Old Dec 09, 2009, 06:23 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Question
Battery discharger tool for storage
Hi all,
i work away on a 2/1 week roster and am looking for a discharge unit that can accurately discharge my batteries down to a storage voltage in a reasonable time frame. i have a unit from hobbycity that discharges at i think
1amp, it works well but when there are 10-20 batteries to be discharged it takes far to long to do at such a low discharge rate. i understand why the rate is so low as disapating the heat is a big issue but if i can fly out a 2200mah pack in 10 minutes surely there is a way that a dicharger can drive a resistor, heatsink and fan to achieve much the same sort of rate, and also have a preset cell cutoff voltage 3.8V for storage. even if it took say 15 minutes that by my calculations should be about 9-10Amps which would be safely achievable i would have thought!
any ideas on this, or knowlege of an existing unit would be appreciated, i an no electrical guru, but i might have to try and nut someting out, learn as i go!
Cheers
Craig
trumps is offline Find More Posts by trumps
Old Dec 09, 2009, 10:11 PM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
There was something like this in the DIY electronic forum. Have a search through there.
discostu956 is offline Find More Posts by discostu956
Old Dec 09, 2009, 10:26 PM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
Cheers bud,
found it, looks like just the ticket.
here is the link for anyone interested.
http://www.rcgroups.com/forums/showthread.php?t=1131817
Craig
Old Dec 09, 2009, 10:34 PM
Inflexo is offline
Find More Posts by Inflexo
Magicsmoke maker
Inflexo's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
buy 10 of these
http://nqrc.com/?vp=PLD-LN3S-01
Also, the reason for the reluctance to discharge in 10 minutes is that it's easy to overshoot and yes, getting rid of a few hundred watts of heat is never easy/safe/cheap.
Paul.
Inflexo is offline Find More Posts by Inflexo
Old Dec 10, 2009, 12:42 AM
Is my CG correct?
Wollongong, Aus
Joined Sep 2009
Cheers bud,
Craig
Cool, I would have linked to it but didn't have time to find it. Good luck with it
Old Dec 10, 2009, 03:10 AM
glydr is offline
Find More Posts by glydr
Next time I'll ARTF...
glydr's Avatar
Canberra, Australia (Southside)
Joined Feb 2004
Originally Posted by pldaniels View Post
That's what I use.
Also - a slow discharge is better for the battery. Compare how heli packs (worked hard) wear out sooner compared to slow parkfly lipos.
glydr is offline Find More Posts by glydr
Old Dec 10, 2009, 07:17 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
The iCharger 1010B+ can discharge through a resistor at up to 300w.
I use it to bring my 10S packs down to storage voltage when I'm not using them and it does it at around 7 amps.
They also have heaps of other functions.
Hobbycity carries them, not exactly cheap, but if you're on 2/1 then money aint a big problem right?
RolandS888 is offline Find More Posts by RolandS888
Old Dec 10, 2009, 07:54 AM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
LOL Roland, it's a relative thing mate, we live according to our means!
cheers for the tip on the charger, i have been thinking about upgrading
as my old swallow2 is getting one hell of a workout these days charging
20 odd batteries for a club day, i have to start charging 2 days ahead!
poor little bugga can't last for ever!
Cheers
Craig
Old Dec 10, 2009, 04:03 PM
Outta Sight
Joined Jul 2008
I know how it goes Craig, I lived and worked in Karratha for a while, earnt heaps and spent it on "living" expenses.
I use 2 iCharger1010B+ chargers for charging my 10S 5AH Lipo packs, these chargers are great for high rate charging.
If i want to charge lots of smaller Lipos (2S and 3S) at the same time I use one of these quattro chargers.
http://www.hobbycity.com/hobbycity/s...Multi_Charger_
They have better specs than the Swallow and there's 4 of them that can charge, or cycle or store etc all at the same time.
And for AU$150 delivered you cant go wrong.
Cheers,
Rol.
Discussion Winter Battery Storage laser110 Scale Boats 12 Oct 04, 2009 06:08 AM
Mini-HowTo How to build a constant current battery discharger biskit Batteries and Chargers 25 Sep 06, 2009 07:53 PM
Discussion battery storage ( discharger) elcamino Batteries and Chargers 15 Aug 26, 2009 08:35 AM
Help! Lipo discharger for storage eckace1 Batteries and Chargers 12 Aug 13, 2007 06:59 PM
Question Discharger for LiPos (3.85V for storage & long life) Joe Minton Batteries and Chargers 11 Aug 14, 2006 02:11 PM
