Old Aug 18, 2011, 12:18 AM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I was running a Turnigy 2730 1500kV but it died on me in short order. I'm currently running a 2712-12 1300kV 'Blue Wonder'.
They are both great for my 12oz plane. The 1500kV definitely packed more punch - the plane had unlimited vertical - but the 1300kV works just fine for the flying I do which is mostly 1/2 throttle or less and usually at night with the lights lit.
mclarkson is offline Find More Posts by mclarkson
Old Aug 18, 2011, 10:18 AM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Hi
If replying to me cool about the motors!!! I have the Turnigy 2730 1500 sitting here, unlimited vertical sounds fun.
I was asking about the motor mount though....guess i never ordered one.
Think i remember seeing square carbon mounts, round aluminum tube.
What do you guys feel was the lightest and or best?
wopachop is offline Find More Posts by wopachop
Old Aug 18, 2011, 07:11 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Oops. I mis-read your post as which motor was best. I use the stock mounts that come with the motors, screwed to a square of thin plywood.
Old Aug 19, 2011, 08:50 PM
wopachop is offline
Joined Apr 2007
On the hobbyKing website it says my Turnigy 2730 will pull 12amps with a GWS 8/4. But i only ordered a plush 10amp esc.
Using a 850mah 25-40c nano tech. Should i of ordered 7/3.5 props instead? Maybe get a slightly larger esc?
I would like to get maximum thrust from the motor/battery package.
Old Aug 19, 2011, 09:56 PM
wopachop is offline
Joined Apr 2007
Originally Posted by ssteven1 View Post
If that is a 2 cell you will have a lot more power and speed on a three cell. Just remember to not run that motor of 3 cell with the 8X4 prop. Use a 7 X 3.5 or like I do cut the 8X4 prop down to just under 7 inches (6.8), round the ends off and balance. You will have about 5 more ounces of thrust and 10 mph of speed.
ooohhhhh....thats right i remember reading this.
is there a math equation that tells you the thrust steven?
how did you come up with 6.8/4 being the best ratio?
Old Aug 20, 2011, 06:21 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
FWIW, my 2712 1300kV pulls only 6.6 amps with at 8x4 on a 3S. I never measured my 2730, but I doubt it would be twice that.
Old Aug 20, 2011, 08:30 PM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Wopa, I've been using Turnigy Plush 10a esc's with 2730-1500's for a couple of years now with 8040 props on 3s. I've never had a problem with any of those setups drawing too many amps.
Murman is offline Find More Posts by Murman
Old Aug 22, 2011, 12:40 PM
radhav is offline
Find More Posts by radhav
United States, CA, Folsom
Joined Jun 2011
how will this combo perform on stryker frame ?
http://www.headsuprc.com/servlet/the...tor-%26/Detail
radhav is offline Find More Posts by radhav
Old Aug 22, 2011, 01:47 PM
prefabu is offline
Find More Posts by prefabu
Kansas City
Joined Dec 2009
That's the same combo I'm putting on my light Stryker, but it's still a work in progress. I sanded a 3/8" groove into the foam where the motor mount usually goes, and I'm mounting the motor on a 3/8" balsa stick that I'm gluing into the groove. I plan to cut fins out of 6mm depron and use balsa for ailerons. I'll probably use a 1300 mah 3 cell, so it won't be super light. I just wanted something a bit slower and more quiet for smaller parks. Hopefully the motor will be a good match. The combo is pretty inexpensive.
prefabu is offline Find More Posts by prefabu
Old Aug 22, 2011, 04:28 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Definitely a heavier setup that I'm running. It won't be super-light and super-slow, but it oughta fly just fine.
Old Aug 24, 2011, 01:18 PM
Heli0z is offline
Find More Posts by Heli0z
To infinity and beyond!
United States, NC, Charlotte
Joined May 2009
Anyone do a night flyer on 2s?
I have a few 1000mah 2s batteries and a spare fuse sitting around, what motor prop combination works with the 2s and extra weight of the leds?
Heli0z is offline Find More Posts by Heli0z
Old Aug 25, 2011, 02:34 AM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Personally, I didn't like how bright the LEDs are on a 2S.
Old Aug 26, 2011, 10:53 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
I will have to agree with you. They are a little dim at 7.4v. I've got some 3s 360mAh packs that I use just for my LEDs. They are small and don't weigh much either.
I should be starting on my Lite Stryker soon and I'm for sure going to add LEDs to it.
Old Aug 26, 2011, 11:05 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
My lights only pull around 0.3 amps, so it doesn't take much battery to run them.
Old Aug 29, 2011, 08:54 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Here's some slow flying from yesterday, around dusk.
Lite Stryker Dusk Flight (4 min 55 sec)
Discussion how can you tell if you prop is cavatating? grfcon Flying Wings 3 Nov 19, 2009 12:30 AM
Discussion 2.4 How high can you go Spencer Thermal 10 Nov 05, 2009 06:47 PM
Discussion Lama 3 Flybar, How light can you go?? jamesppp Coaxial Helicopters 6 Feb 08, 2008 09:16 PM
How light can you go? Halibatsuiba Foamies (Kits) 1 Jul 17, 2004 05:37 AM
