Old May 06, 2003, 10:58 PM
duganderson is offline
Find More Posts by duganderson
Joined Nov 2002
How to convert Zagi 400 to 400X??
Does anyone have any tips/directions to convert a Zagi 400 to 400X?
Thanks, Doug
duganderson is offline Find More Posts by duganderson
Old May 06, 2003, 11:28 PM
PERIStaff is offline
Find More Posts by PERIStaff
PERIStaff's Avatar
Chilliwack BC Canada
Joined Apr 2003
I think Trick-RC sells an up-grade kit for the basic zagi so you can covert to the zagix comes with battery,tray and afew other parts.
PERIStaff is offline Find More Posts by PERIStaff
Old May 07, 2003, 12:44 AM
Bill Germanson is offline
Find More Posts by Bill Germanson
Name it, I've crashed it
Bill Germanson's Avatar
JAX, FL
Joined Feb 2002
Peri is correct - Just talked to Trick about it. There is a larger tray/canopy to handle the 8x1700 packs and a carbon fiber rod which the 400 doesn't have. You also need to deepen the hole in the form for the tray about 1/4, I think is what they said.
Rather than spend the money ($55) for the upgrade I'm just going to buy the tray/canopy for $10 and then get a carbon arrow shaft from WalMart.
http://zagi.com/html/airplanes/ZAGI-...n_.shtml?id=44
Bill Germanson is offline Find More Posts by Bill Germanson
Old May 07, 2003, 09:34 AM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
Like Bill says.......there really isn't any difference but the spar and canopy/tray. The 1700Au pack could be improved by purchasing 1700aup cells.
Al
Al P is offline Find More Posts by Al P
Old May 07, 2003, 10:59 AM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
In the past, I converted my original Zagi 400 to a 400X using the different plastic tray, top, and carbon spar.
Today, there is an alternative. If you don't already have the 400X battery pack, you may want to consider simply switching to a 3s2p Lithium pack.
Good luck!
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Zagi 400/400X Wing Destroyer Flying Wings 13 Feb 23, 2005 10:41 AM
Idea Zagi 400/400X Tach max42 Foamies (Kits) 3 Mar 09, 2004 06:54 AM
Diff. between Zagi 400 and 400X??? Joe Ford Foamies (Kits) 1 Sep 07, 2003 09:30 PM
FS: Zagi 400 and 400X NEW parts CactusJackSlade Aircraft - Electric - Airplanes (FS/W) 0 Feb 05, 2003 02:58 AM
zAGI 400 / 400x CONVERSION Bojulabah Foamies (Kits) 1 Apr 16, 2002 11:37 AM
