Old Dec 13, 2009, 10:24 PM
Warthog_Fan is offline
Find More Posts by Warthog_Fan
United States, NY, Endicott
Joined Jun 2006
Question
What do you recommend as a good CAD program for model design
Hi All,
I've just started looking into designing some models of my own from scratch, and it seems like a good CAD program which could be used to output files that could be used to plot the plans and component drawings would be better than trying to use the T-square and triangle method. While I enjoyed mechanical drawing in high school, I no longer have a drafting board large enough to do the required plans, and I wouldn't have any place to store it when I wasn't using it.
I have a copy of Profili which I use to generate rib templates and it can output DXF files, which I believe are used by CAD programs. I would like a program that could be used to import DXF files, allow the rest of the plans to be drawn, and then output a data file that could be taken to Kinko's and used to print a full sized set of plans.
I've heard of Model CAD, and I'm sure that there are other CAD programs on the market, but can any of you suggest an application that would do what I've described above and also be relatively easy to use?
Thanks in advance.
Bob
Warthog_Fan is offline Find More Posts by Warthog_Fan
Old Dec 14, 2009, 05:44 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Turbocad and Corel draw are the two favourites here. I found the move from board and pencil easier to make to Corel.
Rhino is the equivalent of Corel in 3D and Solidworks the equivalent of Turbocad.
Old Dec 14, 2009, 07:27 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Your head, you heart, your imagination, and a roll of paper.
eflightray is offline Find More Posts by eflightray
Old Dec 14, 2009, 07:29 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The alternative seems to be a cad program, , a bog standard home printer, loads of sheet paper, and a lots and lots of sticky tape.
Old Dec 14, 2009, 09:09 AM
coosbaylumber is offline
Find More Posts by coosbaylumber
Joined Jul 2005
As mentioned, use what you got right now. Do not invest another nickel into some software that is going to become obsolete come January first of 2010.
Invest into some adult high school training instead. From there learn the basics, and then you can aask the intelligent question to the salesman when you are examining the box the software came in.
How does this work with....
Do I need a special printer or can I use what I got here....
If I decide to add on a ____ what drivers do I need to make it work then....
Most of the above you cannot get off the side to the box, other than.. "Powerfull, " You can do... or how about Compatible with other users.....
I have read of quite a few on the sides thereto, but never 'Go to School before using this product. Do not use this product unless properly trained.'
Wm.
coosbaylumber is offline Find More Posts by coosbaylumber
Old Dec 14, 2009, 11:04 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
have a look at devcad for the price it is good software
i use auto cad and prefer ver 2006
it depends on Wat you wont to do and how long you wont to spend in front of a computer you can pick up old ver of acad of the net
dpot is offline Find More Posts by dpot
Old Dec 14, 2009, 11:10 AM
mcg is offline
mcg
Find More Posts by mcg
mcg
Joined Jul 2005
I notice the author of Profili now has a program for fuselages.
I use AutoCAD 2008 and Rhino3D, about 5% and 95%, respectively. Rhino has a little galaxy of "plug-ins", many of them free, which you can use for specialized tasks, e.g., gearboxes, airfoil downloads.
But I started with AutoCAD, and took a 4-day course in it. I agree with Will on the value of some kind of formal training. Without that basic CAD instruction I probably would have had a hard time picking up Rhino. Many of these programs are derivative of AutoCAD, so it is a good place to start.
There is a valuable ongoing thread on this board for Rhino users. It might give you a sense of what can be done with Rhino3D, and of what problems and frustrations arise with it.
http://www.rcgroups.com/forums/showthread.php?t=1113526
mcg is offline Find More Posts by mcg
Old Dec 14, 2009, 01:05 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
Sketchup. It's free. Has a very active user community using it to create airplanes. Lot's of plug-in modules that add features like splines, lofting and so on. There are a number of threads in the scratch built foamies section on this. There are a whole pile of tutorial videos. Unlike a lot of free SW, this is one very high quality piece of code.
philba is offline Find More Posts by philba
Old Dec 14, 2009, 02:32 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
A quick use of the Search function will turn up legions of past threads on this exact same topic. The same question comes up at least monthly and it's been well addressed at length in the past. I'm not trying to be snarky. Just trying to save all of us re-typing the same answers again.
BMatthews is offline Find More Posts by BMatthews
Old Dec 14, 2009, 08:49 PM
mcg is offline
mcg
mcg
Joined Jul 2005
Maybe it should be a sticky.
In fact, maybe there should be an autonomous CAD forum. If we had one, this type of thread would make a logical first sticky.
Could we propose a new forum devoted to CAD or CAD/CAM? There seems to be quite a bit of interest in it.
Old Dec 14, 2009, 09:36 PM
artsmith is offline
Find More Posts by artsmith
Dunedin, New Zealand
Joined Dec 2006
After trying a number of different CAD's of various types, I finally settled on 'DevCAD' in the 'Professional' version. It has everything which a modeller needs, and has been created, I am certain, with the needs of modellers in-mind, unlike a number of others, which might be brilliant for architecture etc. but prove to be hopeless for modelling. DevCAD has a facility built-in whereby you are able to copy, assemble and scale the views of 3-view plans to best suit your own needs, then simply begin your task by tracing over the outlines to get your drawing underway. It uses 'dxf' predominantly, to communicate with the other programmes from the same source (eg 'Profili' and 'DevFus'), plus the rather more recent 'CAM' version of 'DevFUS' and the CAM version of 'DevCAD'. Everything integrates well, in a way which CAD's adapted from other purposes to modelling generally don't; at least not nearly as well. I'm currently researching various 3d CADs to assist me in what I do, plus I am also looking into computer animation software for a video organisation I belong to. I've put a fair bit of time and trouble into all of this, and still find that nothing performs better for modelling purposes all-round than 'DevCAD'. If you are lucky enough to have a local print-shop which copies and scales your model-plans to decent-sized sheets, a good 'PDF' programme is not a bad investment, either.
Ian Smith
artsmith is offline Find More Posts by artsmith
Old Dec 14, 2009, 09:42 PM
artsmith is offline
Joined Dec 2006
Just as an afterthought; 'dc1', DevCAD/DevFus's native format also allows easy integration between the programmes, so although 'dxf' is included in the packages it's not generally needed for 'in-house' work and is usually only called-for (in my case at least), if you step outside the 'Dev' stable and wish to integrate with other brands of software.
IJS.
Old Dec 14, 2009, 09:48 PM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
A lot depends on your needs too. I have tried many CAD programs and found that the plans they output were not to my liking. I have settled on Adobe Illustrator with the Cad Tools plug in. It outputs high print quality plans but will also output DXF or DWG files for laser cutting as well as PDF for plan printing. It does everything I need and more.
Mark Miller
Isthmus Models
Mark Miller is offline Find More Posts by Mark Miller
Old Dec 15, 2009, 01:26 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Not sure what you mean by that. TurboCAD is a 3D CAD program and is not all that similar to Solidworks.
Montag DP is offline Find More Posts by Montag DP
Old Dec 15, 2009, 11:48 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
aha. It wasn't last time I used it!
Question What do you recommend as a good CAD program for model design Warthog_Fan CAD/CAM 31 Feb 24, 2011 10:31 AM
Question Starting from the ground up (Including aircraft). What do you recommend? Craig9080 FPV Talk 66 Dec 09, 2009 10:45 PM
Discussion What servos do you recommend? DaveG99 Radios 3 Nov 22, 2009 02:48 PM
Discussion What do you recommend for a first slope plane? aeajr Slope 111 Nov 01, 2009 07:56 AM
What would you guys recommend as a good CHEAP electric... f2racer Electric Plane Talk 2 Nov 10, 2001 07:44 AM
