Old Nov 09, 2011, 10:50 PM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Originally Posted by wopachop View Post
Also how much throw on my elevons?
As much as possible for my style of flying. I only reduce throws for speed planes.
Murman is offline Find More Posts by Murman
Old Nov 10, 2011, 04:02 AM
mclarkson is online now
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Me too. My elevons go as far as they can on high throws, but I fly around at stall speed all the time.
On low throws, probably about 60% of that. But I've never actually measured.
mclarkson is online now Find More Posts by mclarkson
Old Nov 10, 2011, 07:38 AM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Thanks guys. Using HXT900,s and the Dubro Micro Razor Horns.
This will be my first plane being setup for my DX6i. I have the little OrangeRx 4 Channel.
Can anyone recommend differential and exponential settings please?
wopachop is offline Find More Posts by wopachop
Old Nov 10, 2011, 08:05 AM
ssteven1 is offline
Find More Posts by ssteven1
United States, NC, Randleman
Joined Jan 2007
No differential. I use 100% throws and 45% expo on high and 65% throws and 25% expo. But I am a bit of a stick banger.
ssteven1 is offline Find More Posts by ssteven1
Old Nov 10, 2011, 08:11 AM
wopachop is offline
Joined Apr 2007
Theres the man!!!
Confused as hell again on my prop savers.
The prop saver that came with my Turnigy 2750....is that for the 8/4 prop?
Also i ordered SKU C-380 from HeadsUp. Its a 3 mm prop saver. Now its not showing up i think they changed the SKU. It cost 2.95 is that the regular saver for a 7"
Old Nov 10, 2011, 09:07 AM
ssteven1 is offline
Joined Jan 2007
This will work for 8x4.
http://www.headsuprc.com/servlet/the...r-3.0mm/Detail
This will work for the 7x3.5 and the slow fly props
Old Nov 10, 2011, 09:25 AM
wopachop is offline
Joined Apr 2007
Having trouble setting up the dx6i. I choose "elevon" for the wingtail mix. I hear servos move when I plug battery in but can't make them move with radio.
Old Nov 10, 2011, 03:59 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I'm running about 60% expo and have recently added 20% differential which seems to help the barrel rolls a bit.
At the risk of belaboring the obvious, are you sure the servos are plugged into the correct ports on your Rx? Can you go to the monitor screen on your Tx and confirm that your sticks are doing what you think they're doing?
Old Nov 10, 2011, 06:38 PM
wopachop is offline
Joined Apr 2007
Have one servo in ail and other servo in elev.
Tx on elevon Activate. The monitor menu shows them moving.
Only one servo moves. Do I have to set those Mix 1 settings for elevon mode to work?
Old Nov 10, 2011, 09:26 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
What's your radio?
Old Nov 12, 2011, 08:33 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
Follow these instructions to program your DX6-i for elevons.
Old Nov 13, 2011, 08:37 PM
MiddleMarc is offline
Find More Posts by MiddleMarc
Cedar Rapids, IA
Joined Aug 2010
Originally Posted by mclarkson View Post
My light Stryker and my flying wing built from the wings of another crashed Stryker, battling the high gusty winds. Flirting with stalls at low altitude in high wind is one of my favorite games. (Stick around for the end. )
http://www.youtube.com/watch?v=sJzBd-oI5jg
Very cool!
MiddleMarc is offline Find More Posts by MiddleMarc
Old Nov 14, 2011, 09:24 AM
wopachop is offline
Joined Apr 2007
Im using the OrangeRx 4 ch so i dont have an AUX port.
What exactly is the problem with the DX6i elevon program? I read the link but dont understand...something with the trim buttons?
Old Nov 14, 2011, 11:05 AM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
The problem is explained pretty well in this thread.
Old Nov 14, 2011, 08:33 PM
wopachop is offline
Joined Apr 2007
Awesome thanks for link was reading that thread earlier. Its huge...still cant figure out if i can use the Rudd channel of my 4ch Rx.
Was about to watt test my GWS EP 7035 and 8040 props. I have both size prop savers from heads up.
Problem im having is the EP 8040 wants to mount backwards. I want the numbers facing forward correct? That doesnt work using the back facing motor....what am i missing here?
Discussion how can you tell if you prop is cavatating? grfcon Flying Wings 3 Nov 19, 2009 12:30 AM
Discussion 2.4 How high can you go Spencer Thermal 10 Nov 05, 2009 06:47 PM
Discussion Lama 3 Flybar, How light can you go?? jamesppp Coaxial Helicopters 6 Feb 08, 2008 09:16 PM
How light can you go? Halibatsuiba Foamies (Kits) 1 Jul 17, 2004 05:37 AM
