View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Dec 23, 2012, 08:02 PM
TedFlack is offline
Find More Posts by TedFlack
United States, MI, Bloomfield Hills
Joined Feb 2010
Simon,
This article is about building a carbon fiber Marblehead but it shows a method of using shadows, foam blocks and lots of sanding.
http://radiosailingshop.com.au/index...age=page&id=11
TedFlack is offline Find More Posts by TedFlack
Old Dec 24, 2012, 09:35 AM
SimonRobinson is offline
Find More Posts by SimonRobinson
United Kingdom, North Shields
Joined Feb 2012
Foam for male mould
Thanks Andrew & Ted. It looks like both my ideas would work, so specific questions to Andrew:
1. could you get the finished hull reasonably accurate without using ply shadows? It is very attractive to use only a soft material, so no hard patches and quicker
2. I assume drywall mud is plaster of one form or another. Is that correct?
3. What sort of paint so as not to melt the foam?
4. Packing tape (parcel tape I susect here) sounds good to me, but how does one avoid getting rucks on the joins? I had imagined using shrink wrap over the mould but guess the foam might melt with the hot air gun needed to shrink it. Any thoughts?
Thanks and Happy Christmas to you all
Simon
SimonRobinson is offline Find More Posts by SimonRobinson
Old Dec 24, 2012, 01:38 PM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Simon
Appluing it diagonally seems to avoid the problem.
martin richards is online now Find More Posts by martin richards
Old Dec 24, 2012, 04:29 PM
PorkyPig is offline
Find More Posts by PorkyPig
David Cook Victoria, BC Canada
Joined Oct 2012
Porky Pig flies on maiden voyage
Thanks to Eric A's hard efforts to assemble Porky Pig ,4, hull no. 1 in a record 10 days after receiving the hull, decks and bits and pieces he went racing on its maiden voyage and managed to win a couple of races. See attached photos.
Hull no. 2 has its transom on and I'm building an assembly jig to align all the add-ons. Plans are in the works to build boats no. 3 and 4 early in the new year.
Merry Christmas to all.
David
PorkyPig is offline Find More Posts by PorkyPig
Old Dec 24, 2012, 04:37 PM
A.B. is offline
Find More Posts by A.B.
A.B.'s Avatar
Calgary Alberta, Canada
Joined Feb 2008
Yes, it is amazing how hard glued paper gets, use black marker around edge.
Yes.
Latex house paint
It does a little but not bad, you need to fill pin holes anyway. Also try finding link to German rubber method, no not the kinky sites, but these guys uses latex rubber sheets to streach over the mould, stapling it tight, then rolling out the air bubbles. Good luck
One other idea I have seen was making a full mould, deck and hull all in one the glass it all the way around the once cured you use acetone to dissolve the foam.
A.B. is offline Find More Posts by A.B.
Old Dec 24, 2012, 11:16 PM
Houdini13 is offline
Find More Posts by Houdini13
United States, CA, Fairfax
Joined Apr 2011
Merry Christmas
Houdini13 is offline Find More Posts by Houdini13
Old Dec 25, 2012, 05:26 AM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
Merry Christmas
Merry Christmas to all IOM Skippers and Happy New Year!
ToniGe23 is offline Find More Posts by ToniGe23
Old Dec 26, 2012, 04:17 PM
Joined Feb 2012
Foam mould
Thanks for all the useful advice. I'me going to do some practice and experimenting with foam sections. Eventually when I've done the complete boat I will post a link with photos to show how I did it.
I hope Santa brought you all the right IOM bits and pieces.
Simon
Old Dec 27, 2012, 02:49 PM
PorkyPig is offline
Joined Oct 2012
Eric went out sailing yesterday in very puffy conditions. See video links below.
PP4 1 (0 min 38 sec)
PP4 2 (0 min 55 sec)
PP4 3 (0 min 39 sec)
The boat has exceeded our expectations, I've got the first paying customer, going to make a female mold and set up a builder ASAP. If anyone is interested feel free to email me at porkyiom at telus.net for more info. Boat will be available in kit or complete form. Price TBD.
Cheers
David
Last edited by PorkyPig; Dec 27, 2012 at 03:09 PM. Reason: now have links to video
Old Dec 27, 2012, 08:12 PM
deafsail is offline
Find More Posts by deafsail
deafsail's Avatar
United States, FL, Jacksonville
Joined Mar 2012
Cant find for Mast Heel for Mast tube foot . no Heel Fitting w/pin . Maybe use make one delin rod plug for Mast heel ?
Baron
deafsail is offline Find More Posts by deafsail
Old Dec 27, 2012, 10:53 PM
hiljoball is offline
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
Baron
Is this what you are looking for?
http://www.midwestmodelyachting.com/...elFittings.asp
John
hiljoball is offline Find More Posts by hiljoball
Old Dec 28, 2012, 07:14 AM
deafsail is offline
deafsail's Avatar
Joined Mar 2012
Mast Tube Foot
Mast Tube Foot for http://radiosailingshop.com.au/index...8dacd903a28a55 or http://radiosailingshop.com.au/index...roducts_id=511
Baron
Old Dec 28, 2012, 08:25 AM
TedFlack is offline
Joined Feb 2010
I'm not sure you want either of those. One is too big and the other is for a deck mounted mast. I don't use anything to stop mast rotation other than the ram hitting the gooseneck.
I use one that is for the top (Item 119 in the Midwest Catalog)) and I cut off the little tab to make it fit the OD of the mast. Or I just make one out of delrin.
Ted
Old Dec 28, 2012, 03:18 PM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Baron
Variant used to do a mast step plug, but what I use now is a mast head plug that is round or as Ted said use a normal head plug and shave off the vane holder
8387mike is offline Find More Posts by 8387mike
Old Dec 29, 2012, 10:02 AM
FWAL is offline
Find More Posts by FWAL
Flying without a licence
FWAL's Avatar
United Kingdom, Wales, The Mumbles
Joined Dec 2010
A foam, filler foredeck plug ready for glassing and a little bit more done to the hull
http://www.rcgroups.com/forums/member.php?u=340972
FWAL is offline Find More Posts by FWAL
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion PLD Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
