Old Feb 04, 2013, 06:43 AM
marty_mcfly is offline
Find More Posts by marty_mcfly
Australia, QLD, Townsville
Joined Jul 2011
hi i am looking for good android ap to record track in case of lost plane so i can find the plane with last last gps coordinates can anyone recommend a good one to get for myflydream?
marty_mcfly is offline Find More Posts by marty_mcfly
Old Feb 04, 2013, 06:50 AM
fpvk1 is offline
Find More Posts by fpvk1
fpvk1's Avatar
Norway, Nordland, Vefsn
Joined Sep 2012
i'm using this one...
https://play.google.com/store/apps/d...ZWouYnRncHMiXQ..
and mytracks....
https://play.google.com/store/apps/d...m15dHJhY2tzIl0.
fpvk1 is offline Find More Posts by fpvk1
Old Feb 04, 2013, 06:52 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
Bluetooth GPS app for android works a treat.
If you check the forum section of the MFD website you will see some others but bt gps works so well I don't need much else.
Hope this helps.
R.
RolandS888 is offline Find More Posts by RolandS888
Old Feb 04, 2013, 07:03 AM
Joined Jul 2011
thanks for help, ive tryed bluetooth gps by googoo android and looks great (saw info displayed from plane)but not sure if i can save track to look at after flight, and my tracks looks good too but and has option to save track but cant seem to get my tracks to recognize my external gps
Old Feb 04, 2013, 07:10 AM
fpvk1 is offline
fpvk1's Avatar
Joined Sep 2012
bt.gps for android is too get your phone recognise the gps..
mytracks is to save the flight...works great
Old Feb 04, 2013, 07:14 AM
Joined Jul 2011
thanks again, will play around with them again in the morning
Old Feb 04, 2013, 01:07 PM
GLADUS63 is offline
Find More Posts by GLADUS63
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
gps coordinate of your plane on ARDUINO UNO LCD
For my back pack fpv hexacopter, I use the driver only and pick from it the gps coordinate, and send it to an arduino UNO board with lcd shield to display and keep the plane location
I put an old myflydream driver with an arduino UNO + shield in the same box
here is the code I use, gps tx connected on pin3 :
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
#include <TinyGPS.h>
LiquidCrystal lcd(8, 13, 9, 4, 5, 6, 7);
TinyGPS gps;
#define RXPIN 3
#define TXPIN 2
SoftwareSerial nss(RXPIN, TXPIN);
void gpsdump(TinyGPS &gps);
bool feedgps();
void printFloat(double f, int digits = 2);
void setup()
  Serial.begin(115200);
  nss.begin(38400);
  lcd.begin(16, 2);
  //Print a message to the LCD.
  lcd.print("Elaboration");
  lcd.setCursor(0,1);
  lcd.print("coordonnees GPS");
  //We test the version of the library
  Serial.print("Testing TinyGPS library v. ");
  Serial.println(TinyGPS::library_version());
  Serial.println(sizeof(TinyGPS));
  Serial.println();
void loop()
  bool newdata = false;
  unsigned long start = millis();
  while(millis() - start < 5000){
    if (feedgps())
      newdata = true;
  if (newdata)
    Serial.println("Acquisition Data");
    Serial.println("————-");
    gpsdump(gps);
    Serial.println();
void printFloat(double number, int digits)
  // Handle negative numbers
  if (number < 0.0)
     number = -number;
  // Round correctly so that print(1.999, 2) prints as "2.00"
  double rounding = 0.5;
  for (uint8_t i=0; i<digits; ++i)
    rounding /= 10.0;
  number += rounding;
  // Extract the integer part of the number and print it
  unsigned long int_part = (unsigned long)number;
  double remainder = number - (double)int_part;
  // Print the decimal point, but only if there are digits beyond
  if (digits > 0)
  // Extract digits from the remainder one at a time
  while (digits-- > 0)
    remainder *= 10.0;
    int toPrint = int(remainder);
    remainder -= toPrint;
  float flat, flon;
  lcd.clear();
  gps.f_get_position(&flat, &flon);
  Serial.print("Lat/Long(float): ");
  printFloat(flat, 5);
  Serial.print(", ");
  printFloat(flon, 5);
  lcd.print("lat:");
  lcd.print(flat,5);
  lcd.setCursor(0,1);
  lcd.print("lon: ");
  lcd.print(flon,5);
  feedgps();
bool feedgps()
  while (nss.available())
    if (gps.encode(nss.read()))
      return true;
  return false;
I think it nice improvement of the myflydream system.
Cedric
GLADUS63 is offline Find More Posts by GLADUS63
Old Feb 04, 2013, 03:11 PM
bjornthans is offline
Find More Posts by bjornthans
bjornthans's Avatar
Norway, Troms, Skjervoy
Joined Jul 2012
orux maps is the real deal :-)
QUOTE=marty_mcfly;24028847]hi i am looking for good android ap to record track in case of lost plane so i can find the plane with last last gps coordinates can anyone recommend a good one to get for myflydream?[/QUOTE]
bjornthans is offline Find More Posts by bjornthans
Old Feb 05, 2013, 09:32 AM
ilipin is offline
Find More Posts by ilipin
ilipin's Avatar
Россия, Пермский край, город Пермь
Joined Jul 2011
Originally Posted by ilipin View Post
Hello.
Have a problem.
I try to fly today, but AAT Driver V3 does not work completely. When it switch on there is no lights, no Rx and GPS signlas, bluetooth device is unavailable. But tracker switched on, made a calibration.
The weather was cold today, about -20C. May be problem appear after using on this temperature. Quickly after I deploy all FPV equipment, my laptop "see" AAT device, but connection failed. After this laptop not see this device entirely.
At home I test AAT tracker and see same negative results. Now I stayed without antenna tracker.
Before I see problem with AAT Driver when try to fly at -25C outside. But at home, and with -15C outside system woks fine many times.
MyFlyDreams, helps me to resolve problem!
I resolve problem with MyFlyDreams support and my friends advice.
I changed 7805 voltage regulator to new one. Old given about 1.5v.
ilipin is offline Find More Posts by ilipin
Old Feb 06, 2013, 01:25 AM
sparkyincali is offline
Find More Posts by sparkyincali
United States, CA, Soquel
Joined May 2011
So a few questions? Does the MyFlydream hold last position if it loses the data signal or does it reset to a certain position? Anyone using this with the ezosd and using the Telefly just to send gps data to the tracker? How well does it update and track? I am currently using the Skylark tracker and have a few issues with it.One if you lose the downlink to the tracker it points north instead of holding last position,two the blutooth output send out their own stream of data and not just a Nema output and last when using the convert module with my ezosd it doesnt seem to track as well as it did when I was using the Skylark osd.
sparkyincali is offline Find More Posts by sparkyincali
Old Feb 06, 2013, 07:22 AM
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
I am using the MyFly with the DOSD, when I loose tracking it will hold the last position. I think you can also rotate it by hand at that point, I might be wrong on that part. I rarely loose tracking, and I've been to about 5 miles, but I did just have a video transmitter start having problems with the audio channel and that was causing the lose of tracking.
I really like the MyFlyDreams and wish they would release there own OSD with return to home and auto pilot. Don't get me wrong the DOSD is great but I would like to see how the MyFly would be.
metalbender4by is offline Find More Posts by metalbender4by
Old Feb 07, 2013, 06:16 AM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
video loss during turning
Whilst I have had the MFD for nearly a year I have only played with it around the yard. I find that the video signal drops out/snowy when the tracker spins.
Anyone else have this issue? I figure it is a slipring problem but I don't want to open it up ...springs spring!
Imagecatcher is offline Find More Posts by Imagecatcher
Old Feb 07, 2013, 06:26 AM
GLADUS63 is offline
GLADUS63's Avatar
Joined Jul 2009
I use the nmea from the driver for displaying the coordinates of the planes, even if it loose audio, at least I have the last coordinates.
Cedric
Old Feb 09, 2013, 12:23 PM
RCManiacPHCB13 is offline
Find More Posts by RCManiacPHCB13
Jake B.
RCManiacPHCB13's Avatar
United States, PA, Allentown
Joined Jun 2012
Hey guys, I saw you were talking about the bluetooth function with the tracker. I ordered a bluetooth board when I got the tracker. I don't have any android products, just apple. I would prefer not to jailbreak anything either.
Have any of you found apple applications that work with the MFD tracker and its bluetooth board on an apple device?
Any help is greatly appreciated,
Jake
RCManiacPHCB13 is offline Find More Posts by RCManiacPHCB13
Old Feb 09, 2013, 04:22 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Jake
Hi Jake,
a very good app for tracking is motionx-gps. full support of online map position, record track (position, height, speed) and export via e-mail as google-earth track.
but you have to jailbrake your device and install "bt-stack gps" from cydia! without bt-stack no apple-app accepts gps-data via bluetooth.
cu Thomas
Thint1 is offline Find More Posts by Thint1
Discussion Camera tracking instead of antenna tracking jphong FPV Talk 3 Jan 16, 2015 09:56 AM
Discussion antenna tracking with rssi voltage atari7202 FPV Talk 8 Feb 05, 2011 12:33 PM
Joke Maybe the Best Blonde Joke Ever! dumbthumbs Humor 5 Dec 11, 2009 04:42 PM
Discussion CATPart's Tracking Antenna CATPart FPV Talk 23 Oct 11, 2009 04:24 PM
Discussion CATPart's Tracking Antenna CATPart UAV - Unmanned Aerial Vehicles 15 Sep 06, 2009 06:53 PM
