View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Nov 21, 2012, 05:47 PM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
The IOM Europeans looks like it's hotting up I wonder what happened to Olivier Cohen 100 he was doing well till he got a 75 score!
ToniGe23 is offline Find More Posts by ToniGe23
Old Nov 21, 2012, 06:11 PM
TedFlack is offline
Find More Posts by TedFlack
United States, MI, Bloomfield Hills
Joined Feb 2010
Black Flag, so last place, and then he got stuck in the B fleet, I watched a couple of B fleet videos, he got really messed up at the start in one of them.
TedFlack is offline Find More Posts by TedFlack
Old Nov 21, 2012, 08:52 PM
jims123 is offline
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Mystery solved
Originally Posted by jims123 View Post
I'm concerned that twice now.. After a full day on the water , I drained a teaspoon of water from the hull.. So here is how I plan to try to find the leak.. I'll borrow the aquarium pump and some airline tubing .. And connect it into the 1/4 inch drain plug hole and seal it... While I pump in air, I'll put soapy water all over the hull and see where it bubbles.. Will it find the leak? Is there a better way? No.. I don't have a swimming pool.. JimS
The Aquarium pump worked great. I went over the entire hull with soapy water and found no bubbles brewing anywhere.. until I got to this receiver compartment that is.. there is a leak on the port side aft side that was very clear to spot.. I plan to pull out the receiver and servo wiring, undo the two screws and hope I can pull it out before putting a thin bear of PU goop around its top seam and then re-installing it..
The seam on the port bow was simply a little red trim tape lifting a bit from the hull but nothing was leaking there or around the rudder post and elsewhere that I could find...
jims123 is offline Find More Posts by jims123
Old Nov 21, 2012, 09:09 PM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
I normally run a bead of Silicon around the pot and then push it back into the deck this normally seals it up just fine.
8387mike is offline Find More Posts by 8387mike
Old Nov 21, 2012, 09:46 PM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
That's because you got everything down under that bites kicks or kills but no AMAZING GOOP that stuff is AMAZING for sticking a pot in a boat,Jim we're done helping til after the Euros lol.Oui rip the pot out and get rid of the silicone first.
The Tug is offline Find More Posts by The Tug
Old Nov 21, 2012, 10:35 PM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Ok.. The pots back in and sealed..but I didn't use the polyurethane goop cause its so strong I worried I'd have a very hard time removing it if needed later, so used Elmer's glue in a I inch wide seal around ( after clearing all the original silicone) the top and will retest it once its dry. I'm on to doing the rudder to fit the hull contour tomorrow. Agree the IOM world races are a lot more interesting than my US450 saga..
Old Nov 21, 2012, 10:41 PM
gpzy is offline
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
Is Elmers glue water proof ?
gpzy is offline Find More Posts by gpzy
Old Nov 22, 2012, 10:55 AM
max67 is offline
Find More Posts by max67
max67's Avatar
Italy, Abruzzo, Pescara
Joined Jun 2010
please do not remind me the village and the rover. I ran a long time ago (1967)
max67 is offline Find More Posts by max67
Old Nov 22, 2012, 01:17 PM
Dick L. is online now
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
It is "water resistant" when dry/cured (Titebond II)
Dick L. is online now Find More Posts by Dick L.
Old Nov 22, 2012, 04:32 PM
ToniGe23 is offline
ToniGe23's Avatar
Joined Jun 2005
Wednesdays Highlights
IOM Europeans 2012 - Wednesday Highlights (4 min 47 sec)
Old Nov 22, 2012, 09:20 PM
marter1229 is offline
Find More Posts by marter1229
marter1229's Avatar
United States, ID, CDA
Joined Aug 2005
Great video!
marter1229 is offline Find More Posts by marter1229
Old Nov 23, 2012, 10:44 AM
ToniGe23 is offline
ToniGe23's Avatar
Joined Jun 2005
Thursday's Highlights if you can call it that with only 2 races completed!
IOM Europeans 2012 - Thursday Highlights (4 min 34 sec)
Old Nov 23, 2012, 01:04 PM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Humm.. probably not.. so I stripped it out and used silicone sealer
Old Nov 23, 2012, 01:18 PM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Rudder hull contour mod complete
The Saran wrap we have no longer stretches smooth when it's on tight so I used some Vinyl covering. a single West System Epoxy packet pair was way too much but mixed in the microballs, and hoped it would thicken.. after 15 minutes it was barely thick enough but i went ahead and applied it to the top edge of the fin and lubed the shaft and slipped it in and added a bit more to fill any divits. After removal, , there was a bit of overlap on the sides of the fin but in 3 hrs it was almost hard, and I shaped it very easily with a hobby knife.. Here's how it turned out.. the black "paint" is from a permanent marker.. it's a perfect fit to the hull contour now, and yet the rudder turns easily on the shaft. Thanks Tug and Mike for the tips on doing this mod.
Old Nov 23, 2012, 03:12 PM
FWAL is offline
Find More Posts by FWAL
Flying without a licence
FWAL's Avatar
United Kingdom, Wales, The Mumbles
Joined Dec 2010
More 7 boR
Photo's + of the weeks progress:
http://www.rcgroups.com/forums/member.php?u=340972
FWAL is offline Find More Posts by FWAL
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
