Old Dec 15, 2009, 03:15 PM
asifjahmed is offline
Find More Posts by asifjahmed
Hopelessly Addicted
asifjahmed's Avatar
United States, OH, Cincinnati
Joined Jan 2009
IDEA: DIY Brushless ESC w/ I2C & PWM support (for quadrocopter)
Hi Guys -
I have been doing MUCH research and analysis of various setups. etc. The goal is to eventually build my own custom quadrocopter.
It seems that the high-end quads out there are using I2C ESCs. I know that some have modified TowerPros, and Rusty has created an I2C->PWM converter, but I am seeking something more elegant...
There are TONS of free schematics out there, but oddly I can't seem to find one for a brushless speed controller. It can't be that difficult, right? I'd imagine it is just 3 channels of FETs and a microcontroller - anyone have knowledge of this?
Once we have a solid circuit, we can then make our own ESCs. I am thinking to use ATMega328 w/ arduino bootloader for easy programming, but of course this is debatable.
Some of the advantages of having our own schematic:
-Can group buy and have true I2C ESCs cheaply.
-Can design the PCB in various form-factors, including a single board with multiple ESCs on it (think a single board with 4 seperate channels for quadrocopters
-Can experiment with various other aspects (feedback, rpm sensing, etc etc etc).
Comments, Questions, all welcome!
-Jamie
asifjahmed is offline Find More Posts by asifjahmed
Old Dec 15, 2009, 04:06 PM
otlski is offline
Find More Posts by otlski
checkout my Blog
otlski's Avatar
Joined Feb 2008
I would add dynamic braking so as obtain some deceleration control of larger inertia props so that quad stability is not compromised when using them. Secondly, to dump the back-EMF regeneratively back into the battery.
BTW, have you check in the DIY or power sections of RC Groups? I seem to remember brushless esc schematics being in either place.
Dan
otlski is offline Find More Posts by otlski
Old Dec 15, 2009, 04:46 PM
bw4257 is offline
Find More Posts by bw4257
Joined Aug 2009
Look for Sensorless BLDC App Notes
Pick your flavor of micro and then go to their web site and search their application notes for: Sensorless BLDC
Here's a link to one for an atmel.
http://www.atmel.com/dyn/resources/p...ts/doc8012.pdf
bw4257 is offline Find More Posts by bw4257
Old Feb 02, 2010, 07:16 AM
ahmadshah is offline
Find More Posts by ahmadshah
Joined Feb 2009
Hi !
i have studied a little bit about bldc motors and their control.
but i am having problem with understanding the starting phase of bldc motor , i have read we have to bring the rotor to a known position , what is the known position ?? and how to bring it and by what technique the controller comes to know that now its the desired ??
please help me !!!!
ahmadshah is offline Find More Posts by ahmadshah
Old Feb 11, 2010, 01:25 PM
bw4257 is offline
Joined Aug 2009
sensors or trial and error
I believe that you either need sensors to "sense" the true position, which could be done through halls, encoders, etc or you run through a sequence and try and bump the motor by trial and error. Then when/if the motor moves you can measure the back-emf and figure out where the motor is. This is most likely why typically ESC might appear jumpy at low speeds or when just starting.
Old Feb 11, 2010, 03:44 PM
derelicte is online now
Find More Posts by derelicte
Joined Aug 2006
I like arduinos.
why i2c thou? are you going for an autonomous craft or something that you control?
if you want to control it, it may make more sense to use serial so you could use something like a xbee transceiver.
derelicte is online now Find More Posts by derelicte
Old Feb 11, 2010, 04:00 PM
dcaspi is offline
Find More Posts by dcaspi
destructive testing expert
dcaspi's Avatar
Kiryat Yam, Israel
Joined Apr 2009
I question the need for I2C. You can get great results with cheap PWM ESC, there are so many examples of these around. I mean, I2C is great but at 4x the cost it's not worth it.
dcaspi is offline Find More Posts by dcaspi
Old Feb 11, 2010, 07:48 PM
Hopelessly Addicted
asifjahmed's Avatar
Joined Jan 2009
While decent stability is achievable with standard i2c ESCs, there must be a reason that so many multicopters are going with i2c ESCs:
-Mikrokopter
-X3D BL
-Shrediquette
.. and others
i2c allows a faster update rate than PWM ESCs. This has been proven.
Not to mention that the microcontroller is then relieved of the strain of generating PWM pulses.
Also, with the great work of quad and Arthur P (and others), you can now modify Turnigy/TowerPro ESCs to work with i2c, so the 4x cost point is no longer valid:
http://www.rcgroups.com/forums/showt...766589&page=45
-Jamie
Old Feb 12, 2010, 12:36 AM
dcaspi is offline
dcaspi's Avatar
Kiryat Yam, Israel
Joined Apr 2009
-Mikrokopter
-X3D BL
-Shrediquette
.. and others
You can update at ~500Hz with many PWM ESCs. I update @ 100Hz and I think it's an overkill. Why do you need more than that?
At least with AVR (e.g., Arduino) it's done in h/w, no strain.
-Jamie
Build Log Converting TowerPro 25A type 2 ESC's from PWM to TWI/I2C control Arthur P. DIY Electronics 1283 Apr 16, 2015 10:42 AM
Discussion I2C to PWM converter for use of standard ESCs in multicopters Arthur P. DIY Electronics 8 Feb 01, 2011 07:21 PM
Build Log Converting SuperSimple 50Aamp ESC from PWM to TWI/I2C agressiva DIY Electronics 37 Jan 25, 2011 10:47 AM
Discussion What is the recommended or best MCU for my DIY brushless ESC ? joenet DIY Electronics 1 Dec 11, 2009 06:03 PM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 12:56 PM
