View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Feb 28, 2011, 09:05 AM
Gregg28 is offline
Find More Posts by Gregg28
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
Originally Posted by Ted Flack View Post
What is "depron"?
Depron is a white foam sheet. It is/is like grocery store meat trays. Widely used in small, light RC planes. It comes in sheets of about 1 to 10 millimeters.
http://www.depronfoam.com/
Gregg28 is offline Find More Posts by Gregg28
Old Feb 28, 2011, 09:13 AM
Ted Flack is offline
Find More Posts by Ted Flack
USA-Michigan
Joined Feb 2008
Thanks Gregg.
As far I as know a foam core hull is not legal on IOM's.
Ted Flack is offline Find More Posts by Ted Flack
Old Feb 28, 2011, 10:32 AM
strikermk2 is offline
Find More Posts by strikermk2
Norfolk Uk
Joined Sep 2007
Thanks for all of your replies. It is a shame that foam is illigal as hulls could be made very quickly and cheaply. Looks like i will stick to balsa.I may try a RG65 with 3mm depron and 25gr fglass and see how it turns out. I have plans for Brad Gibsons SKA design that look good. Maybe i will try that with DICK L's (see vanquish Thread) mahogany veneer and f/glass.
thanks
Bryan
strikermk2 is offline Find More Posts by strikermk2
Old Feb 28, 2011, 10:35 AM
jims123 is offline
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Ted & Isis
Thanks for the tips, I need to send a photo of the bumper I made from some black foam packing material similar to flip-flop stuff.. and to save the gas and hassle calling/driving round the sail making shops here I ordered some of this
http://www.sailrite.com/Insignia-Adh...d-UV-Dacron-10
Thanks again..
JimS
-A lot of guys make bumpers from flip-flops. Pick the color you like and cut and sand to shape. Boat builder usually make them to fit their own boats.
-For deck patches I use sticky back sail material, many colors available. ...
jims123 is offline Find More Posts by jims123
Old Feb 28, 2011, 11:09 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Romano
I'd take this with a grain of salt cause I haven't been sailing even 6 months, but you asked for different opinions, here's one from a new novice..
With the stiff winds you have in Burmuda, a bigger course is a good thing, especially helpful for those less skilled but with a faster boat. I like a longer course in lots of wind cause I make mistakes, and a longer course gives a little more chance to make up for them.
But, i know a long course can drag out that pain if you're in the rear too.
We can walk alongside the bank to see the other boats more clearly as well as see the windward and downwind marks, so seeing the marks is not so much a problem for us. But it appears you guys can't do that, and likely sail from an armchair on a pier. Everyone's vision is different.. making it very hard to see and time that turn, or to avoid hitting others at distance..so you're kinda stuck..perhaps with a shorter course as the best solution if you can't walk the bank alongside.
I would mix it up and have some long and some short runs in the race to balance it..specially as the winds fall off.
I'd also try to stick to the AYMA rules which call for a penalty turn if you hit one.. cause if you start setting local rules that may open a Pandora's box too.. Rule one is to Have Fun so you guys should do what ever you decide, and your RD re-affirms before the start .. we mod the rules here a lot too, but take the penalty if you hit another boat or a mark.
I've spent hours reading them, playing on the finckh.net site recommended here, and I still get confused trying to remember the rules, and when they apply, in so many different scenarios it's daunting.. having a local set to learn too, might just make it harder in the long run.
Thanks again for the videos and for asking .. good questions.. JimS
Originally Posted by Romano Ramirez View Post
A comment was made in reference to the length of our course. Some of of sailors have commented also that the course is too long and the difficulty in seeing the bouys correctly. How far out do you feel is a good distance for the furthest mark. Also do you think it should be ok to rub that mark and not be penilized? We are trying to work on these things and we have not yet been to an overseas club to compare. All opinions are important for us. ..
Old Feb 28, 2011, 11:22 AM
colin470 is offline
Find More Posts by colin470
Joined Feb 2010
Maybe you can consider a shorter length course but increase the number of laps.... if you have the 1st boat finish in the region of 10-12 mins should work out alright....
just my 2 cents worth
colin470 is offline Find More Posts by colin470
Old Feb 28, 2011, 11:30 AM
Brian Wa is offline
Find More Posts by Brian Wa
UK
Joined Sep 2002
What is "depron"?
see here:-
http://www.depron.co.uk/
Brian
Brian Wa is offline Find More Posts by Brian Wa
Old Feb 28, 2011, 04:35 PM
USA-Michigan
Joined Feb 2008
I understand some folks have purchased the French 11mm thin wall mast. Anybody have one rigged yet. I have one and am looking for input on how much, if any pre-bend you used and where you located the side-stays.
About I know so far is that it is a bendy section. Bending is not easy either.
Ted
Old Feb 28, 2011, 04:51 PM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Ted,
rebuilt my A rig on the Shadow with the 11mm French mast and the new fittings I am now selling and could only get 8mm in the top 700mm works great, sailed on Sat with an unturned rig and a 120 sec handicap by the end of the day I had won the last 2 races, so it is now turned, but not happy with a few small things.
8387mike is offline Find More Posts by 8387mike
Old Feb 28, 2011, 06:58 PM
Gregg28 is offline
Gregg28's Avatar
Joined Jun 2005
I am building an IOM. The hull is mostly done, but I have not started on the rig yet. Were can I assemble a mast and fitting package at a reasonable cost? For a class that was supposed to be inexpensive and favor the home builder it seems to be neither of those.
Old Feb 28, 2011, 09:40 PM
Romano Ramirez is offline
Find More Posts by Romano Ramirez
I love being the underdog!!!
Romano Ramirez's Avatar
Bermuda
Joined Jan 2011
This is what I like!
All these comments over the last 24 hours is great! We can walk along the shoreline here. Its the offshore mark that may be out too far. Thanks for the number on the bouy trick. Personally I'd prefer to follow international rules so that we do not drop our sailing standards.
Can anybody explain how a sailor gets to compete in the world championships? eg. In Kirby England.... Invited? Qualifys? per country?
Romano Ramirez is offline Find More Posts by Romano Ramirez
Old Mar 01, 2011, 01:27 AM
iomthinkin is offline
Find More Posts by iomthinkin
Australia (Sydney)
Joined Apr 2010
Ted, why do you need to prebend your mast? I`m assuming you are building your new boat!! If your sails are not yet made I`d suggest that you advise your sail maker that you intend to run a straight/ non prebent mast, IE that he (sail maker) incorporates a luff curve into the build. This down the line makes things a little more simple...."my theory".
I`d be interested in knowing more on the mast weight & its ability of memory (or lack thereof)
Mike, this is also directed at you, as you already have the section.
iomthinkin is offline Find More Posts by iomthinkin
Old Mar 01, 2011, 03:57 AM
Brian Wa is offline
UK
Joined Sep 2002
Check out the "Event Management Manual - Radio Sailing and the IOM Class"
doccument. These are the international rules for running IOM events.
See section 5 for Mark identification.
http://www.iomclass.org/events/IOMIC..._2005may05.pdf
Brian
Old Mar 01, 2011, 04:08 AM
Brian Wa is offline
UK
Joined Sep 2002
Not sure of the official route, but first you need to have a "National Association" for IOM model yacht sailing, this needs to then be recognised by the "World Council" as the official body representing IOM model sailing in your country.
It's too late to gat an entry for this years World Championships, but 2013 isn't that far away.
Isreal is the latest country to gain international recognition, see here:-
http://www.iomclass.org/phpBB3/viewtopic.php?f=9&t=1633
I would pose your questions in the above thread, addressed to Barry Fox.
Check out the IOMICA website:
http://www.iomclass.org/phpBB3/index.php
Hope this helps.
Brian
Old Mar 01, 2011, 05:02 AM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
iomthinkin,
The main reason you run prebend is to make your jib stay tighter.
Gregg,
IOM's are only as expensive as you want them to be, you can make a gooneneck, mast crane, use wooden booms, buy cheap Aluminium masts from the hardware stores. For boom fittings use rubber grommets and string.
Come on fire them at me I will try to answer every one of them
(here I am trying to put myself out of business)
www.shiftradioyachts.com
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
