Old Dec 12, 2009, 03:03 PM
moti is offline
Find More Posts by moti
israel
Joined Jun 2003
2.4 Mhz amplifier
Hi all
Can I use this amplifier to boost 2.4 Mhz modules??
http://cgi.ebay.com/Internet-1W-30DB...item3a5594cf09
Have a nice day
moti is offline Find More Posts by moti
Old Dec 12, 2009, 06:24 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I do hope not.
Daedalus66 is offline Find More Posts by Daedalus66
Old Dec 12, 2009, 07:29 PM
onewasp is offline
Find More Posts by onewasp
USA
Joined Sep 2003
Originally Posted by Daedalus66 View Post
I do hope not.
I'm with you.
Perhaps a failsafe will occur -- such as instant smoke.
onewasp is offline Find More Posts by onewasp
Old Dec 12, 2009, 07:37 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
You could, given the right cable adapters... but why? It's not going to give you a great deal more range, because 2.4GHz is pretty strictly line-of-sight at long ranges anyway.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Dec 12, 2009, 08:29 PM
teamdavey is offline
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
To quote Jurassic Park - just because you can does not mean you should
teamdavey is offline Find More Posts by teamdavey
Old Dec 12, 2009, 08:48 PM
CyberJay is offline
Find More Posts by CyberJay
Rsetiegerd Uesr
CyberJay's Avatar
USA, AR, Cave Springs
Joined Apr 2005
If you're wanting to boost 2.4Mhz I would highly recommend this unit. I had one, loved it, wish I never sold it.
Hope that helps.
-Jay
CyberJay is offline Find More Posts by CyberJay
Old Dec 12, 2009, 09:01 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yes you could likely use it. You would need to test it and range test it though to be sure.
It might have some charateristics where it might broadcast on a wider range say several channels. But it is hard to say until one tries it out.
If you were in the USA it would be illegal to do so though. Albeit they let them use it for WiFi indoors, it is illegal for RC users to use it on their TX's.
I do not know if it is illegal in your country for RC purposes or not though.
earlwb is offline Find More Posts by earlwb
Old Dec 12, 2009, 09:53 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
I have heard of guys using something similar to boost their range for long range FPV flights...but again its illegal in the US.
ATIS is offline Find More Posts by ATIS
Old Dec 12, 2009, 11:13 PM
Joined Jun 2006
No, it is NOT illegal in the US. That depends on what antenna you use, and there are plenty of legal choices. It's not even a bad idea, just rather pointless.
Old Dec 13, 2009, 07:43 AM
CyberJay is offline
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
Wow seems like you're right.. I didn't search for all that long, but I did find a couple articles indicating that WiFi networks can use up to 1watt legally.. which is what this amplifier claims to put out.
Given my experience with amateur radio amplifiers, and more to the point cheap chinese CB radio amplifiers there is NO WAY I would use an amp on my model airplanes without somebody with a lot more experience than me to look at the signal and make sure it is clean.
-Jay
Old Dec 13, 2009, 08:56 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well, when I went to research it, I only found where the FCC stated that 2.4ghz spread spectrum transmitters were limited to 1 watt output max. The FCC did mention some "Any" transmitters that were limited to a mv/m standard, but I don't know how that translates to mw yet.
But in Europe RC transmitters are limited to 100mw max output. So it is doubtful, if a manufacturer that is building TX's for other than the USA market, would have their TX's output more than 100mw too.
A 100mw is good for about 1 mile line of sight range. So for normal RC airplane purposes that should be more than adequate. Some TX's output even less power such as the Park flyer type TX's, maybe 1mw to 10mw output.
But if you are flying FPV planes beyond your flying field, you might want more range though. The problem with 2.4ghz is it is a line of sight system, if the plane cannot maintain a direct line between the TX and RX without objects blocking the view, you are at risk of the plane losing the control signals. A nice big tree with lots of leaves can block the signal.
The problem with that 1w amplifier is that we don't know if it would be like those cheap 2.4ghz wire video systems that tend to take over 3/4's of the 2.4ghz spectrum with their video signal, jamming everything else out. We have had reports of people having their flying fields being rendered unusable near a home development because of some sort of interference with the airplanes.
Old Dec 13, 2009, 10:02 AM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Remember, that it takes 4 times the power to double the range. But, when you increase power, you also increase the possibility for spurious emissions. These really cheap, non-FCC approved, devices coming out of China can (and do) reak havoc on 2.4GHz R/C control systems.
JimDrew is online now Find More Posts by JimDrew
Old Dec 13, 2009, 02:01 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Hope that helps.
-Jay
Jay, this brings an image to mind from Back to the Future I. I picture Doc Brown with one of those Heathkits strapped on his back and his mental telepathy headset as the antenna, flying an RC plane
Just curious, but would an old linear amp of that vintage work at 2.4Gigawatts, er, I mean Herz, or more correctly in 1955 speak Gigacycles
Cheers,
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Dec 13, 2009, 02:07 PM
CyberJay is offline
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
I'm not sure about the history of the EM spectrum... I'm sure 2.4Ghz was a known frequency back then but I don't know how much it was used. That amp I posted works from 500Khz up to about 30Mhz.
I did a google search for 2 minutes and couldn't find anything.. Searching for 2.4Ghz tube amps.. I kinda doubt it, but who knows.
-Jay
Old Dec 13, 2009, 05:32 PM
Joined Jun 2006
You can do a 2.4GHz tube amp, using something called a travelling wave tube, or a maser amplifier. But they tend to have kilowatts of output power....
Discussion 72 Mhz Amplifier For Sale fireisborn Aerial Photography 4 Jan 19, 2012 02:24 PM
Discussion CC Phoenix Controller/2.4 Mhz. dharban Electric Sailplanes 5 Aug 29, 2009 10:11 PM
Discussion MPX RoyalPro, PPM signal, 2 modules (41 MHz and 2.4 GHz) YannickF Radios 6 Feb 28, 2009 04:03 PM
Sold 4 receivers 72 mhz, HS-555(2) HS-04MG(2) scottflight Aircraft - General - Radio Equipment (FS/W) 2 Jan 23, 2009 09:11 PM
Discussion HIGH GAIN AMPLIFIER FOR 900 MHz RECEIVERS CATPart FPV Talk 2 May 20, 2008 06:02 PM
