This thread is privately moderated by Pilebuck, who may elect to delete unwanted replies.
Old Dec 14, 2009, 10:26 PM
Pilebuck is offline
Find More Posts by Pilebuck
Carbon User
Pilebuck's Avatar
YAL
Joined Jun 2005
2.4 conversion
Since I'm basically computer illiterate, don't have an I-Pod, and am too stupid to find the address book on my smartphone, I've decided to try and reverse this trend by not being the last RC'er to convert to 2.4Ghz.
I've chosen the Spektrum equipment because I fly JR, and more importantly Spektrum offers the widest selection of 2.4 receivers in the industry. Specifically the "carbon" versions of the various products since I have many full carbon models that may or may not present a challenge to convert. I also had a sneaking suspicion that I could modify the stock Spektrum gear to better suit my needs... But I'll get to that later.
The Ceres drew the short straw and therefore she will be the first to undergo a brain transplant.
First things first; let's disect some of these little 2.4 critters and see what's inside...
Further... >comments.
Pilebuck is offline Find More Posts by Pilebuck
Old Dec 14, 2009, 11:05 PM
Pilebuck is offline
Carbon User
Pilebuck's Avatar
YAL
Joined Jun 2005
2.4 conversion - Ceres
The Ceres was a pretty straight forward conversion.
I used a Spektrum AR9300 which has two integral carbon receivers and an additional tail-mounted carbon receiver.
The main reason I have not wanted to make the conversion to 2.4 is the hideous looking "whiskers" that must protrude out of the fuse... I decided to make mine retractable so that I could at least stomach the look of the model when sitting here at home.
Old Dec 14, 2009, 11:48 PM
Pilebuck is offline
Carbon User
Pilebuck's Avatar
YAL
Joined Jun 2005
2.4 conversion - ceres
On to the rear mount receiver.
I originaly thought I may have to de-case the remote receiver, but as it turns out the Ceres had enough room in the fuse aft of the linkages for a standard carbon remote.
A 50" remote antenna extension had to be soldered up in order to reach the RX... I know Spektrum only recomends 36" as the maximum length, but I extended it anyway.
Since I imagine the 36" limit is set to avoid a possible low voltage condition resulting from the wire run, I decided to do a simple test to verify voltage to the tail RX. This was achieved by hooking up a variable discharge source into the onboard electronics while powering the receivers with a small AAA battery... I was not able to get the rear receiver to brown-out before having the forward receivers also brown-out... So in my opinion, the additional wire run will have no effect on the rear receiver's performance.
FYI, when hooked to my standard four-cell 2/3 SubC onboard battery, I was unable to induce a low voltage condition with my three amp discharge source.
Alert Multiplex Evo 2.4 conversion w/Hitec AFHSS (Digital interface update) MikeMayberry Radios 309 Apr 26, 2014 09:31 PM
Question Ordering 2,4 gHz conversion for FF9 michel Radios 2 Nov 29, 2009 12:50 PM
Found Spektrum DM9 2.4 Conversion Module skewba98z28 Aircraft - General - Radio Equipment (FS/W) 2 Sep 16, 2009 12:56 PM
For Sale Ftuaba 9 Cap 2.4 Spektrum Conversion ( Very Nice ) Aero12 Aircraft - General - Radio Equipment (FS/W) 2 Sep 16, 2009 06:46 AM
Discussion Futaba 9ch 2.4 conversion Frenchy520 Radios 2 Sep 09, 2009 08:44 PM
