Old Dec 14, 2009, 05:11 PM
dizzymarkus is offline
Find More Posts by dizzymarkus
Team Mulikow 3D ---- :0)
dizzymarkus's Avatar
Oswego, NY
Joined Sep 2007
how to mount the vapor brick ?
whats the best way to "stick" the vapor brick to my foam model please?
hot glue?
small amount ca
silicone
velcro (will it hold the servo pressure)
I need to mount it flat on top of a mini pizza box flyer ;0)
Thanks greatly for any tips,
Markus
dizzymarkus is offline Find More Posts by dizzymarkus
Old Dec 14, 2009, 05:30 PM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Markus,
1) A dap of hot glue will work.
2) I would not use CA. It can find its way into the servos and will be difficult to remove.
3) Silicon will also work.
4) I haven't tried this one personally, but am about to. I think that regular Velcro will allow the brick to move and cause some mush in your controls. However, 3M Dual Lock may do the trick, as the distance between the hook and latch is very small.
http://bsdmicrorc.com/index.php?productID=690
-PC49
PiperCub49 is offline Find More Posts by PiperCub49
Old Dec 14, 2009, 06:19 PM
olmstead25 is offline
Find More Posts by olmstead25
Parkzone connectors here!!
olmstead25's Avatar
Joined Oct 2008
i have always used a small drop of hotglue. its not going to hurt anything if if comes of in a hard crash (as long as you dont hotglue wires) and is also clean when or if you want to remove it for your next model. i have also herd of people using double sided tape or servo tape which i have not tried but would imagine would be close to the same.
olmstead25 is offline Find More Posts by olmstead25
Old Dec 14, 2009, 07:43 PM
Oswego, NY
Joined Sep 2007
thanks greatly for the responses -- I thought hot glue would be cool but thought I would ask first ;0) heres the project -- gotta figure linkages and Ill be ready I think lol
Markus
Old Dec 14, 2009, 07:51 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Very cool!
Old Dec 16, 2009, 07:37 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Markus
Hey, it's a peaNUTBALL.
Petefoss is offline Find More Posts by Petefoss
Old Dec 17, 2009, 02:42 AM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
i glue with UHU-poor and let it dry 5min, then it gets a bit harder and sticky but with no "strings". Dont use Ca or Servotape that will stick forever and ruin the board if you try to remove it.
Meshuggah is offline Find More Posts by Meshuggah
Old Dec 17, 2009, 07:00 AM
Oswego, NY
Joined Sep 2007
lol at the peanutball heheheh
Thanks for the responses -- I used hot glue which was nice because I mounted the brick to soon and had to take it off again -- nice and clean :0)
Im not a super fast builder and ive taken a few steps back ;0) I will post pics later
thanks again fellas,
Markus
Old Dec 17, 2009, 04:54 PM
56S is offline
56S
Find More Posts by 56S
56S
Certified Balsa Breaker
56S's Avatar
Joined Nov 2006
A very common mistake to to make structure too strong when building light. Figure like the big boys do. Your max load x 150% and design for that. Using that formula, a very small amount of gllue would be needed to hold the brick in place.
56S is offline Find More Posts by 56S
Old Dec 17, 2009, 09:07 PM
olmstead25's Avatar
Joined Oct 2008
i would tend to disagree on these small indoor jobs. weight is everything on these and a few grams of overbuilding could be the differance in a plane thats fun to fly versus a plan that is slugish or mushy and no fun at all. "if you cant break it then it weighs to much"
Old Dec 18, 2009, 11:14 AM
56S is offline
56S
56S
56S's Avatar
Joined Nov 2006
I think you agree with my statement. Build your plane to take the required air loads not the occasional ground load. Building light has been a challenge and an enjoyable one at that. In my glow days we had to build a robust firewall and airframe just to withstand the harsh vibration of the single cylinder two stroke motor and the man-handling required to hold the plane while starting said beast. I now build my airframe with release their mass upon a "landing" My motors have come loose, the lipos have moved and even the servo tray has been sacrificed to save the airframe. One time I landed 1/2 throttle 6' off the ground on the side of a lightpole.
Old Dec 18, 2009, 01:54 PM
olmstead25's Avatar
Joined Oct 2008
i am sorry. misunderstood. i do indeed agree with you!
Old Dec 18, 2009, 03:23 PM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
I use double stick foam tape to mount my bricks since they are easier to remove with out damage. But if I really want more permanancy I use foam mounting tape and a dab of hot melt glue to stick it good! Then the foam will release the brick without the ever larger hot melt glue build ups that will only increase over time. I often use the foam just for that reason! When I mount servos (AS2000's) I almost always use both. I can always slit the foam tape instead of a risk of circuit board cracks.
MUTCAKE is offline Find More Posts by MUTCAKE
Discussion vapor brick plane the riot Vintage & Old-Timer Designs 9 Dec 17, 2009 07:12 AM
Discussion Vapor brick Woes.... AustinTatious Scratchbuilt Indoor and Micro Models 4 Dec 04, 2009 03:38 AM
Help! Vapor brick servo only drives one way Daddymonkey Scratchbuilt Indoor and Micro Models 6 Dec 02, 2009 10:07 AM
Discussion Vapor and Sukhoi Brick: How Reliable, Durable and Easy to Maintain? flying-llama Micro Ready-to-Fly 2 Nov 02, 2009 11:05 PM
Question how to swap rudder and aileron on vapor brick? indoor_fr Scratchbuilt Indoor and Micro Models 3 Oct 28, 2009 05:49 PM
