Old May 19, 2011, 09:52 PM
tomcor is offline
Find More Posts by tomcor
Battery Powered==(*)==
tomcor's Avatar
Mesquite, Nevada
Joined Jan 2002
Lightweight Stryker onboard video
This is my Lightweight build Stryker with onboard keychain Camera.
Blue Wonder 1500kv
3S 500mah
Castle 10A
Depron fins and elevons.
Flys great my favorite at the moment. Can do great verticle till you can hardly see it.
Parkzone Stryker Lightweight Video 2 (7 min 26 sec)
tomcor is offline Find More Posts by tomcor
Old May 20, 2011, 11:53 PM
impostor is offline
Find More Posts by impostor
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
Finally got some time to make the video of me flying my lightweight build Stryker from a few weeks ago. It was a windy gusty day... Any feedback would be appreciated!
Lightweight Stryker Flights (5 min 7 sec)
impostor is offline Find More Posts by impostor
Old May 21, 2011, 10:03 AM
ssteven1 is offline
Find More Posts by ssteven1
United States, NC, Randleman
Joined Jan 2007
That looks good impostor. It handles the wind pretty well.
If that is a 2 cell you will have a lot more power and speed on a three cell. Just remember to not run that motor of 3 cell with the 8X4 prop. Use a 7 X 3.5 or like I do cut the 8X4 prop down to just under 7 inches (6.8), round the ends off and balance. You will have about 5 more ounces of thrust and 10 mph of speed.
ssteven1 is offline Find More Posts by ssteven1
Old May 22, 2011, 01:12 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Here is my take at the Light Stryker:
Lightweight Low Speed Stryker (2 min 5 sec)
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old May 22, 2011, 08:18 AM
impostor is offline
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
Looks good and nice flying rattlesnake!
@ssteven - I'll try the 3S with 7x.3.5 prop soon to see how that goes.
Old May 23, 2011, 03:05 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
I've built 6 Strykers while fuses were available for $20 shipped
with 19gr. motor was still abale to carry digital camera (modified Canon SD1000 ) , AUW 1lb at most.
RC plane gets in and out of 3000ft canyon - Toroweap (1 min 11 sec)
fmkit is offline Find More Posts by fmkit
Old May 23, 2011, 06:05 PM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
i'm having bad luck with these headuprc motors and escs. First set died on like my 10th flight. using the 2712-17 motor and power up 10amp esc with 7x3.5 prop and 11.1v 860mah batt all from headsuprc... the esc started smoking and I ripped the battery out as fast as I could but it still melted some foam... second set came today, I happily put together my plane once again to find out that the esc spins the motor for a split second and then beeps to reset. ughhhhhh, no flying for over a week already, crazy! I need to put together more planes fully setup, this is depressing!
oh, i actually also replaced the motor connectors on my castle creations phoenix 25 (older, orange sticker) and the only way to get this motor to spin is to push the prop while throttling up, cut my finger dangit!!! but the older ones have problems with outrunners...
and i barely ever used full throttle, only once in a while when floating really low to the ground at the lowest possible throttle to keep her level and then pull up to do a loop and continue.
KillerCut is offline Find More Posts by KillerCut
Old May 23, 2011, 11:27 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I've had good luck flying the Stryker-Lite on a 24g 1300Kv BlueWonder, with the HobbyKing 12a ESC, 8x6 GWS prop and a 910mah 3 cell.
I run this same set-up on a couple dozen planes.
Butch777 is offline Find More Posts by Butch777
Old May 27, 2011, 01:04 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
It would be cool to print out a template of the fins to cut out the depron.
Anyone know of a decent picture? Maybe one with a tape measure next to it for scale?
wopachop is offline Find More Posts by wopachop
Old May 27, 2011, 04:51 PM
wopachop is offline
Joined Apr 2007
Holy crap i read the entire F-27Q thread. Sucks the fuselage is 80 bucks and covered in heavy plastic stuff.
I know Butch or someone will be making a light version of it eventually.
Not sure why it says i joined in 07...im new to RC. In the past when they discontinue a plane can you still find parts years later? Or you fellas stocking up on fuselages?
Old May 27, 2011, 07:32 PM
DustyPockets is offline
Find More Posts by DustyPockets
A fool in a field.
United States, IL, Mahomet
Joined Dec 2006
I have two in the shop, ought to buy several more.
Fmkit you have won the ugliest light Stryker award!.....
DustyPockets is offline Find More Posts by DustyPockets
Old May 29, 2011, 09:59 PM
wopachop is offline
Joined Apr 2007
where be the love in this thread.
Old May 29, 2011, 10:15 PM
ssteven1 is offline
Joined Jan 2007
wopachop how is your build going?
Old May 30, 2011, 10:27 AM
wopachop is offline
Joined Apr 2007
Its just about to start!!! If hobby shop is open on a monday memorial day i will have a fuselage in my hand today woooohoooo!!!!
Read through the entire thread again and keep coming up with questions.
Whats lighter and/or stronger balsa wood or depron elevons?
Have you steven or anyone toyed around with notching in the motor mount VS laying it on top? I read you just lay on top. But have you ever tried notching to feel if plane flies different?
How much deflection should the elevons have? Trying to determine how large of angle to cut into elevon.
Old May 30, 2011, 11:43 AM
wopachop is offline
Joined Apr 2007
Also i noticed one guy used packaging tape on the leading edge of the wing.
Any thoughts on that?
Discussion how can you tell if you prop is cavatating? grfcon Flying Wings 3 Nov 19, 2009 12:30 AM
Discussion 2.4 How high can you go Spencer Thermal 10 Nov 05, 2009 06:47 PM
Discussion Lama 3 Flybar, How light can you go?? jamesppp Coaxial Helicopters 6 Feb 08, 2008 09:16 PM
How light can you go? Halibatsuiba Foamies (Kits) 1 Jul 17, 2004 05:37 AM
