This thread is privately moderated by JohnM, who may elect to delete unwanted replies.
Old Dec 15, 2009, 04:35 PM
JohnM is offline
Find More Posts by JohnM
Trader Rating: 153
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
Trader Rating: 153
Sold
E-flite HP6DSM 6-Channel 2.4GHz DSM2 Transmitter
For Sale: E-flite HP6DSM 6-Channel 2.4GHz DSM2 Transmitter
$55 shipped USPS Priority Mail (with Delivery Confirmation) in the CONUSA
This full range 6-channel Spektrum 2.4GHz DSM2 Heli/ Airplane Transmitter is in excellent working condition and has a significant amount of great features. It is the same transmitter that is included with the RTF E-flite Blade CP Pro 2 helicopter and is sold separately at Horizon Hobbies for $99 as seen here: http://www.horizonhobby.com/Products...rodID=EFLH1056
Specs:
Full range Spektrumô 2.4GHz DSM2ô technology
Mode II
Flight mode switch
Throttle hold switch
Dual rate switches
Trainer Switch
Adjustable Trims
Adjustable Stick Height
Requires 4 AA batteries (not included)
Airplane Mode Features:
Elevator/Aileron (Elevon) mixing
Rudder/Elevator (Ruddervator/V-Tail) mixing
Adjustable knob (fully proportional) for Chan 5 functions (Flaps, Retracts, etc.)
Helicopter Mode Features:
2 Mixing settings: 120-degree Cyclic Collective Pitch Mixing (CCPM) Or Standard mixing
2 Flight Modes: Normal or Stunt/Idle Up
Stunt Mode Throttle Curve Midpoint Adjustment (SM TCM ADJ) knob
Remote Gryo gain knob
DIP Switch Settings:
Dip Switch 1*
UpóChannel 1/Throttle channel reversed
DownóChannel 1/Throttle channel normal
*For safety, channel 1/throttle channel reversing can only be changed when the transmitter is powered off. All
other dip switch positions/functions can be changed while the transmitter is powered on.
Dip Switch 2
UpóChannel 2/Aileron channel reversed
DownóChannel 2/Aileron channel normal
Dip Switch 3
UpóChannel 3/Elevator channel reversed
DownóChannel 3/Elevator channel normal
Dip Switch 4
UpóChannel 4/Rudder channel reversed
DownóChannel 4/Rudder channel normal
Dip Switch 5
UpóChannel 5/Gear channel reversed
DownóChannel 5/Gear channel normal
Dip Switch 6
UpóChannel 6/Pitch channel reversed
DownóChannel 6/Pitch channel normal
Dip Switch 7
UpóHelicopter Mode (Channel 6 becomes pitch channel)
DownóAirplane Mode (Channel 6 becomes an extra aileron channel)
Dip Switch 8*
Upó120-degree Cyclic Collective Pitch Mixing (CCPM)
DownóStandard mixing
*Only functions when in helicopter mode.
Dip Switch 9*
UpóRudder/Elevator (Ruddervator/V-Tail) mixing
DownóNo mixing
*Only functions when in airplane mode, and no function if switch 10 is in the up position.
Dip Switch 10*
UpóElevator/Aileron (Elevon) mixing
DownóNo mixing
*Only functions when in airplane mode, and no function if switch 9 is in the up position.
Binding Process:
First power up your RX in Bind Mode (install Bind Plug, if applicable). To enter bind mode with the transmitter, pull the trainer (TRAINER) switch toward the front of the transmitter, then, while holding the trainer switch forward, power the transmitter on. Youíve successfully entered bind mode when the transmitter beeps and the red LED located under the door on the bottom left front of the transmitter blinks
rapidly. You can release the trainer switch after the transmitter stops beeping and the transmitter will remain in bind mode until the binding process is complete. Then, once the orange LED on the receiver glows solidly, the receiver is bound to the transmitter. Now you will need to power down the transmitter and receiver. (Remove Bind Plug from RX, if applicable).
JohnM is offline Find More Posts by JohnM
Old Dec 21, 2009, 12:42 PM
JohnM is offline
Trader Rating: 153
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
Trader Rating: 153
bump
Old Dec 24, 2009, 02:22 PM
huckleberg is offline
Find More Posts by huckleberg
Trader Rating: 66
Paddle faster - I hear banjos!
huckleberg's Avatar
USA, VA, Fairfax
Joined Mar 2008
Trader Rating: 66
someone really oughtta buy this. i had one, it is actually pretty flexible in its use, with some control of curves etc ...
huckleberg is offline Find More Posts by huckleberg
Old Dec 28, 2009, 07:07 PM
Bishopgoldy is offline
Find More Posts by Bishopgoldy
Trader Rating: 0
Joined Dec 2009
Trader Rating: 0
I really want to buy this!!!
Bishopgoldy@gmail.com
Bishopgoldy is offline Find More Posts by Bishopgoldy
Sold 2 E-flite HP6DSM 6-Channel 2.4GHz DSM2 Transmitters JohnM Aircraft - General - Radio Equipment (FS/W) 7 Dec 09, 2009 06:02 PM
Sold HP6DSM Spektrum 6 Channel eCCPM 2.4Ghz Transmitter (testing the waters) huckleberg Aircraft - General - Radio Equipment (FS/W) 0 Jun 22, 2009 05:01 PM
Discussion BRAND NEW E-flite HP6DSM 6 Channel Transmitter, 2.4GHz DSM2: BCPP2 - $50 ItalianIce Mini Helis 0 May 09, 2009 01:28 PM
Discussion BRAND NEW E-flite HP6DSM 6 Channel Transmitter, 2.4GHz DSM2: BCPP2 - $50 ItalianIce Micro Helis 0 May 09, 2009 01:23 PM
For Sale HP6DSM Spektrum 6 Channel eCCPM 2.4Ghz Transmitter (testing the waters) huckleberg Aircraft - Electric - Helis (FS/W) 0 Mar 05, 2009 08:15 PM
