View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Oct 22, 2012, 04:43 PM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
jims123, you do not need more than 180* on a HS7950 arm servo to get enough travel. My arm is less than 3 inches and I can adjust my endpoints out at each end to get around 120* which is enough for two IOMs that I have them in. It has a 1:2 block on the arm end. No need to convert it to a drum.
On the other hand, RMGs are pretty foolproof (at twice the price). You will be happy with their performance, and their ability to use 2S lipos and regulate voltage to the RX and rudder servo.
hew565 is offline Find More Posts by hew565
Old Oct 22, 2012, 07:17 PM
TedFlack is offline
Find More Posts by TedFlack
United States, MI, Bloomfield Hills
Joined Feb 2010
Hey
I'm very happy with how it went.. .. it didn't sink.... or leak a drop for that matter .. sailed about an hour.. plan to get a new A rig on order cause I doubt a credit card edge alone can take these creases out of the main..
Cool.
Not sure I have ever seen that much wind at that place. Glad it all worked.
Like Hew said, the 7950 will work fine. But I'm sticking with the RMG.
Ted
TedFlack is offline Find More Posts by TedFlack
Old Oct 22, 2012, 09:43 PM
jims123 is offline
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Originally Posted by TedFlack View Post
Cool.
Ted
Ted., I too am glad there's a simple alternative and that the HS7950 with arm works well..
I have a couple questions in these attached Photos..if anyone could give me some advice in reply I'd appreciate it.. Thanks IN Advance
jims123 is offline Find More Posts by jims123
Old Oct 22, 2012, 10:36 PM
hew565 is offline
USA, LA, Mandeville
Joined Feb 2005
Try http://midwestmodelyachting.com for a rudder arm. The third pic is probably the downhaul for the main. It may need to be longer to reach, but the fitting it is on is adjustable fore and aft on the boom. It should run forward to the gooseneck, through some sort of turning hole and tie to the tack of the main.
Old Oct 22, 2012, 10:51 PM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Jim Try these from Sailsetc
From the looks you may need to extend both lines
8387mike is offline Find More Posts by 8387mike
Old Oct 23, 2012, 02:38 AM
FRA3700 is offline
Find More Posts by FRA3700
OlivierFRA100
FRA3700's Avatar
Joined Nov 2006
Picture 2=> For Rig 1, you don't use eyelets, for rig 2, 1 eyelet, for rig 3, 2 eyelets.
FRA3700 is offline Find More Posts by FRA3700
Old Oct 23, 2012, 08:32 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
rgr, understood.. ..and I'm assuming the A Rig is the same as Rig 1
Thanks Mike for the .pdf tips too I see that little strap on the .pdf drawings too, but it appears to be redundant to the downhaul adjustment line that's already in place on the Main, so I need to ask one of the guys how to rig it later at the pond I guess. Right now it's just dangling loose at one end..
Old Oct 23, 2012, 08:37 AM
FRA3700 is offline
OlivierFRA100
FRA3700's Avatar
Joined Nov 2006
In IOM class rules, there are only rigs 1/2/3.
Marblehead use rigs A/B/C/C1... ;-)
Old Oct 23, 2012, 08:41 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
hew565,
I'm sorry I'm confused and failed to show you the downhaul earlier, but since this downhaul was already in place on the main I used it.. so this short little stubby line still is a mystery.. I plan to just remove it.. Regards, JimS
Old Oct 23, 2012, 08:44 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
I'm afraid I've got a lot of catching up to do on the IOM rules. could probably take me a lifetime so I better get started. Thanks, JimS
Old Oct 23, 2012, 10:12 AM
FRA3700 is offline
OlivierFRA100
FRA3700's Avatar
Joined Nov 2006
hew565,
You have a downhaul for luff line (in place on your picture) and a downhaul for the sail itself, also called cunningham. It is used to adjust tension of the sail. I believe this is it.
Old Oct 23, 2012, 10:53 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Ahahh, now I understand .. I bet you are right.. this particular line is too short but I understand where the cunningham is supposed to be connected to the tack of the main now.. and I'll look more closely at the .pdf's Mike sent too.. Thank You very much FRA..
Old Oct 23, 2012, 10:59 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Counterweight ?
I noticed that the oval lead counterweight is missing on the pointy end of my Jib's Boom.. is this a required item? what weight do I need to buy for a No1 Rig?
I notice that they come in several different weights at item 105 and below here:
http://midwestmodelyachting.com/BoomHardware.asp
Old Oct 23, 2012, 11:26 AM
jims123 is offline
jims123's Avatar
Joined Oct 2007
New Sails?
I need a new No 1 main sail.. can I assume that new sails will fit properly in my mast/ boom and rigging? should I get the a new Jib at the same time? Who'd recommend a good IOM sail maker with a good track-record?
Old Oct 23, 2012, 11:35 AM
gpzy is offline
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
Do they sail IOMs down in San Diego? We sail them up in the L.A. area once a month. You may find someone local. My IOM has Brad Gibson sails and I have a set of Black Magic sails. Have no idea about the fit, great question because I am ready for a new set myself.
gpzy is offline Find More Posts by gpzy
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion PLD Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
