Old Dec 14, 2009, 05:58 PM
Yellow Baron is offline
Find More Posts by Yellow Baron
Back in the game.
Yellow Baron's Avatar
3" from insanity, 2' from the computer ,Richford, Tioga county, Southern Tier, New York, U.S., North American Continent, Northern hemisphere, Earth, The Sol System, Milkyway Galaxy, The Universe, The Current Dimension, Your Selected Realm of Reality.
Joined Dec 2006
Build Log
Clipper ship pond sailer.
Well, after looking at Brooks' and MeatBomber's square riggers and realy thinking it though to the point where a materials list is made, I'm going to give it a go and try to build a 4 channel roughly 3 foot pondsailer-scale clipper ship. The hull will be laminated 1/4thick balsa sheet, just like how MeatBomber built his 'Somers' brig-of-war. I'm not building a particular clipper per-se, but a stylized model of what they are in my mind; as such it is going to be more of a pond sailer than a full blown scale model, no ships wheel, little figures, railings, or anything like that. I'm going to TRY to replicate the full rigging job as best I can.
Now on to the specs:
LOA: 2.992 feet (912mm)
Beam: 6" (152mm)
Draft: ~3" (~76mm)
Displacement: 8 pounds (3.63Kg) (that's what Delfship is saying anyway)
Yellow Baron is offline Find More Posts by Yellow Baron
Old Dec 15, 2009, 05:20 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
great On a lesson learned note, i went only up to the deck line with my laminations, not a good idea i had to build teh bullwarks up later on which was a major PITA so get teh whole shape stacked up and hog it out before you glue and your ship will be a lot smoother than mine
mind attaching teh delfship mopdel in your thread?
meatbomber is offline Find More Posts by meatbomber
Old Dec 15, 2009, 08:22 PM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
YB, that will be neat. Depending on what you are trying to achieve, you might consider my experience: I found that the more closely I duplicated the rig of a real ship (spar lengths, spar positions on their masts, shape of fore&aft sails, etc.), the better my models looked. In fact, whenever I took a shortcut and just winged-it, I ended up with something less realistic looking :-).
Brooks is offline Find More Posts by Brooks
Old Dec 16, 2009, 09:15 AM
Back in the game.
Joined Dec 2006
MB, point noted, thanks I attached the pics of the model.
Brooks, that's the plan .
Old Dec 16, 2009, 09:20 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
Great model Fred
i`ve not yet succeded to make it the way you do mate i`m always taking the generic hull and then modify it till the lines lookabout the same as in the lines plan of the template. How`d you get it to work with one control line and then added all the points singly?
Old Dec 16, 2009, 11:00 AM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
if the scale sail section comes alive, get the build log going there
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Dec 16, 2009, 05:26 PM
Back in the game.
Joined Dec 2006
Sorry MB, you've lost me there (control line??) . What I did was open a new model, punch in the length (3 feet), draft (0.25 feet if I remember correctly), the beam (.5 feet), verticle points (5, to start), and finaly horrizontal points (15; each end, plus the 13 crossections on the drawing). I roughed out the shape with those points; then used the 'Sub-Divide Control Net' feature and refined the shape with those, repeating untill I was happy with the 3D model.
Ghost, will do
On a side note (only Delftship related), I'm going to try tonight to render a Sikorski S-69 helicopter fuselage for my little coax (hmm, clipper ship with a helipad...), should be interesting at least to see how complex of a shape the program can do.
Here's some pics of various clippers underway (and my sailplan):
Old Dec 16, 2009, 07:45 PM
Brooks is offline
Brooks's Avatar
Joined Aug 2003
The Flying Cloud has a beautiful sailplan, plus was a very famous clipper. The big, deep topsails show she was a ship of the 1850's; later ships, eg. the tea clippers (Cutty Sark), split the topsail to make handling easier. I like the big topsail :-)
Old Dec 17, 2009, 10:05 AM
Back in the game.
Joined Dec 2006
I agree 100% Brooks . The only thing I think I'll change with that plan is the jibs, space them out verticaly a little more.
Old Dec 17, 2009, 10:34 AM
Back in the game.
Joined Dec 2006
I'm going to try to recess the deck by about a quater inch (6.35mm) at the lowest point along the top line of the hull, any thoughts as to how to do this? I'm going to layer the balsa from the bottom up to give it that planked look (I'm going to stain, not paint, the hull), that that sould only complicate things by about 200%
Old Dec 19, 2009, 02:17 PM
Back in the game.
Joined Dec 2006
Quick update: I think I've got my hull colors figured out (once again borrowing from the J-class yachts). The dark blue is just that DARK, I mean nearly black when you look at it. Once I have the parts for the hull (hopefuly Santa will be so kind ), I think I will go and get some wood stain custom mixed for me .
Old Dec 19, 2009, 06:53 PM
Brooks is offline
Brooks's Avatar
Joined Aug 2003
For your deck, you could always just add a deck support rail after you carve out the hull. John did that for his Berbice hull. If you are using balsa, she will be light enough that you could also just leave her thick under the point you want the deck to rest, making an integral rail. I did that with Aldebaran, but the heavy wood and extra thickness from bilge to the rail made the hull heavier than desired.
Old Dec 20, 2009, 03:52 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
Ah and fred study carefully Brookses layout of his servo and the distance of them from the masts... i carelessly thought i could space them further to prevent overlaps and now i`m having troubles routing the braces as the area i`d like to have the braces run to are getting overlapped by the other brace servo arm! At least for my fore braces its like that... so a bit closer together and further away from the masts would have been better... staggered in high so as to have some room between your arms and you can fit a disk that covers the servo arm over the lower servo.. i thought i had it right until now when i`m triying to actually fit the lines
The deep clipper fuse should help you in these aspects.
Old Dec 20, 2009, 07:58 PM
Back in the game.
Joined Dec 2006
Brooks,
correct me if I'm mistaken; basicly take a bit of balsa and glue it to the deck along the perimeter?
MB, sounds like you got your self in abit of a pickle . I'll try to remember to keep everything from messing everything else up.
Old Dec 21, 2009, 02:50 AM
Brooks is offline
Brooks's Avatar
Joined Aug 2003
The balsa or basswood strip, say 1/4" square, is glued to the hull, to make a support "rim" for the deck. The deck is then glued or screwed to the strip.
Discussion A 4-masted barque pond sailer Brooks Scale Sailboats 106 May 26, 2016 08:03 AM
Discussion A topsail schooner pond sailer Brooks Scale Sailboats 73 May 14, 2015 10:20 PM
Build Log Clipper ship pond sailer. Yellow Baron Scale Sailboats 130 Aug 17, 2012 02:25 PM
Discussion Need help to Identify this pond sailer Aten W Arthog Sailboats 8 Jul 14, 2007 10:25 PM
Sold Uss Constellation Tall Sailing Ship (Square Rigger - Really Sails) Pond Sailer Or Rc flightdog Boats (FS/W) 0 Feb 03, 2006 01:31 PM
