Old Dec 13, 2009, 06:51 PM
hwmccullough is offline
Find More Posts by hwmccullough
The SandMan
United States, NC, Youngsville
Joined Nov 2007
Can I use a 6 Channel E-sky radio for fixed wing airplanes?
I've seen several similar threads, but none to address this exact question. Can I use the transmitter from an E-sky Honeybee CP2 72mhz on a fixed wing RC aircraft? Not park fliers, but regular, nitro powered birds.
Thanks in advance for your answers.
SandMan
hwmccullough is offline Find More Posts by hwmccullough
Old Dec 13, 2009, 11:08 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The answer is there in the other threads. It makes no difference whether you are talking about park flyers or bigger models, they all fly the same way and the answer is the same -- no, it won't work.
The problem is that the transmitter is set up to do CCMP mixing for a CP helicopter and there seems to be no way to turn this off. Consequently, when you move the stick for aileron, three channels are affected (1,2, and 6). Same with moving the stick for elevator. And the throttle stick.
There's no easy way to unmix the output. With a regular transmitter you can just turn off CCPM.
Daedalus66 is offline Find More Posts by Daedalus66
Old Dec 15, 2009, 02:48 PM
The SandMan
Joined Nov 2007
Thanks! I was thinking it wouldn't work but wasn't sure.
Question E-Sky 4 CH Flight Simulator OR Dynam RC Tech 6-Channel vinay2070 Simulators 11 Jun 15, 2011 02:45 PM
Sold E-sky 6 channel Fm Transmitter and Reciever $30 shipped HeliStyle Aircraft - General - Radio Equipment (FS/W) 1 Oct 02, 2009 04:43 PM
For Sale E-sky 6 channel Fm Transmitter and Reciever $30 shipped HeliStyle Aircraft - Electric - Helis (FS/W) 0 Oct 02, 2009 03:42 PM
Sold e-sky 6 channel ccpm radio and rec can be used as airplane also rudyhal Aircraft - General - Radio Equipment (FS/W) 2 May 24, 2009 08:50 PM
Sold E Sky 6 channel radio and receiver 72MHz Dan Halverson Aircraft - General - Radio Equipment (FS/W) 2 Jan 15, 2009 12:41 AM
