Old Dec 12, 2009, 08:08 PM
Chophop is online now
Find More Posts by Chophop
Glad I'm not a Boll Weevil
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
Wing Tips Tips
So far every time I built a wing it goes well up to the tips. There are several types I know of, the Hoerner, Rounded, Flat cut-off, and chord line runner.
The Hoerner is the easiest I have covered because the 45* cut leaves a nice big area to overlap the top and bottom sheet. Great for smaller wings but it takes a big chunk of balsa to cut and carve for a 10 inch or longer chord. And it takes a tip-ground snag well. They add lots of strength to the tip.
Rounded looks very tricky to apply covering, I haven't covered one yet. And this one also takes a big chunk of wood.
Flat cut-off is another easy cover but looks like it will need lots of support to keep the rib from bowing in or breaking from cover tension. And by that I mean does the ledge run along the chord line ? Seems that type could make a rolling tendency if the ledge is not closely running along the chord line.
Chord Line Runner is not an official name, but that's what I call it. It is a ledge of balsa that sticks out spanwise and runs along the chord line. It leaves angled ends on the top and bottom since the chord line is somewhat along the vertical middle of the rib. Looks like the easy out for amount of material, ease of covering and weight.
But how does it perform ?
I read that our 6 foot and under wings really do not have enough surface area to make subtle curves mean much, just not enough area to get airflow trained.
Any suggestions and especially about the chord line runner type ? Exactly how to orient the runner is what I need to know.
I'll dig up some photos as soon as I find some, or someone else who has examples ready could show 'em pretty please.
Ch
Chophop is online now Find More Posts by Chophop
Old Dec 13, 2009, 09:49 AM
Chophop's Avatar
Joined Sep 2006
Here's a little bit I found on tips. Still not to my liking, but I may go with a flat cut with a small winglet.
http://homepage.eircom.net/~justsoun...s/wingtips.htm
CH
Old Dec 16, 2009, 08:35 PM
Chophop's Avatar
Joined Sep 2006
So far I decided to make square cut tips, cover the panel, then screw a slightly rounded block over the tips, maybe 1/4 or 3/8 inch thick, just to help the air get around them easier. Then I can unscrew the tips to do any Monokote touchup or wing repairs.
Ch
For Sale Soprano wing tips rlbpilot Aircraft - Sailplanes (FS/W) 5 Dec 08, 2009 03:42 PM
Question Rounding wing tips thurps Slope 22 Nov 26, 2009 08:14 AM
Discussion supra wing tips with no spars fishdude Composites Fabrication 0 Sep 12, 2009 11:40 AM
Discussion Tiger moth wing tips Dervall The Builders Workshop 20 Sep 11, 2009 05:50 PM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
