Old Dec 11, 2009, 12:30 PM
maverickma is offline
Find More Posts by maverickma
maverickma's Avatar
Fogelsville, PA
Joined Mar 2004
Attention Power 160 owners: Easy question on E-Flite Power 160 dimensions
I bought a generic Power 160 motor and I'm trying to figure out if the E-Flite prop adaptor (the one used if the motor is mounted radially) will work on my generic Power 160. Please see picture. I just need to know what the diameter is of that raised portion of the real Power 160 that the adaptor fits over. On my generic one, its just under 29mm.
Also need to know what the distance is (center of hole to center of hole) between 2 of the 4 prop adaptor mounting holes crossing over the end of the motor shaft. On my generic it's 22mm. Any help is appreciated. Posted the same question on Wattflyer.
Please no hazing, I easily own over a $1000 worth of Horizon Hobby products, but this was a deal I could not pass up. Thanks for any help! Doug
maverickma is offline Find More Posts by maverickma
Old Dec 11, 2009, 03:45 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Looks like the motor you have is one of the Exceed Power 160's sold over at hobbypartz.com and nitroplanes.com
You can call them, they are out of California and order in the radial adapter and xmount if you need them.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Dec 11, 2009, 06:07 PM
maverickma's Avatar
Fogelsville, PA
Joined Mar 2004
I called and they are out until January, but my main concern is being able to put a nice spinner on and with the stock adaptor, I can't because it doesn't have the center hole. Yes I can drill and tap but would prefer something I can just bolt on that has the hole already tapped.
Sold E-Flite Power 160 NIB - SOLD!!!! TonyF Aircraft - Electric - Power Systems (FS/W) 0 Dec 09, 2009 10:28 AM
Discussion Anyone using an E-Flite Power 160 tlh101 Power Systems 1 Oct 17, 2009 09:33 AM
Question Attention GWS Spitfire owners, a question please... CRAZYDAVE Electric Warbirds 29 Oct 02, 2009 08:26 AM
Wanted Attention Raptor E 550 owners Flyboy70 Aircraft - Electric - Helis (FS/W) 0 Sep 29, 2009 08:23 PM
Sold E-Flite Power 160 flyboy1945 Aircraft - Electric - Power Systems (FS/W) 2 Sep 25, 2009 03:49 PM
