Old May 07, 2003, 12:31 AM
GFX is offline
GFX
Find More Posts by GFX
GFX
Joined Feb 2002
Wattage F-22 and AstroFlight 010 brushless
Hi. I am interested in the Wattage F-22 but would like more jet-like performance than a S 400 setup can give. I was wondering if the Mighty Micro 010 Brushless Motor from AstroFlight would be a good match. I don't need blinding speed, but I am tired of electric jets that fly like kites.
If so, could you tell me also what type of battery and how many cells I should use? Also which prop?
I have a lot to learn about all this stuff and any help you could give would be very much appreciated.
Thank you,
GFX
GFX is offline Find More Posts by GFX
Old May 07, 2003, 12:59 AM
therookie is offline
Find More Posts by therookie
Joined Jan 2003
010 on the wattage f22 will not cut it, way underpower. Read this thread
http://www.rcgroups.com/forums/showt...32&highlight=f
option 3 with mega 7 turn is the lightest and most optimized for the Wattage F22. You will love the F22 for it is one of the best pusher jets out there.
This week www.hobbypeople.net has the wattage F22 on sale for $70 and only $3 shipping.
therookie is offline Find More Posts by therookie
Old May 07, 2003, 02:16 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Kinda agree, but kinda disagree. The F22 was designed for a 300 motor geared pretty low. The 010 with a 4x1 would still move the plane with the 8x5 prop.
Gf, Where are you located?
if you havppem to be in Dallas or near, PM me, its worth your while.
Kirby
kepople is offline Find More Posts by kepople
Old May 07, 2003, 09:07 AM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
Everyone I know flies the F-22 with the Mega 5T. There are many threads about it.
I agree, the F-22 needs more power than the Astro can give to be "Jet-like". I put about 150 Watts into mine to get it there. The Astro is limited to half that.
Melf
Darren Hintze is offline Find More Posts by Darren Hintze
Old May 07, 2003, 09:49 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Like the other guys said, the 010 wouldn't feed your need for speed It's more appropriate for a 6-8 oz. plane when used direct drive. But the 020 would rip!
Tres Wright is offline Find More Posts by Tres Wright
Old May 07, 2003, 10:40 AM
RPatrick is offline
Find More Posts by RPatrick
RPatrick's Avatar
Hurst, Texas USA
Joined Jan 2002
I will have to disagree here. My F-22 has a Hacker B20 + 4:1 Gearbox with a 9 x 6 prop on 10 600ae cells. Ready to Fly weight is 19.5 oz. This is a significantly lighter setup, will blast straight up for several hundred feet, makes amazing slow passes, and lands in about 2 feet.
Make no mistake, this is easily one of the best foam pusher Jets!
RPatrick is offline Find More Posts by RPatrick
Old May 07, 2003, 11:16 AM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
patrick
May I ask how many turns is your hacker? and the current draw on your system?
thanks
rcguy01 is offline Find More Posts by rcguy01
Old May 07, 2003, 11:48 AM
rcguy01 is offline
Permanently Banned
Joined Apr 2003
Melf
melf;
I dueled several times using my F22 with mega 7t, 10x1000 hecell and 7.5x6 prop side by side with the other gentleman' s F22 which has a mega 5t, 10xcp1300 and 7x6 prop. It is a very close call in level flight between the two but in vertical performance my F22 is a clear winner to his f22 and it flies longer since the current draw on mine is less. After all, in this case, the maga 7t is a better option. But I think Patrick' s F22 with hacker motor is the lightest and the winner of all Wattage F22s out there.
Old May 07, 2003, 11:50 AM
RPatrick is offline
RPatrick's Avatar
Hurst, Texas USA
Joined Jan 2002
Hi !
It is a B20 15L + 4:1
I have not measured the amps, but it draws down the 10 cell 600ae pack in about 5 minutes. That should put it around 8 or so amps average.
You can't really put a bigger prop on this jet because of the tailerons (unless you modify them), so anyone wanting more amps will need to use a hotter wind motor.
Of course, using KAN 950's or 1100HE cells would be better, but they were not around when I bought my packs! It may be a little tough to get the C of G correct with those heavier packs though.
RPatrick
Old May 07, 2003, 11:54 AM
Tight is Right
Joined Dec 2001
>>I dueled several times using my F22 with mega 7t, 10x1000 hecell and 7.5x6 prop side by side with the other gentleman' s F22 which has a mega 5t, 10xcp1300 and 7x6 prop. It is a very close call in level flight between the two but in vertical performance my F22 is a clear winner to his f22 and it flies longer since the current draw on mine is less.<<
The Mega 7T on 10 cells and the Mega 5T on 8 would be a better comparison that the ones you're running. On 10 CP cells and a 7x6 the Mega 5T is out of its max efficiency range (too many amps). The 5T on 8 will pull as much power and be lighter than the 7T on 10. You're right, the 7T on 10 will fly longer. It depends upon what you want.
Melf
FS- Wattage F-22 Raptor with servos and BRUSHLESS - all new and MAY seperate. Etonic Aircraft - Electric - Airplanes (FS/W) 3 Feb 10, 2004 05:33 AM
FS- NIB Wattage F-22 Raptor, Typhoon 6 Brushless w/contoller, and 2 new GWS bb servos Etonic Aircraft - Electric - Airplanes (FS/W) 3 Jan 27, 2004 06:46 PM
Wattage F-22 and the AstroFlight Mighty Micro 010 brushless GFX Foamies (Kits) 3 May 07, 2003 06:31 PM
Wattage F-22 and AstroFlight 010 brushless GFX Electric Ducted Fan Jet Talk 1 May 07, 2003 12:43 AM
Wattage F-22 EDF conversion..motor/fan choices Ed Waldrep Electric Ducted Fan Jet Talk 6 Sep 10, 2001 01:21 AM
