This thread is privately moderated by nerdc0re79, who may elect to delete unwanted replies.
Old Dec 15, 2009, 05:32 PM
nerdc0re79 is offline
Find More Posts by nerdc0re79
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
breeze 9mm epp
this is a carbon copy of dualsky breeze outdoor edition. i bought the kit as a template because it is made out of depron foam . i cant stand depron. in my opinion depron foam planes can cause alot of building time and money. i've had good luck with depron. But with epp its more forgiving.
so i traced it to 9mm 1.3 epp. used the carbon fibers that came with the kit. a couple of slight modification on the tabs since the thickness of epp is thicker than the depron kit.
no need to look at the manual cuz its basic building knowledge. im not goin with the pull pull system they recomend for this bird.
i am using 4 hxt900 for servos. this time dual servo ailerons
for motor esc prop combo.. i am using Hobbyking's combo
TowerPro BM2410-9T / 18A BEC/ 1047 Prop Combo
http://www.hobbycity.com/hobbycity/s...idproduct=4706
battery 3cell 1000mah 20c
nerdc0re79 is offline Find More Posts by nerdc0re79
Old Dec 23, 2009, 05:47 PM
helifryer is offline
Find More Posts by helifryer
"I Am The Animal!" in training
helifryer's Avatar
Winston-Salem, NC
Joined Sep 2008
wow! looks really nice! ...any chance you could post a PDF template of this plane?
helifryer is offline Find More Posts by helifryer
Old Dec 26, 2009, 12:12 PM
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
haha i dont have a plan for this. i searched and searched for it. so i decided hey for 32 dollars. im gonna buy it and use that as a template. but im doin some changes on this plane and i sure will get this on pdf. so 2dogrc doesnt chase me around for licensing,patent BS because by the time i am done with modz on this plane. it wont have the same breeze measurement lines and stuff.so it wont be a breeze plane anymore. its goin to be my plane not theres
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
so hang tight. u'll be the first to know
Old Dec 26, 2009, 12:34 PM
helifryer's Avatar
Winston-Salem, NC
Joined Sep 2008
Haha. Cool. Thanks
Sold 2 NIB Slofly 28 SuperSlo-Acro's with 2 sheets of 9mm black EPP - $49 shipped shawn595 Aircraft - Electric - Airplanes (FS/W) 2 Feb 07, 2008 11:53 PM
Question Are there any 9mm epp high wing trainer plans available kevin estes Foamies (Scratchbuilt) 8 Nov 29, 2007 05:33 AM
Discussion Which wing with 9mm EPP? infinitum Foamies (Scratchbuilt) 15 Oct 31, 2007 11:30 PM
Sold 9mm EPP 11inx12in 8 sheet for 1 cent 1 hour left sloper steve Aircraft - General - Miscellaneous (FS/W) 0 Jul 06, 2007 08:56 PM
Wanted EPP 9MM Small sheets fuzzyhead Aircraft - General - Miscellaneous (FS/W) 0 Jun 21, 2007 07:30 PM
