This thread is privately moderated by nerdc0re79, who may elect to delete unwanted replies.
Old Dec 15, 2009, 04:37 PM
nerdc0re79 is offline
Find More Posts by nerdc0re79
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
yak 55 9mm by leadfeather
most durable foamie i have ever flow. in the years i have been into rc planes. i have built and bought foam planes. from electrifly series to scratchbuilt. this plane is the funnest to fly
i did everything within leadfeather's recommendation . the only thing i added was the string bracing cuz i wanted it to be as stiff as possible. and with that i got a very stiff 9mm epp foamie
my electronic set up
motor-
HXM2730-1500
hexTronik 24gram Brushless Outrunner 1500kv
shaft size-3mm diameter
motor mount-
HXM2730-Mount
HXT 8mm Alloy Motor Mount 2.5g
esc-
TowerPro 9g w12A Brushless Speed Controller
http://www.towerpro.cn/english/Manual/manual.html
servos x3-hxt900
props- 8x3.8 sf or 8x4
battery - 2 cells only with 800mah or 850 mah with 15c rating
CENTER OF GRAVITY
3 inches from leading edge of wing TAIL HEAVY
2 3/4 balanced
nerdc0re79 is offline Find More Posts by nerdc0re79
Discussion Leadfeather's EPP Yak 55 motorhead Foamies (Kits) 68 Jan 04, 2015 10:09 PM
For Sale EPP Leadfeather Yak 55 Kit fatcat1 Aircraft - Electric - Airplanes (FS/W) 8 Apr 12, 2010 06:37 PM
Discussion 18.5" Yak 55 Build (leadfeather's EPPYAK-55plans) K0na_stinky Foamies (Scratchbuilt) 1 Apr 05, 2009 04:05 PM
For Sale Leadfeather EPP Yak-55 kits motorhead Aircraft - Electric - Airplanes (FS/W) 4 Mar 12, 2009 09:14 PM
