View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Nov 29, 2012, 04:57 PM
D design is offline
Find More Posts by D design
NORTHLAND NEW ZEALAND
D design's Avatar
New Zealand, Northland, Totara North
Joined Feb 2012
I have a skiff type deck with the mast deck steeped and mast at 100mm lower point to deck limit mark. The only modifications needed to lower would be the goseneck. Lucky I have a telescopic mainsheet post!
D design is offline Find More Posts by D design
Old Nov 29, 2012, 06:03 PM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Originally Posted by TedFlack View Post
Low as possible within the rules, yes. BUT, there may be other things that get in the way, such as the vang hitting the side deck, sheet lines, etc. On my Britpop I had to get the wheel off the vang adjuster to clear the sheets. Just be aware!
This comes back to what was mentioned a few weeks ago about the where the vang meets the boom, if you shorten the vang it will clear the side deck, I had the same problem with my old TS2 clone.
8387mike is offline Find More Posts by 8387mike
Old Nov 29, 2012, 06:12 PM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
Originally Posted by BrushlesHeaven View Post
Sorry, new in rc sailing and this was asked before I am sure but
where do I get one of this sailboats please?
Robert
Robert,
As Ted said is it a second hand boat you are chasing or is it that hull that you want?
If so taht hull in the picture looks like a TS2, Check the for sale sections of different club, state and national website's.
I only know of one for sale but it is here in Western Australia
http://www.rsawa.asn.au/index.php?op...d=3&Itemid=100
Old Nov 29, 2012, 06:15 PM
isisagoodun is offline
Find More Posts by isisagoodun
Broughty Ferry, Dundee, Scotland
Joined Feb 2006
I would like to clarify the deck limit mark/lower measurement point association if I may.
The deck limit mark is a small perminant mark, painted or otherwise on the centreline of the deck in proximity to the mast recess or deck mount and must be a minimum of 5mm in diameter.
The lower limit mark on the mast which is a 5mm band, below the top of which the mainsail must not extend, and the top of which must be between 60mm and 100mm above the deck limit mark.
The three rigs 'A', 'B' &'C', must have their lower limit mark with a maximum variation of 5mm between them. This prevents skippers having two or more 'A' rigs with varying lower limit marks and being able to choose which to use for any given event, dependant on forecast conditions, as all smaller rigs would have to be within the 5mm tolerance.
Ralph
isisagoodun is offline Find More Posts by isisagoodun
Old Nov 29, 2012, 06:20 PM
hiljoball is online now
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
The latest edition of the excellent Seattle IOM newsletter is out.
http://www.seattleradiosailing.org/w...28email%29.pdf
John
hiljoball is online now Find More Posts by hiljoball
Old Nov 29, 2012, 06:29 PM
TedFlack is offline
Find More Posts by TedFlack
United States, MI, Bloomfield Hills
Joined Feb 2010
Ralph
The different rigs don't have to be within 5mm, this was discussed a few years ago on the International Forum and it was decided that all it means is that they all have to be within the 60mm to 100mm mark. Most of us here is he USA though they all had to be within 5mm of each other but turns out we were mistaken
But, as you said the reason from the rule was to prevent moving a given rig up and down as the wind changes. Apparently some people wanted to raise the rig quite high in light air and down in heavy air.
I'll see if I can find the discussion. http://www.iomclass.org/phpBB3/viewtopic.php?f=27&t=797
TedFlack is offline Find More Posts by TedFlack
hiljoball's Avatar
Joined Jul 2011
Ralph
HI Ralph,
Very good description of the limit mark.
The 5mm tolerance is not to prevent different A rigs being used - that is not allowed under the rules already.
I believe that it relates to the practice of using a tensioning screw on the mast heel to raise and tension the rig. The tolerance is to limit any excesses in changing rig height with that fitting (if used).
John
Old Nov 30, 2012, 02:17 AM
max67 is offline
Find More Posts by max67
max67's Avatar
Italy, Abruzzo, Pescara
Joined Jun 2010
Hi all,
on the link you can find photos of the of Mrs. Alessia Carmignani taken to European class IOM
http://mainboom.blogspot.it/
cheers, massimo
max67 is offline Find More Posts by max67
Old Nov 30, 2012, 07:21 AM
The Tug is online now
Find More Posts by The Tug
Barbados
Joined Jan 2011
Well i never knew i could generate a page and a half of discussion by moving my rig as i am only experimenting with this it is nice to know i don't have to move the other rigs if i decide to stay there,as Olivier has pointed out the boom will be low to the water which i do not think will be a problem here as the lake is high wind but small in size so it's flat water on a big steady breeze(excellent speed sailing) however this could be a problem in waves,the B rig and C rig are a big reduction in sail area in this class if you were to compare it to a real boat with a 1st reef, so i don't think it would be smart to carry those rigs at less than 70mm because at that point you shurley will have waves and you don't really need to stuff the rig right down in the boat as it is already a huge drop in mast height,it really depends where you sail as a big lake will have much more wave action than a small one given the same wind speed.A Lintel will never be fast in under 6 knots therefore i am looking for it's best setup around what it does best.If it's lite trust me i have another weapon.Sometimes too far East is West and i intend to find out.
The Tug is online now Find More Posts by The Tug
Old Nov 30, 2012, 07:48 AM
FRA3700 is offline
Find More Posts by FRA3700
OlivierFRA100
FRA3700's Avatar
Joined Nov 2006
You still sail your Lintel ? Not the other one ?
FRA3700 is offline Find More Posts by FRA3700
Old Nov 30, 2012, 08:16 AM
Barbados
Joined Jan 2011
The dust is coming off of this one these boats are still very fast when there is some wind blowing.
Old Nov 30, 2012, 01:29 PM
jims123 is online now
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Originally Posted by max67 View Post
Hi all,
cheers, massimo
Wow.. great Photos.. Thanks!
jims123 is online now Find More Posts by jims123
Old Nov 30, 2012, 01:40 PM
jims123's Avatar
Joined Oct 2007
repairing a keel bulb?
Tug,
I have another question... I just noticed that some how I got a little ding ( about 1/4 inch circular in diameter) in the front end of my keel bulb.. it's chipped off the multiple layers of paint , and exposed the lead and a silvery colored steel? rod running thru it..and its a chip at an oblique angle.. not straight on.. any way.. How should I fix this? I would like to try to sand down and around .. back perhaps an inch, and apply some bondo on it, then re-shape/ prime and paint it..
Will this work Ok? what paint should i use .. it's got a very shiny Black finish now.. but I suppose i could tape it off and do some other color since matching it will be nearly impossible.. alternatively I could take it off the Keel fin and try to re-sand and re-do the entire paint job on the bulb..it's almost exactly 2500grams now there are a few other blemishes in it.. but the prior owner had painted them with a touch up..
Old Nov 30, 2012, 04:13 PM
BrushlesHeaven is offline
Find More Posts by BrushlesHeaven
Lipo Power
BrushlesHeaven's Avatar
Joined May 2009
I got it, thank You...
Are you asking where to get an IOM or this design boat shown in the picture?
BrushlesHeaven is offline Find More Posts by BrushlesHeaven
Old Dec 01, 2012, 07:44 AM
Barbados
Joined Jan 2011
Originally Posted by jims123 View Post
Tug,
Mix up some of the west system snot(thickish) and use as a filler it gets very hard sand it back to shape and paint it.Did you put the air pump back or are the fish dead???Do not sand down the bulb you don't want to remove lead fill it and fair it.
Yesterday was a holiday here so i sailed the tug for 3 races in a moderate breeze and won 2,i see no problem so far with boom height, another members boat shut down so i let him sail it he had no probs either but time will be the test,it feels different because it looks different if you understand that terminology,again today we sail so i might drink less beer and sail more.
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
