Old May 03, 2012, 03:45 PM
Lantsov Alexey is offline
Find More Posts by Lantsov Alexey
Lantsov Alexey's Avatar
Russian Federation, Saint Petersburg, St Petersburg
Joined Jan 2009
George.
Hacker was unsuccessfully revamped, little pulls.
Lantsov Alexey is offline Find More Posts by Lantsov Alexey
Old May 05, 2012, 05:02 PM
Ampbomber is online now
Find More Posts by Ampbomber
Ampbomber's Avatar
Michigan
Joined Aug 2002
Originally Posted by Lantsov Alexey View Post
George.
FYI
That's strange. I pulled my modified Hacker A10-15s out of my Relax2 and weighed it. It weighs 11.6 grams with mount and pulls my 123 gram Relax2 (seen in video) without any problem. I beleive it weighed close to 11 gm without the mount.
This was my first attempt to lighten any motor and I think I could have gone a lot lighter.
What could have gone wrong with your friends A10-15S mod?
Ampbomber is online now Find More Posts by Ampbomber
Old May 06, 2012, 04:03 AM
asw is offline
asw
Find More Posts by asw
asw
Joined Apr 2011
Originally Posted by Ampbomber View Post
FYI
Description: Name: IMG_1368.jpg
Description:
Here my "tuning" of the motor Hacker A10-15S
Му plane weighs about 90 grams.
According to video it is visible that power not enough.
http://www.youtube.com/watch?feature...&v=LMDkjYjIS_0
probably reason not in the motor, and in the cheap Chinese noname controler,or prop 9x2 too big.
In the next season I will replace the motor and the controler, then it will be possible to do conclusions.
asw is offline Find More Posts by asw
Old May 06, 2012, 07:27 AM
Ampbomber's Avatar
Michigan
Joined Aug 2002
[QUOTE=asw;21531962]Attachment 4839921Attachment 4839922
QUOTE]
AWS,
Here is some info on my A10-15S mod.
I wish I had seen your mod before I had done mine. Some better Ideas with yours.
The problem I encountered with my mod was that I got a lot of metal shavings between the magnets from lathing the bell (?) diameter. It took me quite a lot of time to get all the metal shavings out from between the magnets.
I put together a test stand and ran the motor this morning. Results posted. Don't know if this will help you determine why your motor seems weak.
. I had used a different controller in my Relax2 and the motor would not start all the time (hand slap to start) but ran without any problems. I ran this test with a Turnigy 6A and had no problems with motor starting.
Hope this helps.
George
Old May 06, 2012, 10:21 AM
asw is offline
asw
asw
Joined Apr 2011
George, what type of a battery you use?
Old May 06, 2012, 10:41 AM
Ampbomber's Avatar
Michigan
Joined Aug 2002
For the test it was a 2S Rihno 360 mah fresh off the charger.
Old May 06, 2012, 02:52 PM
asw is offline
asw
asw
Joined Apr 2011
George, look at my stand
Description:
Hacker with prop 9х2
middle I=1,75A rpm=3000 trust=90gr
at max I=2,75A rpm=4500 trust=145g
my next motor has more diameter of rotor than Hacker and weight 12g, but
prop 9x2
middle I=1.5A rpm=3000 trust=90g
max I=2,5A rpm=4800 trust=165g
George, current 5А and a battery 360ma too much for f3p, I use batteries 120mа
I think that Hacker is bad motor for big prop(9inch) and small current, because the small size rotor.
It is necessary a little bit more rotor and everything will be OK.
Old May 07, 2012, 06:45 AM
Ampbomber's Avatar
Michigan
Joined Aug 2002
Hi ASW.
Let me explain, I'm not a contest flyer, I'm almost 70 , just really like to build different aircraft and enjoy modifying just about everything. Also, I'm not a very good flyer.
I understand, as a contest flyer, your concern for light weight. I also use Hyperion 120 G3 cells rated at 25/45 C for some of my smaller aircraft but my Relax2 is a little over weight so it is set up to use the 360 pack. I'm not proud of how heavy it turned out but it really flies well at 123 gm.
The reason I got involved in the A10-15S conversation is that back in post 346 Lantsov infered that your modifacation of the A10-15S caused it to have "little pulls" and I find that mine appears to perform just as well as a stock A10-15S.
If you could, to put this contraversy to rest, run a GWS EP-8043 and let me know the results. I would run a 9x2 here but I don't have on.
BTW, nice test stand. I'll have to think about building one.
George
Old May 10, 2012, 08:30 AM
Joined Jan 2009
That is amazing! Great inovation. Waiting for the video.
George
20120506235535 (1 min 10 sec)
Old May 10, 2012, 11:53 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Congratulations Alexy
great to see something new in the way of a concept
Andycap is offline Find More Posts by Andycap
Old May 11, 2012, 04:14 AM
Ampbomber's Avatar
Michigan
Joined Aug 2002
Lantsov,
Nicely done! Wish I had your talent. Keep up the inovations.
Now you can fly in between flight layovers
George
Old May 12, 2012, 02:24 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Beautiful! It is like there is no gravity in the room.
marhar is offline Find More Posts by marhar
Old Jun 18, 2012, 05:25 PM
sps3172 is offline
Find More Posts by sps3172
United States, MO, St Louis
Joined Oct 2006
I just wanted to bump the questions below as I never saw a reply.....
It seems these 'magic' silver tubes are one of the keys to pulling this techique off....
Originally Posted by crossup View Post
No so simple over here.
First off, what is the weight of the fabric and the weave
Second, is it prepreg or if hand wetted, how is resin applied and is it polyester, vinylester or epoxy?
Sounds like your using an inside mold and pressurizing, I assume the mylar prevents the pressure from migrating thru the cloth so it is like vaccuum bagging in reverse.
How is the finished tube removed? Is a release agent involved?
"Insert inside the matrix"? sounds simple, just try it with a one meter noodle, NOT easy unless you have figured a solution.
Perhaps A. Kashkin could provide some photographs of the process
and last question is the matrix heated to cure the resin?
sps3172 is offline Find More Posts by sps3172
Old Sep 11, 2012, 04:49 PM
Joined Jan 2009
Hi Guys.
Started the new season.
Allow me to present the final version of my Volumes aircraft.
The photo model "CARBONIC"
Old Sep 11, 2012, 04:59 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Wow! That looks great! What's the AUW?
Free
Free is offline Find More Posts by Free
Build Log VIDEO ADDED: Pro Design F-18 Build MattinAZ Electric Ducted Fan Jet Talk 871 Jun 25, 2014 02:36 AM
Discussion EJF Composite F-86 Reco Electric Ducted Fan Jet Talk 11 Jan 08, 2010 03:23 PM
Question Composite Arf P-51 Engine ? ? ? dono Fuel Warbirds 0 Dec 04, 2009 06:36 PM
Idea Composite D Box Design j.m. Composites Fabrication 4 Sep 02, 2009 03:38 AM
Jet Design Contest entry #3 -- Messerschmitt Me P.1092/5 berniep1 Electric Ducted Fan Jet Talk 79 Nov 22, 2007 06:46 AM
