View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Nov 26, 2012, 03:03 PM
jims123 is offline
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Originally Posted by hiljoball View Post
Hi Jim,
I can only do this sailing against other IOMs.It takes sailing 20 or more meters on a single tack to see if the boat is faster/slower/ pointing higher/lower. And it will only be a small gain or loss - and it requires that the other boat has not been altered and that sailor is sailing consistently. Just not possible to do against other classes of boat as the gain/loss is usually just a small increment for each adjustment.
John
John,
Thanks.. in practical terms I believe you are 100% correct.. I've occasionally checked the approximate time in my head that it takes me to hit the favored pin at the start line a few times.. but you're right .. you need to go farther say to weather or straight down wind to really tell, especially at our pond where its winds are so shifty even that varies a lot. I don't know how to measure it any way other than direct comparisons against an IOM in real time either... my problem is it's only a couple times a week i get to sail against others.. and often they are in ODOMs and Soling 50's so there's no meaningful direct comparison..
Carrying a stopwatch to time arbitrary runs to selected points seems impractical and likely ineffective too... but I hope it doesn't hurt to ask..
How these hull designers do it is a real mystery too..it must take hours of time on the water and keen observation skills to get an optimal design.
jims123 is offline Find More Posts by jims123
Old Nov 26, 2012, 09:33 PM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Ahh, Big boats are now copying BG's Britpop or is it a Lintel on steroids?
8387mike is offline Find More Posts by 8387mike
Old Nov 27, 2012, 12:43 AM
D design is offline
Find More Posts by D design
NORTHLAND NEW ZEALAND
D design's Avatar
New Zealand, Northland, Totara North
Joined Feb 2012
looks like the frames in the mold have expanded in the heat and humidity, same happend with my spitfire
D design is offline Find More Posts by D design
Old Nov 27, 2012, 12:44 AM
D design is offline
D design's Avatar
Joined Feb 2012
D1 undergoing major modifications.
Old Nov 27, 2012, 12:38 PM
FWAL is online now
Find More Posts by FWAL
Flying without a licence
FWAL's Avatar
United Kingdom, Wales, The Mumbles
Joined Dec 2010
That looks pretty serious Nathaniel, what's up D any lessons we could learn here
FWAL is online now Find More Posts by FWAL
Old Nov 27, 2012, 04:12 PM
D design is offline
D design's Avatar
Joined Feb 2012
Top secret
Old Nov 27, 2012, 06:02 PM
D design is offline
D design's Avatar
Joined Feb 2012
NZ Northland Champs 2012
Northland IOM Camps 2012 (13 min 35 sec)
Old Nov 27, 2012, 06:43 PM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
Hey Nathaniel,
Where abouts is that lake and is this where you sail?, I have travelled up and down that coast from New Plymouth to Wellington many times as my brother lives in Stratford and the rest of my family are in New Plymouth
Old Nov 27, 2012, 07:32 PM
D design is offline
D design's Avatar
Joined Feb 2012
Hey Nathaniel,
Hi Mike, we are from Northland, Kerikeri and we sail at Lake Manuwai and Whangaroa
Old Nov 27, 2012, 07:41 PM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
For some reason I was thinking you were way more down south, never been up there
Old Nov 28, 2012, 07:16 AM
FWAL is online now
FWAL's Avatar
Joined Dec 2010
Top secret
No worries, I wont tell anybody
Old Nov 29, 2012, 10:11 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
Oui you lot,i am searching for the rule where the lower mast band has to be above deck betwene a specific measurement max is 90mm to memory i want the min.Looking through the new IOMICA rig measurement form i have'nt seen it however it was there on the previous tick the box sheet.i want to expirement with lowering my A rig to the minimum.
The Tug is offline Find More Posts by The Tug
Old Nov 29, 2012, 10:18 AM
FRA3700 is offline
Find More Posts by FRA3700
OlivierFRA100
FRA3700's Avatar
Joined Nov 2006
C.7.4 MAST
(a) DIMENSIONS
.................................................. ..............................minimum maximum
Lower point to deck limit mark
as defined in D.1.5 ................................................ 60 mm ..... 100 mm
FRA3700 is offline Find More Posts by FRA3700
Old Nov 29, 2012, 10:27 AM
The Tug is offline
Barbados
Joined Jan 2011
Thank you Olivier i made a guess and put it at 60mm doing this to my Lintel to see what it's like built new blue rig and used one of Pierre's goosenecks which are very short allowing you to do this,if i don't like it i will just put back on a sleeve on the bottom of the mast.We have the breeze for this and other Tugs to sail against .Thanks
Old Nov 29, 2012, 11:02 AM
FRA3700 is offline
OlivierFRA100
FRA3700's Avatar
Joined Nov 2006
You're welcome !
Just tell me if your boom is not too much in the water when reaching.
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
