Final Push
I got quite a bit done in the last couple of days. After I figured out where the batteries needed to be for balance I installed a tray for the A123 packs. It took a little thinking to come up with a tray for the flight batteries. The hardest part was designing it to hold the 4 x 6S-5800 batteries securely but permit the tray to be adjustable. I think that my design is okay because no matter how hard I shake the tray the batteries do not move. The bottom row of batteries include velcro and the top row uses grip tape (sandpaper) to create friction. I am using one 2 inch wide velcro strap. The tray will be fastened down using 6 bolts and blind nuts. I will be able to move holes to adjust the tray position. I also added a plywood baffle under speed controller to force air through other holes that I drilled in the side and top of the firewall. I want to make sure that there is good airflow around the batteries. All that is left is to install the wiring between the ESC and batteries and the Deans shunts (2).
Wiring For Power
I had a weeks vacation (out of town) but this week I did manage to get a couple of nights work on the wiring. I am pretty much committed to Deans connections so I replaced the bullet connectors on the Turnigy batteries. I realize that the Deans plugs may not handle as many amps but I am aiming for only about 75 Amps from each bank of batteries. I am using Turnigy 10 gauge wire with two separate runs to the two connectors on the Jeti ESC. I am also using two external Deans shunts for arming.I used the existing hole for the switch to mount the shunt assembly. It was easier to solder the fuse side shunt connections first before mounting the assembly to the fuse. I have a push switch for the anti-spark charging circuit. The wiring is very short thanks to the close proximity of the batteries to the ESC. Just a few things to tidy then I can program the ESC and run some motor tests. I am aiming to maiden two weekends from now. |
I am off to the Mini IMAC contest tomorrow in Bellingham. I would have liked to fly the Extra but I will fly my 33% Sukhoi instead. |
![]() Would like to have come out and watched. I've had last weekend and this weekend off so I'm working for the next 2 ![]() Rick |
| Thread Tools | |
| Wanted Hangar 9 35% Extra 260 left wing panel | 2robinhood | Aircraft - Fuel - Airplanes (FS/W) | 0 | Oct 18, 2009 07:33 AM |
| Wanted Hangar 9 35% Extra 260 right wing | 2robinhood | Aircraft - Fuel - Airplanes (FS/W) | 0 | Sep 07, 2009 07:17 AM |
| Article Hangar 9 35% Extra 260 ARF Review | tailskid2 | Giant Scale Airplanes | 13 | Oct 14, 2008 11:38 PM |
| Discussion Hangar 9 35% Extra 260 ARF-Electric Conversion | Splummer | Giant Electric Planes | 29 | Mar 02, 2008 10:32 AM |
| Alert Boletin Extra 260 de Hangar 9 35% Pag. 4 | alenys | Mexico | 56 | Jan 21, 2008 08:42 PM |
