMs it doesn't take much.
Old Dec 18, 2009, 06:21 AM
istandalone is offline
Find More Posts by istandalone
life is an oyster. shuck it!
istandalone's Avatar
bennington, VT
Joined Mar 2008
" It also comes with a outrunner motor instead of an inrunner!!! "
the fan/motor that you linked to does in fact have an outrunner in the picture, not an inrunner. i'm not sure why your saying it should be an inrunner.
istandalone is offline Find More Posts by istandalone
Old Dec 18, 2009, 02:36 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Looks like the ELE fan combos BP is selling
http://www.bphobbies.com/view.asp?id=B1098403
The link shows the 40mm fan, but they have a 64mm one also. I think the outrunner is the right motor. Some would even argue that an outrunner is better in an EDF, for cooling purposes.
All my J Power 64mm jets use outrunners. They're fine. (Hell, Hoffman Beast and Wild Beast, and the JS 1400 are outrunners).
kelberts is offline Find More Posts by kelberts
Old Dec 19, 2009, 02:10 PM
liam2317 is offline
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
Thanks for another link kelberts!
Though it doesn't ever state what kind of motor it is on HK's site from the image it sure looked like an inrunner to me. There is no apparent gap between the motor and the motor casing as I have pointed out in the attached image. Why on earth would they nearly encase the motor in plastic if it was an outrunner? I suppose I don't really know though, you could easily be right. How do you know it is supposed to be an outrunner?
Old Dec 19, 2009, 02:49 PM
bennington, VT
Joined Mar 2008
^^ that pic is definitley an outrunner, no question about that.
the only drawback to that is the motor might be hot. outrunners are great in edf applications, but they really do well when they're mated with a standoff adaptor so that the spinning motor can is in the breeze.
Old Dec 19, 2009, 02:53 PM
bennington, VT
Joined Mar 2008
like these:
Old Dec 19, 2009, 11:09 PM
Gerry Santos is offline
Find More Posts by Gerry Santos
Manila, Philippines
Joined Jul 2001
Motor specs
like these:
What are the specs of that motor on the far right? This looks like the stock motors used in the blitzrcworks F14.
Gerry Santos is offline Find More Posts by Gerry Santos
Old Dec 20, 2009, 07:52 AM
bennington, VT
Joined Mar 2008
it's dons wicked extreme 5400kv.
works great in the phase 3 ef16 stock fan on 4s.
Discussion HobbyKing 70mm EDF EPO F15 KCV6 Foamy EDFs 2 Dec 15, 2009 06:30 PM
Question gws edf 64 lilpip Electric Ducted Fan Jet Talk 11 Dec 07, 2009 09:44 AM
Wanted 64 mm edf unit eschult Aircraft - Electric - Jets (FS/W) 6 Nov 22, 2009 05:40 PM
Discussion Are EDF-75 or EDF-64 nacelles available any where AMTJIM Foamy EDFs 1 Apr 16, 2006 12:10 AM
GWS EDF-55's and EDF-64's are available Hawker Electric Ducted Fan Jet Talk 26 Oct 02, 2003 05:51 AM
