Old Dec 15, 2009, 04:36 PM
jmccoy62003 is offline
Find More Posts by jmccoy62003
Gahanna Ohio
Joined Jul 2007
Hey butch where did you get the epp foam for the elevons and canopy?? And how much wider did you make the elevons over stock??
jmccoy62003 is offline Find More Posts by jmccoy62003
Old Dec 17, 2009, 04:29 PM
Gahanna Ohio
Joined Jul 2007
Hey steven.....or anyone......where else online can i buy the motor you suggested...hobbycity is sold out of everything you suggested.
Old Dec 17, 2009, 08:37 PM
Murman is online now
Find More Posts by Murman
Go Panthers!!
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Montorc.com has them also
Murman is online now Find More Posts by Murman
Old Dec 18, 2009, 05:04 PM
ssteven1 is offline
Find More Posts by ssteven1
United States, NC, Randleman
Joined Jan 2007
You can use the 2712-17 1700 kv motor here.
http://www.headsuprc.com/servlet/the...lectric/Detail
You just need to use a 7-3.5 gws prop for 3 cells and a 8-4 prop for 2 cells. I have used them before, shipping is just $2.00 and is fast (they are in america)
You can also use there 10 amp esc and 9 gm servos too.
http://www.headsuprc.com/servlet/the...OWER-UP/Detail
http://www.headsuprc.com/servlet/the...sh---9g/Detail
This is a little more expensive than hobby city but they are faster and are good people to deal with.
The motor mount can be found here about 1/3 of the way down it is labled the "8mm Magic Motor Mount".
http://www.lightflite.com/
Don't use lightflite blue wonder motor because it is too low of kv for use in the stryker.
Good luck and lets see the styker when you finished.
ssteven1 is offline Find More Posts by ssteven1
Old Dec 18, 2009, 08:44 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
Originally Posted by Flatulator View Post
Here is my lightweight Stryker. I cut the fuselage completely off and clipped 2" off the ends of the wings also. Wingspan is now 30" and with the Wicked Jr motor and 1200mAh 3s lipo, it will do 70+mph and fly slow also. Cut the throttle, and this thing glides forever!! Right now, the auw is 13oz, but not for much longer...I am getting ready to glass it so I can add a Mega 16-15-4 on 4s
what prop are you using?
epoweredrc is offline Find More Posts by epoweredrc
Old Dec 18, 2009, 09:01 PM
Go Panthers!!
Murman's Avatar
Joined Jul 2008
4.1x4.1 prop on that Wicked Jr motor
Old Dec 19, 2009, 03:20 PM
Gahanna Ohio
Joined Jul 2007
Hey Steve...
got my stryker airframe in the closet waiting for santa to wrap it. got servo's and motor from headsup ordered and motor mount from the other suggestion ordered also. Now i have a question..... are you just tapeing the motor mount to the airframe and with what tape?? and the elevons look as if they are taped on also... am i seeing it correct?? Hope i can pick your brain so i can get this put together the right way.
thanks
Old Dec 20, 2009, 06:52 PM
ssteven1 is offline
Joined Jan 2007
jmccoy I normally glue the motor mount with hot glue. If it is cold where you live, the hot glue seems to not hold as well in the cold and you might use epoxy. Make sure to get the motor mount straight. The same with the fins just a little dab in the front and in the rear in case you need to replace them. I tape the elevons with scotch exteme packing tape (office depot). I have also used clear duck tape (walmart), it looks the same. I just put a piece on the top and none on the bottom. It is probably not the best way but it works for me. I just check the tape before I fly. You have to cut an angle in the bottom on the elevons so they can hinge. If you put on a 8 inch prop you need to trim the rear fin tabs as shown in my bottom pict of the stryker with the lights. Also remember to keep any paint light. I recomend a paint scheme like this.
Yes i know I have a lot of strykers. This one is a 17 ounce 55 mph plane.
Old Dec 20, 2009, 06:59 PM
ssteven1 is offline
Joined Jan 2007
Since I am showing all my light stryker I have made. This is my 10 ounce styker powered by a park 250 with 35 watts. Proving you don't need a lot of power to fly these. It was a little under powered and the blue wonder has more range of flight.
Old Dec 20, 2009, 10:19 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I have a ton of EPP foam I got from SloperSteve. I've also picked up some EPP block foam, to cut canopys out of.
The elevons are 6mm depron about 2"s wide for slow flying.
I also built one with the 1300kv, 24g outrunner, 8x6, on 3's and it had unlimited vertical.
Butch777 is offline Find More Posts by Butch777
Old Dec 29, 2009, 07:00 PM
Gahanna Ohio
Joined Jul 2007
Motor Mount
Hey butch..... how did you mount the motor to the frame on your lightweight stryker? And how do you determine the center of gravity to get the plane to balance out??
Thanks guys...
Old Dec 29, 2009, 07:23 PM
Zaurak3 is offline
Find More Posts by Zaurak3
Gravity-Compliant User
Zaurak3's Avatar
Nebraska USA
Joined Mar 2008
Thanks guys...
Since the center of lift doesn't change in a Stryker (lightweight or otherwise), the center of gravity remains the same as well.
Zaurak3 is offline Find More Posts by Zaurak3
Old Dec 30, 2009, 08:00 PM
ssteven1 is offline
Joined Jan 2007
jmccoy, There are 2 small divots in the middle of the hand grip cutout on the bottom of the plane. This is the center of gravity. You place your finger tip in them to balance the plane.
Old Dec 30, 2009, 10:30 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
Thanks guys...
I used a carbonfiber motor mount and got it mounted to line up with the cord-line of the wing.
I used wider ailerons, which increased the wing area and moved the C/G ballance point back just a bit.
Heres the Thread, it has a pic of the motor mount. Butch
http://www.rcgroups.com/forums/showthread.php?t=530040
Old Jan 02, 2010, 02:24 PM
Windy_planes is offline
Find More Posts by Windy_planes
Windy_planes's Avatar
Abilene,kansas
Joined Dec 2009
Where did you get the led lights..I have read this thread several times,but didn't see the answer.You have an awsome plane.Also where did you hook the leds into?Seperate battery pack?
Windy_planes is offline Find More Posts by Windy_planes
Discussion how can you tell if you prop is cavatating? grfcon Flying Wings 3 Nov 19, 2009 01:30 AM
Discussion 2.4 How high can you go Spencer Thermal 10 Nov 05, 2009 07:47 PM
Discussion Lama 3 Flybar, How light can you go?? jamesppp Coaxial Helicopters 6 Feb 08, 2008 10:16 PM
How light can you go? Halibatsuiba Foamies (Kits) 1 Jul 17, 2004 06:37 AM
