View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Nov 11, 2012, 12:16 PM
fvracerone1 is offline
Find More Posts by fvracerone1
USA, MI, Ortonville
Joined Sep 2006
patch removal
If you are having trouble removing deck patches, I would reccomend using a hair dryer on medium heat to loosen the adhesive.... If you have adhesive left on the hull, WD40 and a soft cloth will remove it.....
Frank Vella
fvracerone1 is offline Find More Posts by fvracerone1
Old Nov 11, 2012, 08:08 PM
jims123 is offline
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
HS 645MG replacement?
I appreciate all the tips on deck patch material and ordered some of the more durable material ToniG recommended to compare as well.. Have another question..
I noticed that my rudder servo tends to buzz a bit when the stick is idle, and it doesn't center properly each time I tap it left or right it toggles and centers about 5 degrees off to the left or right of center-line.. There doesn't seem to be friction in the rudder shaft or control rod linkage that would cause this so i want to replace it.. I've just ordered an identical servo but wonder, is there a significantly better alternative rudder Servo out there for IOM's now? this Hitec HS645MG is pretty old , as is this boat..
Regards. JimS
jims123 is offline Find More Posts by jims123
Old Nov 12, 2012, 07:44 AM
TedFlack is offline
Find More Posts by TedFlack
United States, MI, Bloomfield Hills
Joined Feb 2010
Regards. JimS
I use a $10.00 Futaba 3004, it works great. After a full season of using them in two different boats I think they are fine I used to use $100.00 fancy digital steering servo's but not any more.
TedFlack is offline Find More Posts by TedFlack
Old Nov 12, 2012, 08:04 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
When a servo is buzzing there is a bind somewhere,check the top of the rudder and the bottom of the boat then shaft then linkage.
The Tug is offline Find More Posts by The Tug
Old Nov 12, 2012, 09:51 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Tug,
Agreed, but the rudder, with no control arm attached spins easily in the shaft, I did replace the arm and drilled the hole for the rod only slightly, so that is a little snug yes,.. but I want it that way to keep the linkage free play down.. that leaves this little rubber hull access tube, and I will try to lubricate it a little with some silicon lube.. or it's the centering failure in the servo itself causing the intermittent buzz.. I want to see if it persists with the new servo before worrying about it but I do completely agree it's not normal, and that while it's buzzing, I know the servo is draining my battery quickly. ( I don't want to risk replacing that access tube but that's where the drag is now)
by the way if you look to the right of and above the control arm you will see where I think a little water got into the boat last time out.. thru that slight air gap under the clear laminating film.. I believe that lifted slightly last time out.. .. I will be replacing it soon too..
Thanks.. JimS
Old Nov 12, 2012, 10:01 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Ted,
it's very encouraging to know an IOM can still sail well with a servo that has got 1/2 the torque in mine now.. I am tempted but for one thing.. here in San Diego the Local HiTec repair outfit has always repaired and/or replaced any servo mailed to them for free. I've done this a half dozen times on glider/airplane servos. So. I'm sticking with Hitec for that reason and am pretty confident I can get this one fixed ( for use as a spare) too.. Another friend met here on this thread sent me a half dozen links to several others that would work well .. including some water proof ones from HiTec RCD so it's great to know there are so many alternatives including cheaper ones that work well. Thanks Again, JimS
Old Nov 12, 2012, 11:10 AM
Tom Corbett is online now
Find More Posts by Tom Corbett
Joined Mar 2012
I used to have the problem of servos not centering, buzzing and burning out. On my futaba, I found that if you lower the sensitivity of the signal put out by the transmitter the problem goes away and it doesn't affect control in any way.
Tom Corbett is online now Find More Posts by Tom Corbett
Old Nov 12, 2012, 01:09 PM
jims123 is offline
jims123's Avatar
Joined Oct 2007
I've never heard of doing such an adjustment. Is it the rf power out if the Tx , or something on the Rx that is adjustable .. Do u have a Futaba Radio setup? I have an Assan and it doesn't support it .. But as Tug said, generally it's something mechanically binding that causes servo buzz
Old Nov 12, 2012, 01:27 PM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
I have never heard such utter nonesense
ToniGe23 is offline Find More Posts by ToniGe23
Old Nov 12, 2012, 02:51 PM
Joined Mar 2012
To be clearer--on my Futaba (a 3VCS) there is a mode/modulation selection menu item where the user is given a choice between HRS, PPM, and PCM (this is reflected on page 89 of the manual). Even if you are using the system on 2.4gz, if you change/dial down the modulation selection from HRS (high resolution) or PCM to PPM, jittery and buzzing servos seem to go away. This is particularly true if you are using older, analog servos. Check the manuals for a variety of radios and other threads on the r/c forums site and I think you will find further confirmation of this "utter nonesense"
Old Nov 12, 2012, 05:20 PM
waboats is offline
Find More Posts by waboats
Joined Jan 2007
waboats is offline Find More Posts by waboats
Reply With Quote  (Disabled)
Old Nov 12, 2012, 08:49 PM
Rssailor is online now
Find More Posts by Rssailor
United States, CA, Alameda
Joined Nov 2010
Tom, the 3VCS has several features that other Radios do not have. The mode/modulation is one, the knob adjustment for the third channel is another feature. Its an expensive radio, but worth it. I really like mine. FYI, I just got a new Hitec waterproof servo for the rudder on my Pikanto and it works well. Ryan
Rssailor is online now Find More Posts by Rssailor
Old Nov 12, 2012, 09:09 PM
gpzy is online now
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
What model Hitech servo ? Specs ?
gpzy is online now Find More Posts by gpzy
Old Nov 12, 2012, 10:46 PM
waboats is offline
Joined Jan 2007
Grzy
I have been trying to get some of these to do some testing.. Especially the Mini version..
http://www.hitecrcd.com/products/ser...vos/index.html
Click on each for specs..
Cheers
John
Old Nov 13, 2012, 04:42 AM
FRA3700 is offline
Find More Posts by FRA3700
OlivierFRA100
FRA3700's Avatar
Joined Nov 2006
There is another analog one http://www.hitecrcd.com/products/ser...vos/index.html
FRA3700 is offline Find More Posts by FRA3700
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
