Old Dec 12, 2009, 11:00 AM
MelihK is offline
Find More Posts by MelihK
MelihK's Avatar
United Kingdom, England, Canterbury
Joined May 2008
New Audio Modem Protocol For FPV Telemetry
Hi Everyone,
I'm designing new audio modem protocol for FPV telemetry over PC.
It started for my SimpleOSD XL but i think every OSD can use it.
Protocol will very simple and i will share protocol and software with all OSD brands/users, i hope they will use same protocol and someone will write new softwares like googleearth connection or telemetry screens like voltage etc.
I just started the modem software over soundcard's microphone input.
I can write my own googleearth and antenna tracking codes into the software but this is not usefull for everyone, i'm planning giving outputs for another softwares like Happykillmore's softwares. this is best way for new softwares.
Modem software working like an oscilliscope for reading the bytes. baudrate is 50 byte per second.
What you thinking about this?
Melih
MelihK is offline Find More Posts by MelihK
Site Sponsor
Old Dec 12, 2009, 11:20 AM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
Excellent! That's a great idea!
Are you thinking about using a text based protocol (liek NMEA) or machine code (like uBlox hex characters)?
I personally like the easier debug of the text protocol, but in actual use, the machine code is about 1/2 the size (or less).
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Dec 12, 2009, 11:52 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
Actually i'm searcing about simplest protocol and i found a way.
hardware protocol
signal looking like you saw on the software (green line is signal)
it starting with a start bit and stop bit, then it sending 8 bit value and silence area bigger than this signal totals. software will learn bit timing from starter bit's width. and it will find the start bit from big silence area.
This sample's value 3, you can see start+stop+10100000
I'm using 0.8ms for bit timing, this mean maximum freqency (1010101010) is 1200hz end it is compatible with all audio systems. and i'm syncronising bytes with camera frames. and it is enough for 50 byte per second.
software protocol
I'm not sure but, we can use compressed protocol for data.
1 byte starter byte(0x00) for finding line
4 bytes(32 bit) enough for GPS position values x 2 = 8 Byte,
1 bytes from ADC's (8 bit) like voltage, current, temp etc x 4 = 4 Byte,
2 byte Altitude (from sea level)
1 byte CRC for data correction
total 16 byte package. You can send it 3 times in a one second.
What is your comment?
is it useful or useless?
Site Sponsor
Old Dec 12, 2009, 01:30 PM
Brunswick, OH
Joined Nov 2005
I think it's useful... you're talking 50 baud? Any chance it can go faster?
I like the idea. Is the hardware going to be inexpensive to do this? For about $100 users can add X-Bee...
Old Dec 12, 2009, 02:19 PM
MelihK is offline
MelihK's Avatar
Joined May 2008
50 byte = 50 x8 = 400 baud.
It is fast enough because you need 1200hz beeps for sending this data, higher speeds possible but it depends your videotx's audio output quality. useless for everyone.
You dont need any hardware for that.
It will free, because it is just a software that connected your video receivers audio output. And you can write a code to your OSD for sending signals over videoTX's audio output.
I will write this modem software that reads audio signals. What is best way for output from my firmware? i can give the bytes over TCP-IP, or application APIs, or DLL plugs but i'm not sure about that. did you used any way for a arduino softwares.
Site Sponsor
Old Dec 12, 2009, 02:36 PM
Brunswick, OH
Joined Nov 2005
So the audio channel will get connected to the microphone input on my laptop? Or on a USB to serial channel? If it's actually sending using a serial protocol, then it makes more sense to use a "standard" baud rate like 4800...
All the stuff I've been doing lately is serial using a COM port.
Old Dec 12, 2009, 03:49 PM
MelihK is offline
MelihK's Avatar
Joined May 2008
Yes, audio signals coming from microphone input of laptop. Then my software will convert it to bytes.
Then i will use it for tracking plane over google earth and other telemetry values.
Normally i can integrate everything on same software and it can work only my OSD and software.
But i want to share it with other software developers like you or ardupilot users etc.
This is why i need a "plug" on modem software. If i design a plug(tcp or API) you can read values from my modem software and design your interface for this values.
And all OSD developers can use same protocol for sending telemetry to ground. this is why i start this thread.
Site Sponsor
Old Dec 12, 2009, 04:10 PM
jimbob00 is offline
Find More Posts by jimbob00
Joined Aug 2009
I'm wondering, what makes it hard to use a standard modulation?
e.g. v34 comes to mind: http://www.itu.int/rec/T-REC-V.34-199802-I/en
(28.8k and 33.6 with v34bis)
its the fastest "simple, analog" standard (v.92 uses pcm and its not that simple afaik)
or the chips just aren't quick enough?
advantage would be that you don't need to write anything on the receiver side and it works on any system
jimbob00 is offline Find More Posts by jimbob00
Old Dec 12, 2009, 05:03 PM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Originally Posted by MelihK View Post
What is best way for output from my firmware?.
Firstly, a virtual com port running at one of the common baud rates - many could use it for applications that are ready to use NMEA sentances over com ports.i.e. Google earth or a PC based antenna tracker that already exists.
Secondly dll etc for developers.
Shikra is offline Find More Posts by Shikra
Old Dec 12, 2009, 05:45 PM
Dimitris76 is online now
Find More Posts by Dimitris76
United States, IN, Carmel
Which one is this?
Dimitris
Dimitris76 is online now Find More Posts by Dimitris76
Old Dec 12, 2009, 06:09 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
This is the best! It would be so nice to have a antenna tracker that works with all major osd.
bracky72 is offline Find More Posts by bracky72
Old Dec 12, 2009, 06:24 PM
Brunswick, OH
Joined Nov 2005
So what modem does the OSD use to encode onto the audio channel?
The info in the packets I would assume would include:
Lat & Long, Speed, Alt, Heading and maybe some other items like battery voltage and amps. I'm not sure the baud rate will be fast enough for all this in one second....
Old Dec 12, 2009, 07:07 PM
KristianS is offline
Find More Posts by KristianS
FPV addict
Giske, Norway
Joined Aug 2009
Best news this month
This will be sweeeet
KristianS is offline Find More Posts by KristianS
Old Dec 13, 2009, 12:37 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
It is impossible because this is not telephone wire and you need fast DAC chips for sending full analog encoded standart modem signals. My modem protocol working like old CB modems for radio amateurs. Low speed is a rule for supporting all video transmitters etc.
I was write it on top, but sorry, i guess my english not enough for that.
This is not serial modem device, nor NEMA transmitter etc. It is a software for translating audible signals to strings for OSD telemetry. And it cant give out Serial Port data, because it is alread inside the computer, dll or PI connections enough. I will connect it on google earth over APIs.
Originally Posted by Dimitris76 View Post
Which one is this?
Dimitris
I will show it after modem protocol clear and everything is ready. basicaly 1 analog input, 1 button, 1 led and 2 servo out for tracking
It depends OSD developers, but i hope they will use.
OSD's porcessor will create a string and it will send over audio.
I was calculate it on top of the page, 16 byte enough for most of values and mean 3 refresh per second.
I hope it will
Site Sponsor
Old Dec 13, 2009, 12:55 AM
CrazyG is offline
Find More Posts by CrazyG
Israel
Joined Aug 2008
Very nice idea!
Hope this will come useful for all of us.
Thanks.
CrazyG is offline Find More Posts by CrazyG
Discussion First FPV application for the iPhone, decode EzOSD Telemetry : Beta Now Available! ImmersionRC FPV Talk 107 Sep 09, 2011 09:37 PM
Discussion Telemetry using audio channel of video transmitter m1tch37 UAV - Unmanned Aerial Vehicles 1 Mar 20, 2009 09:16 AM
Alert FPV telemetry for sale powerblimp UAV - Unmanned Aerial Vehicles 2 Dec 11, 2008 05:04 PM
Alert FPV telemetry for sale very good price! powerblimp FPV Talk 4 Dec 11, 2008 12:36 PM
Discussion Telemetry via wireless (2.4ghz) av audio channel? darkage DIY Electronics 3 May 11, 2007 01:30 AM
