Light Strykers have been a way of life for me for a couple years now..
Here is number four, a "3d" version with about 150 hard flights so far..
(the first pic has a Micro Stryker on the nose)
Elevon thrust vector with 3 inch, 6mm depron surfaces.
10 oz without battery auw.
Runs on 1.6-2.5 oz batteries. (400-800 mah) 30c+
MicroDan 2505-1200 with 9x5" GWS is good for 22 oz thrust at 11a.
Castle 9 esc.
My 1845kv version with 8x4 is good for 27oz.
9g servos move the sufaces well because they are set up with low resistance pin hinges.
60 degrees of throw.
Spars removed for weight savings, add tape and plenty strong. (has not lost form or broke)
Bits of carbon added here and there.
No plastic anywhere except control horns that are glued on.
3mm depron fins last about 50 flights before I destroy them from dragging inverted.
