Old Feb 08, 2013, 12:06 PM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
Here is the hatch from an earlier thread.
Lammergier is offline Find More Posts by Lammergier
Old Feb 08, 2013, 12:47 PM
geedee is offline
Find More Posts by geedee
Chester, UK
Joined May 2010
Stryker
Many thanks for that.
geedee is offline Find More Posts by geedee
Old Feb 09, 2013, 07:09 AM
AeroRecon is offline
Find More Posts by AeroRecon
Work....fly, repeat...
AeroRecon's Avatar
Fredericksburg, Virginia
Joined Jul 2008
So...here I am at E-Fest.
What is YOUR ideal LS setup?
I have two new fuses (only one nose though) and want to build a couple new setups.
Figured I would ask the experts.
Thanks!!
AeroRecon is offline Find More Posts by AeroRecon
Old Feb 09, 2013, 08:30 AM
ssteven1 is offline
Find More Posts by ssteven1
United States, NC, Randleman
Joined Jan 2007
Here is my setup. 600 ma 3 cell battery, 1500kv blue wonder brushless, GWS 8x4 prop, 10 amp esc; 2 x 9 gm servos.
Make the fins and elevons out of depron. I make the elevons between 1.25-1.75 inches wide depends how responsive I want the stryker to be.
I make the hatch out of a manilla folder covered in black packing tape.
This should get you a stryker with very good vertical at around 11 ounces. Take out the fiberglass spars to drop another .6 ounce.
ssteven1 is offline Find More Posts by ssteven1
Old Feb 09, 2013, 09:32 AM
AeroRecon's Avatar
Joined Jul 2008
Thanks! I have I one flying already but don't remember the motor kv. I will pick up those specs and give it a shot.
Old Feb 10, 2013, 03:13 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
My go to setup is:
“Blue Wonder”-style 24g 1300kV motor
10- 12 amp ESC
GWS 8040 propeller
2x 9g Servos
800-860mAh 3 cell LiPo batteries
mclarkson is offline Find More Posts by mclarkson
Old Feb 11, 2013, 01:27 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Hi guys!
I've been flying heavy Strykers for some years but have recently put together a lightweight version. I used stock airframe, hatch and elevons, but for the rest I used:
Motor: C20 1550kv: http://www.hobbyking.com/hobbyking/s...er_1550kv.html
Fins: own design. 1.5mm cardboard laminated with vinyl tape and packing tape.
Esc: A yellow, generic 30A that was originally shipped with a HK foamy
Servos: http://www.hobbyking.com/hobbyking/s...dProduct=16259
Prop: APC7x5E
Battery: 2S1300 15C: http://www.hobbyking.com/hobbyking/s...1P_15_25C.html
Rx: AR500
The mission was to build a "fly anywhere" Stryker capable of carrying a keychain camera and long flight time, and I'm quite happy with the outcome.
Stryker UltraLight Winter (4 min 14 sec)
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Feb 11, 2013, 02:00 AM
rchank is offline
Find More Posts by rchank
I used to like trees
rchank's Avatar
United States, WA, Spokane
Joined Jul 2011
Originally Posted by Arcteryxxx View Post
Hi guys!
Prop: APC7x5E
Rx: AR500
I've always enjoyed your great Stryker videos. Chalk up another nice one with your light Stryker.
rchank is offline Find More Posts by rchank
Old Feb 11, 2013, 02:19 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Looks great - what's your AUW?
Old Feb 11, 2013, 02:23 PM
Arcteryxxx's Avatar
Joined Feb 2010
454gram. Plus 18g camera and two square cm of velcro.
Old Feb 17, 2013, 12:50 AM
ssteven1 is offline
Joined Jan 2007
Introducing the X-ray lite stryker.
I wanted to try something different. I cut out as much of the body as dare. Total up weight is 8.9 Oz on 2 cell and 9.6 on 3 cell. Funny thing is it is slightly heavier from the reinforcements I had to do comparered with the base foam after you remove the spars. I thinks it looks cool and flys good.
And yes it does have a hatch set made out of clear tape.
Description: Top
Description: Bottom
Description: Ready for launch.
Description:
Old Feb 17, 2013, 01:29 AM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Put some lights in there!!!!
So you're saying we're better off, weight-wise, to leave the foam alone?
Old Feb 24, 2013, 01:52 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Hi, i am new to stryker...I bought a radjet a while back, and love it,but this stryker seems to have exactly what i need... i am building from parts and can't find a canopy??...does Q version canopy fit the C version.?..Also which motor and prop from HK works best.?..i want to run 3s 2200mah and also be able to run 4s using this motor...i am looking for a 90-110mph on 3s...Please point me in the right direction so i can order what i need and get this show on the road thax
hate2crash is offline Find More Posts by hate2crash
Old Feb 24, 2013, 09:59 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Way to go steven tell us more!!!
Whats covering the holes? What type of glue and reinforcements did you do?
wopachop is offline Find More Posts by wopachop
Old Feb 24, 2013, 10:10 PM
wopachop is offline
Joined Apr 2007
Hi!!!
For a lightweight stryker most guys ditch the stock C canopy because its too heavy.
The plane you are looking to build is much faster and heavier. But i tell you what. Check out this thread. The light strykers are a blast.
Discussion how can you tell if you prop is cavatating? grfcon Flying Wings 3 Nov 19, 2009 12:30 AM
Discussion 2.4 How high can you go Spencer Thermal 10 Nov 05, 2009 06:47 PM
Discussion Lama 3 Flybar, How light can you go?? jamesppp Coaxial Helicopters 6 Feb 08, 2008 09:16 PM
How light can you go? Halibatsuiba Foamies (Kits) 1 Jul 17, 2004 05:37 AM
