USA, NY, Brooklyn
Joined Jan 2002
I just started using hot glue for the first time this year, and I love it. I've flown in 90+degree hot sunny weather and nothing fell off. Hot glue kicks butt compared to epoxy, any ca, rubber cement, or white gorilla glue... It may be weaker if you dont heat it up enough...
Alright... the 3D thing didn't work out very well so I've changed things up and mounted my new FPV gear on this one. It's a little heavy at 504 grams AUW, but it's packing two batteries the video transmitter and camera, etc.
I mounted the camera right behind the nose and then wound up shaving off the top of the nose to give me a clear view. I think I'm gonna try mounting one of my keychain cameras on the new nose. |
10oz
cheers |
USA, NY, Brooklyn
Joined Jan 2002
i'll probably beat or come close to 10oz rtf WITH FPV gear and batteries, soon. Maybe I'll complete it today.
By Drilling holes into the airframe and reinforcing with very thin but strong tape. bare airframe is about 150grams or 5.3oz. I will try to lower it by 2-3 oz hopefully. The lighter you get it, the slower/more control at lower speeds you get. So flying between trees becomes very very easy. at 14oz AUW with battery and fpv gear it is awesome flying between/under around trees. imagine 10oz with high quality fpv gear. that will be INSANE! |
On mine, the wide angle lens I was using required me to actually shave into the front of the fuselage. Sure the nose of the plane is as aerodynamic as a brick, but it provides a clear view. Plus I've found that my light stryker tends to slow down very quickly, even when it had a nose due to the lack of momentum. Also, why are you using two video batteries? Its really not that hard to get a single battery system working without interference. That makes it really easy to lose some weight by using just one battery, and its a lot more convenient only having to charge one batery. |
| Thread Tools | |
| Discussion how can you tell if you prop is cavatating? | grfcon | Flying Wings | 3 | Nov 19, 2009 12:30 AM |
| Discussion 2.4 How high can you go | Spencer | Thermal | 10 | Nov 05, 2009 06:47 PM |
| Discussion Lama 3 Flybar, How light can you go?? | jamesppp | Coaxial Helicopters | 6 | Feb 08, 2008 09:16 PM |
| How light can you go? | Halibatsuiba | Foamies (Kits) | 1 | Jul 17, 2004 05:37 AM |
