Old Apr 21, 2011, 11:53 PM
impostor is offline
Find More Posts by impostor
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
Hey guys - How do you remove that screw in the nose cone? I can't seem to get it out.
impostor is offline Find More Posts by impostor
Old Apr 22, 2011, 05:55 AM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Originally Posted by NOTAR 600 View Post
Hey wow!
Here is a motor that might be fun on a light stryker. Don's RC has this 2200kv brushless outrunner firewall type mounting......only 29 grams. A little small for what I've been used to. This one has been tested with up to a 6x4 prop which pushes a stryker real good but I'm afraid it would overheat. The 5x5 would probly work better.
http://donsrc.com/cart/index.php?act...d&productId=63
I have a couple of WickedJr motors. They are good for speed, but at 2200kv and a small prop, may not have the thrust for unlimited vertical.
Murman is offline Find More Posts by Murman
Old Apr 22, 2011, 08:49 AM
ssteven1 is offline
Find More Posts by ssteven1
United States, NC, Randleman
Joined Jan 2007
I reach in the nose with some needle nose plier and drag that screw out. It is very stupid that parkzone still put those screws in there.
ssteven1 is offline Find More Posts by ssteven1
Old Apr 22, 2011, 10:05 AM
impostor is offline
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
Thank you! I'll try that since unscrewing with screwdriver didn't work for me.
Old Apr 22, 2011, 12:31 PM
NOTAR 600 is offline
Find More Posts by NOTAR 600
ohio usa
NOTAR 600's Avatar
Joined Nov 2007
I use a long super skinny screwdriver (or any stiff small diameter rod) and push it down through the foam from the top side so it pushes the screw down and out the original hole. Then spackle both holes with DAP fast-n-final from walmart (best type to use for filling voids in foam IMHO).
NOTAR 600 is offline Find More Posts by NOTAR 600
Old Apr 22, 2011, 01:16 PM
impostor is offline
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
Thanks guys! I ended up sticking a skinny needle nose plier in there and yanking it out. It wasn't easy. Luckily, I had some foam bits that I filled the hole with along with some Gorilla Glue.
Old Apr 22, 2011, 01:41 PM
ssteven1 is offline
Joined Jan 2007
That wicked jr motor looks like a good I just ordered one to try.
Old Apr 22, 2011, 09:26 PM
impostor is offline
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
Finally got the Stryker built. But it ended up not being so light at 13 oz. I'm going to run the 2712-17 motor with a 8040 prop on 2S 20C 1000mah. If that's not enough, I'll go up to a 3S 30C 1000mah with the 7035 prop.
Thank you for all the advice and help guys!!
Old Apr 23, 2011, 09:23 AM
ssteven1 is offline
Joined Jan 2007
That looks good imposter. At that weight you probably will not be happy on the 2 cell and will need the three cell. Make sure you get the COG right before you fly. It should fly fine at that weight on three cell.
If you want to lighten the plane up even more later you can replace those stock fins with foam. Those stock fins are heavy. Replace those stock fins and run a 800-600 ma three cell and you should drop about two ounces.
Old Apr 23, 2011, 09:36 AM
impostor is offline
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
Thanks for the advice ssteven, I'm trying to find some of the depron foam but looks like I have to buy bulk online since they don't just sell 1 sheet of it.
Old Apr 23, 2011, 03:56 PM
MiddleMarc is offline
Find More Posts by MiddleMarc
Cedar Rapids, IA
Joined Aug 2010
Originally Posted by impostor View Post
...trying to find some of the depron foam but looks like I have to buy bulk online since they don't just sell 1 sheet of it.
I'm hoping to use DollarTree foam (without the paper) for fins, elevons and battery cover.
But... $Tree foam is pretty flimsy without the paper. Anyone tried this? Got any advice?
I have a carbon strip I could glue to the elevons to stiffen it up.
For elevons: I've had folks recommend 3/16 Balsa (got some, doesn't seem too robust) or 3/16 basswood (got some, much more robust but also heavier).
I've seen coroplast used for fins and that does seem to be plenty stiff and light weight too?
MiddleMarc is offline Find More Posts by MiddleMarc
Old Apr 23, 2011, 03:58 PM
Cedar Rapids, IA
Joined Aug 2010
I've seen folks painting the whole bottom black to get enough contrast against the sky. Any experience on how stripes like this work? Well enough? I do want to keep the weight down. I like the way this looks in the picture but don't want to lose the plane when it gets up high!
Old Apr 23, 2011, 04:03 PM
Cedar Rapids, IA
Joined Aug 2010
Originally Posted by herk1 View Post
I used that same plastic stick mount on my lightweight Stryker (though I bought mine from HobbyKing). When I installed the mount, I attempted to align it parallel to the top/bottom centerline of the fuse, NOT to the top surface of the fuse (which angles down toward the back because of the tapering fuse/wing thickness). So the stick mount is embedded a little deeper towards the front. See the attached photo. It worked out just fine that way inflight...there are no sudden pitch-change effects when increasing or decreasing power. There is a build description and another photo of my lightweight Stryker here: http://www.rcgroups.com/forums/showthread.php?t=1337131
Thanks so much for posting this! I'm very new to building and only know enough to wonder what to do about thrust angle.
Old Apr 23, 2011, 04:06 PM
impostor is offline
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
My Super Cub has the stripes on the bottom like this and I can see it ok at the height I'm flying at (2X tree height). I haven't maiden this one yet so I don't know how it'll be for the Stryker.
Old Apr 23, 2011, 07:54 PM
ssteven1 is offline
Joined Jan 2007
If you can see the supercub you should be able to see the stryker. Fly it and see.
Discussion how can you tell if you prop is cavatating? grfcon Flying Wings 3 Nov 19, 2009 12:30 AM
Discussion 2.4 How high can you go Spencer Thermal 10 Nov 05, 2009 06:47 PM
Discussion Lama 3 Flybar, How light can you go?? jamesppp Coaxial Helicopters 6 Feb 08, 2008 09:16 PM
How light can you go? Halibatsuiba Foamies (Kits) 1 Jul 17, 2004 05:37 AM
