Old Jun 01, 2011, 07:56 PM
DustyPockets is offline
Find More Posts by DustyPockets
A fool in a field.
United States, IL, Mahomet
Joined Dec 2006
Originally Posted by oly_rcer View Post
body,18.99,fins and hatch,free made from coroplast election signs,elevons,3.99 rods,2.49servos,2.69x2,esc,hk25-30a,5.99,clone 6100 reciever,4.99,motor 2409-12,9.79,paint,sharpie marking pens,2.00 batt,1800 3s,11.19 so my stryker complete ready to fly with batt 64.81 before tax.forgot,motor mount was about 3.00 it's a piece of 10mm square alum tube and hot glue
Pretty darn amazing how much fun you can have with a $65.00 airplane!!
Flew mine yesterday, just about time to break out the lite Stryker night flyer.
DustyPockets is offline Find More Posts by DustyPockets
Old Jun 03, 2011, 03:14 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
Going through my box of parts. Realize i have 2 HXT500's. Also have 6 HXT900's. Its been so long i can remember what the heck i was buying and for what.
8 gram difference....i dont mind the extra weight. Not sure if i bought the 500's for this build of just to have around cause so cheap.
wopachop is offline Find More Posts by wopachop
Old Jun 03, 2011, 08:28 PM
ssteven1 is offline
Find More Posts by ssteven1
United States, NC, Randleman
Joined Jan 2007
Wopachop use the hxt900 the weight difference is minor and a 5 gram servo is just to light in my opinion. I use the hxt900 and similar in mine.
ssteven1 is offline Find More Posts by ssteven1
Old Jun 03, 2011, 08:31 PM
wopachop is offline
Joined Apr 2007
10/4 brotha!!!
Old Jun 05, 2011, 03:33 AM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I decided to go for it and ordered my parts tonight:
  • TURNIGY Plush 10amp 9gram Speed Controller
  • GWS EP Propeller 8040
  • Turnigy 2730 Brushless Motor 1500kv
  • HXT900 9g Servos
I plan to run 800mAh 3S LiPos on it. Tell me that'll work.
mclarkson is offline Find More Posts by mclarkson
Old Jun 05, 2011, 07:42 AM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
I'm using the 1360kV Park 370 outrunner with the EP 8x4 and 2S 1200 lipo. Top speed on mine is about 40mph or so, although I usually fly it low and slow. I would guess yours will be a bit more zippy with the 1500kV motor.
Tony
t-turley is offline Find More Posts by t-turley
Old Jun 05, 2011, 09:46 AM
ssteven1 is offline
Joined Jan 2007
mclarkson the 800 ma should work fine. Watch your weight as much as possible. The stryker body does not really need any extra reinforcement when built light.
Old Jun 05, 2011, 02:24 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Thanks. I read through this whole thread and people are using a lot of different motors, usually somewhere around the 'Blue Wonder.' I thrashed for days before I decided to just pick some gear and go.
I'm not looking for anything near 40MPH on this plane - it will be all about the low and slow. I'd like something to fly in a small park, or even the neighborhood. I might try a 2S, but I don't have any right now.
Thanks for all the advice and info in the thread.
Old Jun 10, 2011, 12:25 AM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I did a quick test with some LED lights tonight. I taped a strip of red, upside-down, on the top of the wing. This way they shine down through the wing, lighting it up like a Chinese lantern. I’m not entirely sure it’ll be bright enough, but I’m planning on this being a low-and-slow plane, so I think I’ll be okay. (I hope.) Here is how it looks from the bottom with one wing:
Old Jun 10, 2011, 02:46 AM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Does anyone have any suggestions for ways to get those fiberglass support rods out of there without destroying the wing?
Old Jun 10, 2011, 10:47 AM
oly_rcer is offline
Find More Posts by oly_rcer
what ya mean i have to land?
DesMoines,Wa
Joined Feb 2008
i use a piece of dental floss,slide it under one end of the rod and slide it back and forth while moving it slowly down the rod(keep your comments to yourself)take your time and it will come out fairly easy.
oly
oly_rcer is offline Find More Posts by oly_rcer
Old Jun 11, 2011, 03:06 AM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I never ever would have thought of that. Thanks! I'll give it a try.
And I'm back and it worked. Thanks again. Man, those empty channels are begging to have some LED strips put in them.
Old Jun 11, 2011, 03:16 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Being naturally impatient, I just run a sharp knife quickly down each side of the rod and then grip the wingtip end with my needle nose pliers and just pull it out. Easy, quick and since I replace with 5 or 6mm rod and hot glue anyway, the extra "slot" size is an advantage!
Peter M is offline Find More Posts by Peter M
Old Jun 11, 2011, 08:11 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I nearly cut my fingers off with that floss, but I got them out. Those slots are the exact perfect size for HobbyKing LED strips.
Old Jun 11, 2011, 10:46 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
The Stryker wings flex quite abit without the CF spars, so be carefull in tight turns and pulling out of steep dives.
They also will have a tendacy to warp up at the tips.
Butch777 is offline Find More Posts by Butch777
Discussion how can you tell if you prop is cavatating? grfcon Flying Wings 3 Nov 19, 2009 12:30 AM
Discussion 2.4 How high can you go Spencer Thermal 10 Nov 05, 2009 06:47 PM
Discussion Lama 3 Flybar, How light can you go?? jamesppp Coaxial Helicopters 6 Feb 08, 2008 09:16 PM
How light can you go? Halibatsuiba Foamies (Kits) 1 Jul 17, 2004 05:37 AM
